    Initial Setup Q's and Some Doc Feedback
    21 Posts 3 Posters 10.7k Views 3 Watching
      sdetweil @ember1205
      @ember1205 the installer you used is WAY downlevel… I have created a new one that will be released on the next update
      see
      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      if u want to run it now, then rename the MagicMirror folder out of the way and use the command
      provided in the linked topic
      (note there is also a new script for updates, and a new script to fix PM2 should you change your mind or have trouble)… all added to the next release
      it solves most of the issues you mentioned…
      except for warnings… which were added to the npm install processes, and we have no control.
      they ARE Warnings… so unless u intend your mirror to be accessed from over the internet, i think most are not worth chasing down… (the updates to fix the ‘vulnerabilities’ MAY/have/will at some time, mess things up and the mirror won’t run. (due to somebody elses code being broken)…
      notice on the kms driver the F letter
      dtoverlay=vc4-fkms-v3d
      means use the FAKE driver, not real… it MAY work, for portrait rotated displays it seems to have problems (search the forum)
      E 1 Reply Last reply Reply Quote 1
        @ember1205 said in Initial Setup Q's and Some Doc Feedback:
        Backing up just a bit, there appears to be no guidance in the install doc as to whether I should choose to allow the installer to set MM to autostart and/or whether I should disable the screensaver during the install process. I chose “N” and “Y” respectively.
        that is all really choice on your installation and and usage planning…
        i don’t want to touch the mirror… if it reboots cause of power outage, etc, I want it to logon, and start mirror, and never screen lock…
        so, set OS to auto logon (manual step)
        use pm2 to autostart
        and turn off screensaver
        • E Offline
          ember1205 @sdetweil
          Thanks… Good updates. I will definitely look through your updated installer.
          With regard to the warnings - I understand what you’re saying, but my concerns were driven more by the warnings that said “this might not even work.” I realize that they may be very specific to certain aspects, but given that isn’t indicated specifically, it raised up my alert level.
          On the fake versus real driver piece, I did notice the “f” to indicate the fake driver. With zero experience with this piece, and having no background that there IS a fake driver or that it’s now default, my eyes told me that the name for the fake driver was actually the name for the real one at first [two] glance[s]. It wasn’t until I reached the latter part talking about the fake driver that I realized it was a different name and changed it.
          I’m not using portrait mode as I want this to be a “Magic Photo Frame” and display pictures (many of which are in landscape format), so it seems that I might be able to use either.
          • E Offline
            ember1205 @sdetweil
            @sdetweil said in Initial Setup Q's and Some Doc Feedback:
            Yes. Those were all done. But, the screensaver disable was done during the install and it appears to not have modified the same files as the manual changes show.
            S D 2 Replies Last reply Reply Quote 0
              sdetweil @ember1205
              @ember1205 i didn’t set the OpenGL driver… not worth the hassle. the driver is REALLY useful for algorithmic objects, rotating in 3d… nothing we do on the mirror
                sdetweil @ember1205
                hm… i didn’t update the doc for manual install for my new installer… there are just too many places with different solutions…
                I embodied all that I know about and generalized to attempt to cover more as time goes on.
                  dsegel @ember1205
                  @ember1205 There are three locations where the screensaver might be starting from, and only one of them is actually run (I believe the first found in this order):
                  /home/pi/.config/lxsession/LXDE-pi/autostart
                  /etc/xdg/lxsession/LXDE-pi/autostart
                  /etc/xdg/lxsession/LXDE/autostart
                  Raspbian recently changed to not having the first one, so the second is now the preferred method.
                  S E 2 Replies Last reply Reply Quote 0
                    sdetweil @dsegel
                    @dsegel thx… already in the updated installer and the screensaver fixer scripts
                    • E Offline
                      ember1205 @dsegel
                      @dsegel said in Initial Setup Q's and Some Doc Feedback:
                      So… None of that works. The ONLY way I could get the screensaver to shut off was to do:
                      sudo apt install xscreensaver
                      And then run the Screensaver Preferences setup and set it to disabled. Anything else I tried ultimately allowed the screen to go blank (black) after about 15 minutes.
                        sdetweil @ember1205
                        @ember1205 thanks… I wished we had worked on it a little more…
                        i have a script that just does setting screensaver off…
                        haven’t had it fail on anything in a while… just tested Zorin OS. it worked properly
                        • E Offline
                          ember1205 @sdetweil
                          I’m going to try a fresh build and will use your script to see how it fares on this exact version of Raspbian…
                            sdetweil @ember1205
                            @ember1205 k… let me know
                            • E Offline
                              ember1205
                              I have started my new build from scratch and used your install script.
                              There are a number of ‘vulnerability’ warnings that show, and I’m curious if I should actually try and repair them with the suggested npm commands or not.
                              Also, so far, the screensaver does seem to be disabled, but I haven’t yet jumped into the MM configuration to put in place the same modules I had been using on the other setup as of yet.
                                sdetweil @ember1205
                                @ember1205 yes, the vulnerability warnings are troublesome… they usually cannot be all resolved, and some modules fixes force changes that break applications using them. i prefer NOT to attempt to resolve the problems…
                                screensaver…
                                can u show/send me the ~/install.log
                                my email is the same userid as here on gmail
                                • E Offline
                                  ember1205
                                  install starting  - Fri Dec 20 08:32:44 EST 2019
                                  installing on armv7l processor system
                                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                  Updating packages ...
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Get:3 http://raspbian.raspberrypi.org/raspbian buste
                                  r/main armhf Packages [13.0 MB] Fetched 13.0 MB in 15s (852 kB/s) Reading package lists...
