    Error code EADDRINUSE
    41 Posts 3 Posters 19.1k Views 3 Watching
      PXNDA
      I cloned MagicMirror and copied the run-start.sh into the original but it still doesn’t work.
      Entire error:
      { Error: listen EADDRINUSE 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1330:14)
          at listenInCluster (net.js:1378:12)
          at doListen (net.js:1492:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
          at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
          at startup (internal/bootstrap/node.js:241:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
        errno: 'EADDRINUSE',
        code: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080 }
      S mumblebajM 2 Replies Last reply
        sdetweil @PXNDA
        @PXNDA that means something is already using port 8080. Maybe u have pm2 running magicmirror already
        • mumblebajM
          mumblebaj Module Developer @PXNDA
          @PXNDA As @sdetweil mentioned, the EADDRINUSE means that something is already listening on port 8080. You need to check what it is and kill the process and try restarting the MM again.
            PXNDA
            Thank you. It fixed the error code but now it is asking me to create a config file when I already have one.
              sdetweil @PXNDA
              @PXNDA u have a syntax error
              From the MagicMirror folder do
              npm run check:config
              Fix errors top down, rerun til no errors
                PXNDA
                Thanks it worked but I now have a black screen, with nothing on it.
                  sdetweil @PXNDA
                  @PXNDA open the developers console, ctrl-shift-i, select the console tab and scroll up to find any errors, usually in red text
                    PXNDA
                    I got this warning:
                    Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                    Policy set or a policy with “unsafe-eval” enabled. This exposes users of
                    this app to unnecessary security risks.
                    For more information and help, consult
                    https://electronjs.org/docs/tutorial/security.
                    This warning will not show up
                    once the app is packaged.
                      sdetweil @PXNDA
                      @PXNDA don’t care about that… looking for errors
                      are you still getting the eaddressinuse error in the terminal window?
                        PXNDA
                        No, and i only have that warning.
                          PXNDA
                            select the console tab… you are on the elements tab
                              PXNDA
                              same thing:
                              C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
                              warnAboutInsecureCSP @ C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
                                sdetweil @PXNDA
                                @PXNDA change the filter from defaults to all
                                  PXNDA
                                  What do you mean?
                                    PXNDA
                                      sdetweil @PXNDA
                                      @PXNDA there is a field called filter, center … there should be a lot of info in the console…
                                      the very top row, elements, console, sources, network, …
                                        sdetweil @PXNDA
                                        @PXNDA not the word all, next to it there is a drop down says default levels
                                          PXNDA
                                          Same thing:
                                            sdetweil @PXNDA
                                            @PXNDA ok… kill mirror
                                            then from the MagicMirror folder do
                                            npm start &
                                            there should be a stream of info , like this
                                            > magicmirror@2.8.0 start /home/pi/MagicMirror
                                            > sh run-start.sh
                                            Starting MagicMirror: v2.8.0
                                            Loading config ...
                                            Loading module helpers ...
                                            handler helper in init
                                            Module helper loaded: MMM-SleepWake
                                            Module helper loaded: MMM-ImagesPhotos
                                            Module helper loaded: MMM-voice
                                            Module helper loaded: WaterLevels
                                            All module helpers loaded.
                                            Starting server on port 8086 ...
                                            Server started ...
                                            Connecting socket for: MMM-SleepWake
                                            handler helper in start
                                            Connecting socket for: MMM-ImagesPhotos
                                            Starting node helper for: MMM-ImagesPhotos
                                            Connecting socket for: MMM-voice
                                            Starting module helper: MMM-voice
                                            Connecting socket for: WaterLevels
                                            Starting module: WaterLevels
                                            Launching application.
                                            then u should see any messages from the node_modules…
