Solved why does my MM on pi crash every night?
@sdetweil so far, does not crash.
If I add Watchdog, it gets restarted.
I’ve made the timeouts really long. Still fails overnight -
Not sure, but worthy to check wifi autosleep of rpi, I think humbly.
@Sean thanks, will check.
@Sean
power mgmt was off for that wireless adapter…
the other two systems are on ethernet wire
i took out Watchdog, it caused restarts every night… the system ran fine overnight, without any issues…
so I think there is a problem with Watchdog itself…
watchdog has a problem… removing… have not crashed since increase swap space…
will close for now as I work on the watchdog socket problem
