    Initial Setup Q's and Some Doc Feedback
    21 Posts 3 Posters 9.3k Views 3 Watching
      @ember1205 said in Initial Setup Q's and Some Doc Feedback:
      Backing up just a bit, there appears to be no guidance in the install doc as to whether I should choose to allow the installer to set MM to autostart and/or whether I should disable the screensaver during the install process. I chose “N” and “Y” respectively.
      that is all really choice on your installation and and usage planning…
      i don’t want to touch the mirror… if it reboots cause of power outage, etc, I want it to logon, and start mirror, and never screen lock…
      so, set OS to auto logon (manual step)
      use pm2 to autostart
      and turn off screensaver
      • E Offline
        ember1205 @sdetweil
        Thanks… Good updates. I will definitely look through your updated installer.
        With regard to the warnings - I understand what you’re saying, but my concerns were driven more by the warnings that said “this might not even work.” I realize that they may be very specific to certain aspects, but given that isn’t indicated specifically, it raised up my alert level.
        On the fake versus real driver piece, I did notice the “f” to indicate the fake driver. With zero experience with this piece, and having no background that there IS a fake driver or that it’s now default, my eyes told me that the name for the fake driver was actually the name for the real one at first [two] glance[s]. It wasn’t until I reached the latter part talking about the fake driver that I realized it was a different name and changed it.
        I’m not using portrait mode as I want this to be a “Magic Photo Frame” and display pictures (many of which are in landscape format), so it seems that I might be able to use either.
        • E Offline
          ember1205 @sdetweil
          @sdetweil said in Initial Setup Q's and Some Doc Feedback:
          Yes. Those were all done. But, the screensaver disable was done during the install and it appears to not have modified the same files as the manual changes show.
          S D 2 Replies Last reply Reply Quote 0
            sdetweil @ember1205
            @ember1205 i didn’t set the OpenGL driver… not worth the hassle. the driver is REALLY useful for algorithmic objects, rotating in 3d… nothing we do on the mirror
              sdetweil @ember1205
              hm… i didn’t update the doc for manual install for my new installer… there are just too many places with different solutions…
              I embodied all that I know about and generalized to attempt to cover more as time goes on.
                dsegel @ember1205
                @ember1205 There are three locations where the screensaver might be starting from, and only one of them is actually run (I believe the first found in this order):
                /home/pi/.config/lxsession/LXDE-pi/autostart
                /etc/xdg/lxsession/LXDE-pi/autostart
                /etc/xdg/lxsession/LXDE/autostart
                Raspbian recently changed to not having the first one, so the second is now the preferred method.
                S E 2 Replies Last reply Reply Quote 0
                  sdetweil @dsegel
                  @dsegel thx… already in the updated installer and the screensaver fixer scripts
                  • E Offline
                    ember1205 @dsegel
                    @dsegel said in Initial Setup Q's and Some Doc Feedback:
                    So… None of that works. The ONLY way I could get the screensaver to shut off was to do:
                    sudo apt install xscreensaver
                    And then run the Screensaver Preferences setup and set it to disabled. Anything else I tried ultimately allowed the screen to go blank (black) after about 15 minutes.
                      sdetweil @ember1205
                      @ember1205 thanks… I wished we had worked on it a little more…
                      i have a script that just does setting screensaver off…
                      haven’t had it fail on anything in a while… just tested Zorin OS. it worked properly
                      • E Offline
                        ember1205 @sdetweil
                        I’m going to try a fresh build and will use your script to see how it fares on this exact version of Raspbian…
