    Can someone do the coding for me? $$
    8 Posts 3 Posters 1.5k Views 3 Watching
      sdetweil @Hellonoonan
      @Hellonoonan I am willing to discuss. send me a better description. My email is my user ID here on Gmail.
      We can also chat on discord.
      • H Offline
        Hellonoonan @BD0G
        @BD0G Ill give that a shot. Thanks for the suggestion!
        • H Offline
          Hellonoonan
          /* Magic Mirror Module: calendar_monthly
          • v1.0 - June 2016
          • By Ashley M. Kirchner kirash4@gmail.com
          • Beer Licensed (meaning, if you like this module, feel free to have a beer on me, or send me one.)
          Module.register(“calendar_monthly”, {
          // Module defaultsca
          defaults: {
          	debugging:		false,
          	initialLoadDelay:	0,		// How many seconds to wait on a fresh start up.
          						// This is to prevent collision with all other modules also
          						// loading all at the same time. This only happens once,
          						// when the mirror first starts up.
          	fadeSpeed:		2,		// How fast (in seconds) to fade out and in during a midnight refresh
          	showHeader:		true,		// Show the month and year at the top of the calendar
          	cssStyle:		"block",	// which CSS style to use, 'clear', 'block', 'slate', or 'custom'
          	updateDelay:		5,		// How many seconds after midnight before a refresh
          						// This is to prevent collision with other modules refreshing
          						// at the same time.
          // Required styles
          getStyles: function() {
          	return [this.data.path + "/css/mcal.css", this.getThemeCss()];
          getThemeCss: function() {
          	return this.data.path + "/css/themes/" + this.config.cssStyle + ".css";
          // Required scripts
          getScripts: function() {
          	return ["moment.js"];
          // Override start method
          start: function() {
          	Log.log("Starting module: " + this.name);
          	// Set locale
          	moment.locale(config.language);
          	// Calculate next midnight and add updateDelay
          	var now = moment();
          	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
          	this.loaded = false;
          	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
          // Override dom generator
          getDom: function() {
          	if ((moment() > this.midnight) || (!this.loaded)) {
          		var month = moment().month();
          		var year = moment().year();
          		var monthName = moment().format("MMMM");
          		var monthLength = moment().daysInMonth();
          		// Find first day of the month, LOCALE aware
          		var startingDay = moment().date(1).weekday();
          		var wrapper = document.createElement("table");
          		wrapper.className = 'large';
          		wrapper.id = 'calendar-table';
          		// Create THEAD section with month name and 4-digit year
          		var header = document.createElement("tHead");
          		var headerTR = document.createElement("tr");
          		// We only fill in the THEAD section if the .showHeader config is set to true
          		if (this.config.showHeader) {
          			var headerTH = document.createElement("th");
          			headerTH.colSpan = "7";
          			headerTH.scope = "col";
          			headerTH.id = "calendar-th";
          			var headerMonthSpan = document.createElement("span");
          			headerMonthSpan.id = "monthName";
          			headerMonthSpan.innerHTML = monthName;
          			var headerYearSpan = document.createElement("span");
          			headerYearSpan.id = "yearDigits";
          			headerYearSpan.innerHTML = year;
          			// Add space between the two elements
          			// This can be used later with the :before or :after options in the CSS
          			var headerSpace = document.createTextNode(" ");
          			headerTH.appendChild(headerMonthSpan);
          			headerTH.appendChild(headerSpace);
          			headerTH.appendChild(headerYearSpan);
          			headerTR.appendChild(headerTH);
          		header.appendChild(headerTR);
          		wrapper.appendChild(header);
          		// Create TFOOT section -- currently used for debugging only
          		var footer = document.createElement('tFoot');
          		var footerTR = document.createElement("tr");
          		footerTR.id = "calendar-tf";
          		var footerTD = document.createElement("td");
          		footerTD.colSpan ="7";
          		footerTD.className = "footer";
          		if (this.config.debugging) {
