    Error code EADDRINUSE
    41 Posts 3 Posters 18.3k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer @PXNDA
      @PXNDA As @sdetweil mentioned, the EADDRINUSE means that something is already listening on port 8080. You need to check what it is and kill the process and try restarting the MM again.
        PXNDA
        Thank you. It fixed the error code but now it is asking me to create a config file when I already have one.
          sdetweil @PXNDA
          @PXNDA u have a syntax error
          From the MagicMirror folder do
          npm run check:config
          Fix errors top down, rerun til no errors
            PXNDA
            Thanks it worked but I now have a black screen, with nothing on it.
              sdetweil @PXNDA
              @PXNDA open the developers console, ctrl-shift-i, select the console tab and scroll up to find any errors, usually in red text
                PXNDA
                I got this warning:
                Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                Policy set or a policy with “unsafe-eval” enabled. This exposes users of
                this app to unnecessary security risks.
                For more information and help, consult
                https://electronjs.org/docs/tutorial/security.
                This warning will not show up
                once the app is packaged.
                  sdetweil @PXNDA
                  @PXNDA don’t care about that… looking for errors
                  are you still getting the eaddressinuse error in the terminal window?
                    PXNDA
                    No, and i only have that warning.
                      PXNDA
                        select the console tab… you are on the elements tab
                          PXNDA
                          same thing:
                          C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
                          warnAboutInsecureCSP @ C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
                            sdetweil @PXNDA
                            @PXNDA change the filter from defaults to all
                              PXNDA
                              What do you mean?
                                PXNDA
                                  sdetweil @PXNDA
                                  @PXNDA there is a field called filter, center … there should be a lot of info in the console…
                                  the very top row, elements, console, sources, network, …
                                    sdetweil @PXNDA
                                    @PXNDA not the word all, next to it there is a drop down says default levels
                                      PXNDA
                                      Same thing:
                                        sdetweil @PXNDA
                                        @PXNDA ok… kill mirror
                                        then from the MagicMirror folder do
                                        npm start &
                                        there should be a stream of info , like this
                                        > magicmirror@2.8.0 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        Starting MagicMirror: v2.8.0
                                        Loading config ...
                                        Loading module helpers ...
                                        handler helper in init
                                        Module helper loaded: MMM-SleepWake
                                        Module helper loaded: MMM-ImagesPhotos
                                        Module helper loaded: MMM-voice
                                        Module helper loaded: WaterLevels
                                        All module helpers loaded.
                                        Starting server on port 8086 ...
                                        Server started ...
                                        Connecting socket for: MMM-SleepWake
                                        handler helper in start
                                        Connecting socket for: MMM-ImagesPhotos
                                        Starting node helper for: MMM-ImagesPhotos
                                        Connecting socket for: MMM-voice
                                        Starting module helper: MMM-voice
                                        Connecting socket for: WaterLevels
                                        Starting module: WaterLevels
                                        Launching application.
                                        then u should see any messages from the node_modules…
                                          PXNDA
                                          Will this work with Git Bash? This is what I’m using.
                                            PXNDA
                                            Tried it twice got this
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno ENOENT
                                            npm ERR! syscall spawn
                                            npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                                            npm ERR! spawn ENOENT
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.8.0 start script.
                                            npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