                                  apt-get update  completed ok
                                  apt upgrade result =rc=0 Reading package lists...
                                  Building dependency tree...
                                  Reading state information...
                                  Calculating upgrade...
                                  The following package was automatically installed and is no longer required:
                                    point-rpi
                                  Use 'sudo apt autoremove' to remove it.
                                  Installing helper tools ...
                                  Minimum Node version: v10.1.0
                                  Installed Node version: v10.15.2
                                  No Node.js upgrade necessary.
                                  Minimum npm version: V6.0.0
                                  Installed npm version: V5.8.0
                                  npm should be upgraded.
                                  Installing npm ...
                                  npm is already the newest version (5.8.0+ds6-4).
                                  npm set to manually installed.
                                    point-rpi
                                  upgrading npm to latest
                                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                  + npm@6.13.4
                                  added 430 packages from 854 contributors in 42.042s
                                  npm installation Done! version=V6.13.4
                                  Cloning MagicMirror ...
                                  Cloning MagicMirror Done!
                                  Installing dependencies ...
                                  Dependencies installation Done!
                                  setting up initial config.js
                                  Check plymouth installation ...
                                  Splashscreen: Checking themes directory.
                                  Splashscreen: Create theme directory if not exists.
                                  Splashscreen: Changed theme to MagicMirror successfully.
                                  install and setup pm2
                                  pm2 not installed, installing
                                  pm2 install result /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2 /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev /usr/local/bin/pm2-docker -> /usr/lo
                                  cal/lib/node_modules/pm2/bin/pm2-docker /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_
                                  modules/pm2/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arc
                                  h":"arm"}) + pm2@4.2.1 added 207 packages from 202 contributors in 38.506s
                                  get the pm2 platform specific startup command
                                  startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                  __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                                   _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                                    _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                                     _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                                      _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                                       _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                                        _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                                         _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                          _\///______________\///______________\///__\///////////////__
                                                            Runtime Edition
                                          PM2 is a Production Process Manager for Node.js applications
                                                       with a built-in Load Balancer.
                                                  Start and Daemonize any application:
                                                  $ pm2 start app.js
                                                  Load Balance 4 instances of api.js:
                                                  $ pm2 start api.js -i 4
                                                  Monitor in production:
                                                  $ pm2 monitor
                                                  Make pm2 auto-boot at server restart:
                                                  $ pm2 startup
                                                  To go further checkout:
                                                  http://pm2.io/
                                  [PM2] Init System found: systemd
                                  Platform systemd
                                  Template
                                  [Unit]
                                  Description=PM2 process manager
                                  Documentation=https://pm2.keymetrics.io/
                                  After=network.target
                                  [Service]
                                  Type=forking
                                  User=pi
                                  LimitNOFILE=infinity
                                  LimitNPROC=infinity
                                  LimitCORE=infinity
                                  Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                                  Environment=PM2_HOME=/home/pi/.pm2
                                  PIDFile=/home/pi/.pm2/pm2.pid
                                  Restart=on-failure
                                  ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
                                  ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
                                  ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
                                  [Install]
                                  WantedBy=multi-user.target
                                  Target path
                                  /etc/systemd/system/pm2-pi.service
                                  Command list
                                  [ 'systemctl enable pm2-pi' ]
                                  [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                                  [PM2] Making script booting at startup...
                                  [PM2] [-] Executing: systemctl enable pm2-pi...
                                  [PM2] [v] Command successfully executed.
                                  [PM2] Freeze a process list on reboot via:
                                  $ pm2 save
                                  [PM2] Remove init script via:
                                  $ pm2 unstartup systemd
                                  pm2 startup command done
                                  configure the pm2 config file for MagicMirror
                                  start MagicMirror via pm2 now
                                  save MagicMirror pm2 config now
                                  disable screensaver via lxsession
                                  We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                                  install completed - Fri Dec 20 08:59:08 EST 2019
                                  • E Offline
                                    ember1205
                                    Some additional notes:
                                    • The screensaver settings appear to have been set in the /etc/xdg/lxsession/LXDE-pi/autostart file
                                    • No settings have been adjusted in /etc/lightdm/lightdm.conf
                                    • The mouse pointer auto remove configuration has not been completed, but there appears to be no issue with the pointer remaining on the screen once Electron loads
                                    • There was no change made to the system to disable power saving on the WLAN interface - as a result, the interface seemingly “could” go into powersave mode and affect network connectivity (I have not yet experienced an issue with this)
                                      sdetweil @ember1205
                                      @ember1205 cool. great feedback.
                                      i dont have lightdm changed on my buster system.
                                      according to this, its still lxde
                                      https://www.raspberrypi.org/forums/viewtopic.php?t=249837
                                      correct, there is no mod for mouse pointer.
                                      can also be done in css
                                      cursor: none;
                                      also no setting change for wlan power
                                      • E Offline
                                        ember1205 @sdetweil
                                        -Should- the WLAN power setting be changed? It would seem that this would be a wise approach to ensure it doesn’t go into powersave mode.
                                          sdetweil @ember1205
                                          @ember1205 i don’t know the answer… depends on how much its used I would guess…
                                          I don’t know what the power save rules are
                                          • E Offline
                                            ember1205 @sdetweil
                                            I believe the rules are less important than the consequences. I don’t believe WLAN has a good track record overall of waking up from a sleep state. And, regardless of how much it’s directly used, you can bet that the one time it won’t work is when you try using the remote control module to power it down. :)
