    My MagicMirror screen keeps turning off
    20 Posts 4 Posters 9.9k Views 4 Watching
    • E Offline
      EhsanMomeni81 @evroom
      @evroom
      I edited the autostart which was stated in the MagicMirror guide
      sudo nano /etc/xdg/lxsession/LXDE/autostart
      • evroomE Offline
        evroom @EhsanMomeni81
        @EhsanMomeni81
        For Debian buster that seems to be right.
        For Debian stretch it is
        /home/pi/.config/lxsession/LXDE-pi/autostart
        On my Debian buster Pi with official RPI 7 inch screen, I have this for screen off after15 minutes.
        So, your xset settings seem right; have them like that on my other MagiMirror install (on Debian stretch) too.
        pi@raspberrypi:~ $ cat /etc/xdg/lxsession/LXDE-pi/autostart
        @lxpanel --profile LXDE-pi
        @pcmanfm --desktop --profile LXDE-pi
        @xscreensaver -no-splash
        point-rpi
        @xset s 900
        @xset s blank
        @xset -dpms
        @sdetweil made install scripts, so I guess he knows a bit more.
        MagicMirror version: 2.37.0
        S E 2 Replies Last reply Reply Quote 0
          sdetweil @evroom
          @evroom not for screen stuff yet
          • E Offline
            @evroom
            Sorry, but Debian buster and Debian stretch?
            I have a cronjob to turn off the screen at 11 pm until 6 am, which works, but other than that I want the screen to be on. Is it possible to change 900 to 61 200 (17 h) instead?
            • evroomE Offline
              evroom
              @EhsanMomeni81 said in My MagicMirror screen keeps turning off:
              I guess you downloaded and installed an image with Debian, like from
              https://www.raspberrypi.org/downloads/raspbian/
              Debian Buster is the latest Debian version.
              With lsb_release -ayou can find out which version you have.
              If your cronjob works for turning on / off the screen, then I guess you do not need to use the @xset parameters to turn off the screen.
              This is what I currently have:
              For Debain Stretch (screen always on):
              $ cat /home/pi/.config/lxsession/LXDE-pi/autostart
              @point-rpi
              @unclutter -display :0 -idle 3 -root -noevents
              @xset s noblank
              @xset s off
              @xset -dpms
              For Debian Buster (screen off after 900 seconds):
              point-rpi
              @xset s 900
              @xset s blank
              @xset -dpms
              Not sure what the other entries do, I just appended the @xset lines to the existing entries.
              Will try what happens when I remove them a bit later.
              • evroomE Offline
                evroom @evroom
                @evroom said in My MagicMirror screen keeps turning off:
                To answer myself.
                lxpanel        0.10.0-2+rpt4 armhf        LXDE panel
                pcmanfm        1.3.1-1+rpt7 armhf        extremely fast and lightweight file manager
                point-rpi      0.20160905   armhf        Locate the mouse pointer over the menu button
                xscreensaver - not installed
                Using Debian Buster and a RPI 7 inch display, these settings should work for ‘screen always on’:
                @point-rpi          # locate the mouse pointer over the menu button
                @xset s off         # don't activate screensaver
                @xset -dpms         # disable DPMS (Energy Star) features.
                @xset s noblank     # don't blank the video device
                I left @point-rpias it sounds useful somehow; for screensaver settings not needed though.
                Will test it now.
                • evroomE Offline
                  evroom @evroom
                  @evroom
                  Talking to myself :-)
                  The settings for Buster are not working.
                  My display goes to sleep after 10 minutes.
                  Perhaps because it isn’t a HDMI connected monitor.
                  I found 2 interesting files though:
                  pi@raspberrypi:~ $ ls -als /home/pi/.xsession-errors
                  4 -rw------- 1 pi pi 2426 Aug  1 12:30 /home/pi/.xsession-errors
                  pi@raspberrypi:~ $ ls -als /home/pi/.cache/lxsession/LXDE-pi/run.log
                  20 -rw------- 1 pi pi 17988 Aug  1 12:30 /home/pi/.cache/lxsession/LXDE-pi/run.log
                  Also see that this file is being used, so that seems right:
                  • evroomE Offline
                    evroom @evroom
                    @evroom
                    This works (running for 100 minutes at the moment of posting):
                    $ sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
                    @touch /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                    @point-rpi
                    @xset -dpms
                    @xset s off
                    @xset s noblank
                    Note: the autostart file does not like comments.
                    Reboot:
                    $ sudo reboot
                    After reboot is finished, check:
                    $ ls -als /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                    That will tell if the autostart file was used (timestamp should match reboot time).