          			footerTD.innerHTML = "Calendar currently in DEBUG mode!<br />Please see console log.";
          		} else {
          			footerTD.innerHTML = "&nbsp;";
          		footerTR.appendChild(footerTD);
          		footer.appendChild(footerTR);
          		wrapper.appendChild(footer);
          		// Create TBODY section with day names
          		var bodyContent = document.createElement("tBody");
          		var bodyTR = document.createElement("tr");
          		bodyTR.id = "calendar-header";
          		for (var i = 0; i <= 6; i++ ){
          			var bodyTD = document.createElement("td");
          			bodyTD.className = "calendar-header-day";
          			bodyTD.innerHTML = moment().weekday(i).format("ddd");
          			bodyTR.appendChild(bodyTD);
          		bodyContent.appendChild(bodyTR);
          		wrapper.appendChild(bodyContent);
          		// Create TBODY section with the monthly calendar
          		bodyTR.className = "weekRow";
          		// Fill in the days
          		var day = 1;
          		var nextMonth = 1;
          		// Loop for amount of weeks (as rows)
          		for (var i = 0; i < 9; i++) {
          			// Loop for each weekday (as individual cells)
          			for (var j = 0; j <= 6; j++) {
          				bodyTD.className = "calendar-day";
          				var squareDiv = document.createElement("div");
          				squareDiv.className = "square-box";
          				var squareContent = document.createElement("div");
          				squareContent.className = "square-content";
          				var squareContentInner = document.createElement("div");
          				var innerSpan = document.createElement("span");
          				if (j < startingDay && i == 0) {
          					// First row, fill in empty slots
          					innerSpan.className = "monthPrev";
          					innerSpan.innerHTML = moment().subtract(1, 'months').endOf('month').subtract((startingDay - 1) - j, 'days').date();
          				} else if (day <= monthLength && (i > 0 || j >= startingDay)) {
          					if (day == moment().date()) {
          						innerSpan.id = "day" + day;
          						innerSpan.className = "today";
          					} else {
          						innerSpan.className = "daily";
          					innerSpan.innerHTML = day;
          					day++;
          				} else if (day > monthLength && i > 0) {
          					// Last row, fill in empty space
          					innerSpan.className = "monthNext";
          					innerSpan.innerHTML = moment([year, month, monthLength]).add(nextMonth, 'days').date();
          					nextMonth++;
          				squareContentInner.appendChild(innerSpan);
          				squareContent.appendChild(squareContentInner);
          				squareDiv.appendChild(squareContent);
          				bodyTD.appendChild(squareDiv);
          			// Don't need any more rows if we've run out of days
          			if (day > monthLength) {
          				break;
          			} else {
          		this.loaded = true;
          		return wrapper;
          scheduleUpdate: function(delay) {
          		Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
          		Log.log("CALENDAR_MONTHLY IS IN DEBUG MODE!");
          		Log.log("Remove 'debugging' option from config/config.js to disable.");
          		Log.log("             Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
          		Log.log("scheduleUpdate() delay set at: " + delay);
          	if (typeof delay !== "undefined" && delay >= 0) {
          		nextReload = delay;
          	if (delay > 0) {
          		// Calculate the time DIFFERENCE to that next reload!
          		nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
          			var hours = Math.floor(nextReload.asHours());
          			var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
          			var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
          			Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
          			Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
          			Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
          	var self = this;
          	setTimeout(function() {
          		self.reloadDom();
          	}, nextReload);
          reloadDom: function() {
          		Log.log("          Calling reloadDom()!");
          	var now = moment();
          	if (now > this.midnight) {
          		this.updateDom(this.config.fadeSpeed * 1000);
          	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
          	this.scheduleUpdate(nextRefresh);
          • H Offline
            Hellonoonan
            Module.register(“OfficeHours”,{
            // Default module config.
