Unsolved Calendar/familyplan
@Clubjack
ideally, I considered that kind of view once, but havent.
if using 1920px for full screen(usually default mm is smaller than that due to its default css),
for 30 days, each cell could obtain around 60px height. Header and some gaps would take area remains. 60px seems enough? maybe. but even 2 or max 3 events per cell(at most). And this view will cover literally entire real estate of MM. definitely not pretty. that’s why i havent. -
@Sean
A calendar, like the picture, only need to Show one or two events per cell.
Than i would have one column for every calendar.
I don’t need a Header for every day. Only one Header at the top with the Namens of the calendar.
And left side the days from top to bottom. -
@Clubjack
Yes, I’ll consider again. Maybe it could be new plugin of CALEXT series like Minimonth or Timeline.
Frankly not difficult at all. All the reason was, just worry about inefficient space used I thought. However, at least you won’t mind about it.
Unfortunately, at this moment, I have broken my ankle last week so being in Hospital. After return home, I’ll consider. Maybe releasing new AMK2 version then this would be next work. I hope this could be released until mid Jan. -
@Sean First of all, thank you for your feedback and of course I wish you a speedy recovery as soon as possible.
A plugin would be great.Since I am still in the initial phase, I will use a different view for now.
@Sean said in Calendar/familyplan:
Unfortunately, at this moment, I have broken my ankle last week so being in Hospital. After return home, I’ll consider. Maybe releasing new AMK2 version then this would be next work. I hope this could be released until mid Jan.I wish you a quick and good recovery Sean. I personally would be very happy about the plugin. Thanks in advance for that.
