    Unable to install dependencies - chromedriver.js
    8 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @jinhyuck
      @jinhyuck can u show the ~/MagicMirrir/install.log (or email to me if not, same userid as here at gmail)
      try
      npm i -g npm
      then try the install again (remove MagicMirror folder)
        jinhyuck @sdetweil
        @sdetweil I’ve done this
        npm i -g npm
        but still same problem happens.
        And I couldn’t find the ‘install.log’ file.
        the link below is npm log file just in case this helps.
        https://drive.google.com/file/d/1J3IMZ6g4bhwmVW-gAH7b8vmJDG_u_vwn/view?usp=sharing
          @jinhyuck said in Unable to install dependencies - chromedriver.js:
          Error: getaddrinfo EAI_AGAIN github-production-release-asset-2e65be.s3.amazonaws.com github-production-release-asset-2e65be.s3.amazonaws.com:443
          there is some networking access problem from your system
          if you do
          cd ~/MagicMirror/node_modules/electron-chromedriver
          then
          node ./download-chromedriver.js
          you should see the same error
          are you working thru a VPN, or from a docker container? (where the same error has been reported before)
            jinhyuck @sdetweil
            @sdetweil Thanks, Sam.
            It was a kind of network issue.
            I used hotspot from my cellphone and I could done the installation.
            I have to find out why my LAN has that kind of problem.
            Anyway thanks a lot.
              sdetweil @jinhyuck
              @jinhyuck cool… glad you were able to continue