            defaults: {
            	text: ""
            getTemplate: function () {
            	return "OfficeHours.njk"
            getTemplateData: function () {
            	return this.config
            • H Offline
              Hellonoonan
              Module.register(“MMM-fbPageCounter”,{
              // Module config defaults.
              defaults: {
              	access_token: "",
              	page_id: "",
              	refresh_interval_sec: 10, //minimum 30. If your daily visitors of page are under 10, use 30 as this value.
              	return ["MMM-fbPageCounter.css", "flipcounter.css"]
              	return [
              		this.file("js/flipcounter.js")
              start: function() {
              	this.fb = {}
              	this.myCounter = null
              	this.apiUrl = "https://graph.facebook.com/v2.10/"
              		+ this.config.page_id
              		+ "/?fields=fan_count,name&access_token="
              		+ this.config.access_token
              	if (this.config.refresh_interval_sec < 10) {
              		this.config.refresh_interval_sec = 10
              	var wrapper = document.createElement("div")
              	wrapper.className = "fb_board"
              	var myCounter = document.createElement("ul")
              	myCounter.className = "flip-counter " + this.config.size
              	myCounter.id = "myCounter_" + this.data.identifier
              	wrapper.appendChild(myCounter)
              	return wrapper
              notificationReceived:function(noti, payload, sender) {
              	if (noti == "DOM_OBJECTS_CREATED") {
              		this.myCounter = new flipCounter("myCounter_" + this.data.identifier, {value: 0, pace:100, auto: false})
              		this.updateCounter()
              		var self = this
              		setInterval(function() {
              			self.updateCounter()
              		}, this.config.refresh_interval_sec * 1000)
              updateCounter: function() {
              	var self = this
              	this.loadJSON(this.apiUrl,
              		function (result) {
              			self.fb = result
              		function (err) {
              			console.log("[FBKCNT] ERROR!", err)
              	if (this.fb.fan_count) {
              		this.myCounter.incrementTo(this.fb.fan_count, 100, 20)
              loadJSON: function(path, success, error) {
              	var xhr = new XMLHttpRequest()
              	xhr.onreadystatechange = function() {
              		if (xhr.readyState === XMLHttpRequest.DONE) {
              			if (xhr.status === 200) {
              				if (success) {
              					success(JSON.parse(xhr.responseText))
              			} else {
              				if (error) {
              					error(xhr)
              	xhr.open("GET", path, true)
              	xhr.send()
              • H Offline
                Hellonoonan
                • Magic Mirror *
                • Custom CSS *
                • By Michael Teeuw http://michaelteeuw.nl *
                • MIT Licensed. *
                • Add any custom CSS below. *
                • Changes to this files will be ignored by GIT. *
                body {
                #yearDigits {
                color: #fff;
                font-weight: normal;
                #monthName {
                #monthName:after {
                content: " •";
                color: #80ff00;
                font-weight: bold;
                .monthPrev {
                color: #333333;
                .monthNext {
                color: #333333;
                .square-box {
                position: relative;
                width: 50%;
                overflow: hidden;
                margin: 0px auto;
                .square-box:before {
                content: “”;
                display: block;
                padding-top: 20%;
                .square-content {
                top: 0;
                left: 0;
                bottom: 0;
                right: 0;
                .square-content .today {
                border: 1px solid #80ff00;
                color: #80ff00;
                .square-content div {
                display: table;
                width: 100%;
                height: 100%;
                .square-content span {
                display: table-cell;
                text-align: center;
                vertical-align: middle;
                .OfficeHours {
                text-align: left;
                color: #fff;
                font-size: 50px;
                header {
                text-transform: none;
                font-size: 65px;
                font-family: “Roboto Condensed”, Arial, Helvetica, sans-serif;
                font-weight: 600;
                border-bottom: 2px solid #0084ff;
                line-height: 55px;
                padding-bottom: 5px;
                margin-bottom: 10px;
                color: #fff;
