    rpi3 freezes every few days .. need help
    18 Posts 4 Posters 5.0k Views 5 Watching
      sdetweil @nagaculun
      @nagaculun sounds like the swap space might need to be enlarged
      • N Offline
        nagaculun @sdetweil
        @sdetweil and how do I do that ?
          sdetweil @nagaculun
          @nagaculun now now… google is your friend
          see https://www.bitpi.co/2015/02/11/how-to-change-raspberry-pis-swapfile-size-on-rasbian/
          • FoziF Offline
            Fozi Project Sponsor
            @nagaculun Are you using MMM-GoogleTrafficMap? This module has a severe memory leak. Increasing swap memory will not help, as it just shifts the freeze to a later point in time. Other option is to setup a cron job that reboots regularly the RPi.
            S N 2 Replies Last reply Reply Quote 0
              sdetweil @Fozi
              @Fozi i have a fixed GoogleMapsTraffic module on my github.
              I submitted it, but it hasn’t been picked up…
              https://github.com/sdetweil/MMM-GoogleMapsTraffic
              • FoziF Offline
                Fozi Project Sponsor @sdetweil
                @sdetweil thanks for the heads up!
                Didn’t know you fixed it. I’ll give it a try for my next MM version, I’m currenttly planning.
                • N Offline
                  nagaculun @Fozi
                  @Fozi I dont have the MMM-GoogleTrafficMap. Even just the default clock module has the issue.
                  I setup a cron to reboot every day at 6am; and it happens as well.
                  • N Offline
                    nagaculun @sdetweil
                    Just modify accordingly. Now wait and see. Thanks.
                    • N Offline
                      nagaculun
                      It still freezes even I made the modification.
                      S FoziF 2 Replies Last reply Reply Quote 0
                        sdetweil @nagaculun
                        @nagaculun bummer…
