    Unable to install dependencies - chromedriver.js
    8 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @jinhyuck
      @jinhyuck try my updated installer… will be part of next release
      see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      you will have to erase the MagicMirror folder
      from /home/pi
      rm -rf MagicMirror
        jinhyuck @sdetweil
        @sdetweil Thanks for the answering.
        I tried the new script you offer
        bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        Unfortunately, result is the same error. Am I understand you right?
          sdetweil @jinhyuck
          @jinhyuck can u show the ~/MagicMirrir/install.log (or email to me if not, same userid as here at gmail)
          try
          npm i -g npm
          then try the install again (remove MagicMirror folder)
            jinhyuck @sdetweil
            @sdetweil I’ve done this
            npm i -g npm
            but still same problem happens.
            And I couldn’t find the ‘install.log’ file.
            the link below is npm log file just in case this helps.
            https://drive.google.com/file/d/1J3IMZ6g4bhwmVW-gAH7b8vmJDG_u_vwn/view?usp=sharing
              @jinhyuck said in Unable to install dependencies - chromedriver.js:
              Error: getaddrinfo EAI_AGAIN github-production-release-asset-2e65be.s3.amazonaws.com github-production-release-asset-2e65be.s3.amazonaws.com:443
              there is some networking access problem from your system
              if you do
              cd ~/MagicMirror/node_modules/electron-chromedriver
              then
              node ./download-chromedriver.js
              you should see the same error
              are you working thru a VPN, or from a docker container? (where the same error has been reported before)
                jinhyuck @sdetweil
                @sdetweil Thanks, Sam.
                It was a kind of network issue.
                I used hotspot from my cellphone and I could done the installation.
                I have to find out why my LAN has that kind of problem.
                Anyway thanks a lot.
                  sdetweil @jinhyuck
                  @jinhyuck cool… glad you were able to continue
