Solved Google calender no events shown
@sdetweil browser is fine. Also all my other internet dependant modules work ok. It is purely calender not showing events when the adress seems fine and all settings are set to allow
@mercuryskies please cut paste your calendar config. Change some of the coded numbers, but don’t change anything else. Use the code block to mark it
Select all, hit the </>
Hi there, below is my calendar config. Thanks again, Michael.
language: “en”,
timeFormat: 12,
units: “metric”,modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Family Calender", position: "bottom_left", config: { calendars: [ { symbol: "calendar", url: "https://calender.google.com/calender/ical/michael.lloyd%40live.com/public/basics.ics", } //url: "https://calender.google.com/calender/ical/michael.lloyd%40live.com/private-cf63bd901ffd72df081e7258123456789/basics.ics" } //url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" } ] }
i have commented out the private one as when i do not the file crashes
@mercuryskies right, cause the 1st one ends with ,} which closes the lists of calendars, and then next one has a } too…
the 1st one url doesn’t work for some reason, (in browser)
so the test is to take each url, and put it into a browser on the pi, it should download the ics file… if not, you have to fix THAT…
the pi does not logon as you… so it might work on windows -
so both of the google calendar links do not work in my pi browser, it just says site not available.
if i paste the last default webcal address it just takes me to a google search result. -
@mercuryskies i typed over the word calendar in the https://calendar.google.com and it gets urls not found, not address not found…
try that… seems some goofy character
the standard google calendar url works fine. it takes me to my calendar and i can see everything in my browser.
but when i try my private and public urs in the browser i get the site can not be reached.
i am so confused -
@mercuryskies i was confused as well, then started overtyping the url to find the problem… something in the word ‘calendar’ not right… type it over from the keyboard, not just cut/paste
@sdetweil I’m sorry to sound dumb but can you elaborate . Over typing ? Where are you putting the corrected url .
