Unsolved Issues with a special Google calendar
@Clubjack all the dates are in the past
Arena You Sure?
There are dates from 06.01. till 02.02.
In my Android-App i can see the dates. But not in MM. -
I should have searched for 2020… sorry, yes I see those…
is this cal listed first?
there is a total number of entries… so it will truncate
and there is also how far forward is shownmaxItems: 100, beforeDays: 60, afterDays: 365,
which view are your using?
Okay.
I tryed it using this calendar alone.
Without other calendars. But nothing is shown.
I use:
Mode: week
Slotcount: 5
Maxitems: 1000
Hideoverflow: falseHow i say… The Main Google calendars work fine with the same settings.
@Clubjack ok, i put this in the default calendar and it worked…
so, that means the ext2 is having a problem…
when did u clone ext2? there was a problem when the api returned the cal data in zipped format…
he fixed that last week I think…so, if u have not updated recently do
cd ~/MagicMirror/modules/MMM-CalendarExt2 git pull
and restart the mirror app
@sdetweil thank You
Git pull says: Already up to date -
@Clubjack bummer
I would open an issue on the github site for the module
But what could be the problem,when all the other calendars worked? -
@Clubjack well, it looks like the code doesn’t parse it correctly… I don’t know… not my code.
I am not in a position to debug it currently -
@sdetweil ok. Thank You very much for your help. Great.