                    Then check for set errors:
                    $ grep xset /home/pi/.cache/lxsession/LXDE-pi/run.log
                    It should say 3 times Launching xset, with 3 times exit 0 (for every set entry in the autostart file).
                    Works for Raspberry Pi 7" Touchscreen Display.
                    $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID:	Raspbian
                    Description:	Raspbian GNU/Linux 10 (buster)
                    Release:	10
                    Codename:	buster
                    • E Offline
                      EhsanMomeni81
                      Wow, that’s a lot to take in. Thank you so much for your help, I’m going to try this during the week.
                      • E Offline
                        @evroom
                        @point-rpi
                        @xset -dpms
                        @xset s off
                        @xset s noblank
                        I tried the code above, and it works on stretch, I screen doesn’t turn off. But my cronjob acts funny. Last night when I look at it after it was supposed to be turned off, the backlight was on but everything else was dark. Don’t really know whats going on, but I’ll take a new look tonight.
                        • E Offline
                          EhsanMomeni81 @EhsanMomeni81
                          @evroom I’m stuck :(
                          I tried the code above, and it works, the screen doesn’t turn off, but now I can’t see the desktop, it’s black when I minimize the MM-window, and I can’t connect to my MM via VNC which I could before and that’s how I changed in the first place.
                          • evroomE Offline
                            @EhsanMomeni81
                            Is here something useful ?
                            https://forum.magicmirror.builders/topic/1801/get-back-to-desktop
                            https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
                            I personally only use VNC to “look” at the screen remotely and never use the Pi for anything else then displaying MM.
                            Not interested in the desktop.
                            I always login to the Pi using a ssh client, like for example PuTTY, or on my Mac the iTerm2.
                            If you use Windows, then I would recommend PuTTY.
                            It is small and simple.
                            • E Offline
                              @evroom
                              Thanks ever so much. I googled and found something that worked. Now everything is running as it should. Still have problems with VNC, but I installed TeamViewer, but I’m going to give ssh a shot soon. Thank you again
                              • T Offline
                                TvE
                                So I have also been searching a lot for an answer to this question and been wondering why it have been so difficult to find a CLI based solution to this task.
                                I am using the “Raspberry Pi Imager” tool (on Window$) to prepare a USB stick (or SD card) and hereafter configure everything via SSH.
                                I know I could just use RDP or VNC to access and thus make this change via a GUI. But that’s to annoying, hence my need for a CLI based solution
                                Finally I found it in this thread (thank you @evroom !)
                                So this is just to help others with the same search that this [1] still works on the current latest RPI OS bullseye:
                                pi@magicmirror:~ $ lsb_release -a
                                Description:    Raspbian GNU/Linux 11 (bullseye)
                                Release:        11
                                Codename:       bullseye
                                Without this [1] change the screen goes black after 600s (10m)
                                Which can also be identified by the “timeout value” returned by this command.
                                pi@magicmirror:~ $ DISPLAY=:0 xset q
                                Screen Saver:
                                  prefer blanking:  yes    allow exposures:  yes
                                  timeout:  600    cycle:  600
                                After fixing it the value gets set to ‘0’
                                Right now I still see the screen after 16m (and counting…)
                                How to
                                The config change can be applied in many ways (vi, nano etc) but I prefer this method (as it can be copy-pasted or be made part of a config-script).
                                [1] I “just” add the three required lines to the config file:
                                printf "@xset -dpms\n@xset s off\n@xset s noblank" | sudo tee -a /etc/xdg/lxsession/LXDE-pi/autostart
                                PS.: Before I found this I also tried these solutions (which all failed to solve the problem
                                A. in /etc/lightdm/lightdm.conf:
                                xserver-command=X -s 0 dpms
                                B. Enable VNC as a workaround for mutter
                                I found (but did not try)
                                C. install xscreensaver and configure it to not kick in
                                HTH (my first post here :-)
                                  sdetweil @TvE
                                  @tve I wonder if my screensaver-off script would have done it.
                                  see
                                  down at the bottom of the page
                                  this is part of the install too, but the script is added in case u change your mind or need help. it checks 4 or 5 ways screensaver is done
                                  • T Offline
                                    TvE @sdetweil
                                    @sdetweil It most likely would!
                                    My one -file-only-edit solution have the added bonus that I know exactly what needed to be changed thus not relying on a 100+ line script.
                                    I see that you are so kind to log what the script is doing, so you don’t leave the user in the dark (pun intended :-) ) I like that design!
                                    I should have read your script earlier though (I read through the looong ticket regarding making the installer scripts external to MM2 and remember many of your posts!)
                                    Actually, while browsing the MM repo I also stumbled across the exact same solution
                                    https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disabling-the-screensaver
                                    Why either of those were never returned to my by google-foo I can only wonder about
