    Calendar/familyplan
    15 Posts 4 Posters 4.1k Views 4 Watching
      sdetweil @Clubjack
      @Clubjack it would have to be daily, slot count= will be a problem maybe… set to 31, don’t know what happens in feb!
      u can force your system date to any day to see what it looks like
        Clubjack @sdetweil
        Thanks, for the first that could be the right way.
        Do you know the right command for the custom.css to set the font size of the headers and the event lines separately?
          sdetweil @Clubjack
          @Clubjack there are a ton of little pieces that u can set css for
          See
          https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
            Clubjack @sdetweil
            First of all, I’m sorry that I have to ask such stupid questions. Sometimes, as a beginner, you simply lack the overview. I have now tried your proposal. Unfortunately, every day has a headline. It would be great if the days had no headline, but the days were to the left of it. Like in the picture. Do you think that is feasible?
              sdetweil @Clubjack
              @Clubjack you will have to use the cash to NOT display the elements u want hidden
              display:none;
              For each element there is
              title, subTitle, and altTitle.
                Clubjack @sdetweil
                OK. That sounds good. I will try it.
                An idea to get an row at the left side with the days?
                  Clubjack
                  If someone would like to create such a module or still have tips for settings for existing modules, I would be very happy.
                    [[global:former-user]] @Clubjack
                    @Clubjack
                    ideally, I considered that kind of view once, but havent.
                    if using 1920px for full screen(usually default mm is smaller than that due to its default css),
                    for 30 days, each cell could obtain around 60px height. Header and some gaps would take area remains. 60px seems enough? maybe. but even 2 or max 3 events per cell(at most). And this view will cover literally entire real estate of MM. definitely not pretty. that’s why i havent.
                      Clubjack @Guest
                      @Sean
                      A calendar, like the picture, only need to Show one or two events per cell.
                      Than i would have one column for every calendar.
                      I don’t need a Header for every day. Only one Header at the top with the Namens of the calendar.
                      And left side the days from top to bottom.
                        @Clubjack
                        Yes, I’ll consider again. Maybe it could be new plugin of CALEXT series like Minimonth or Timeline.
                        Frankly not difficult at all. All the reason was, just worry about inefficient space used I thought. However, at least you won’t mind about it.
                        Unfortunately, at this moment, I have broken my ankle last week so being in Hospital. After return home, I’ll consider. Maybe releasing new AMK2 version then this would be next work. I hope this could be released until mid Jan.
                        C LordyL 2 Replies Last reply Reply Quote 0
                          Clubjack @Guest
                          @Sean First of all, thank you for your feedback and of course I wish you a speedy recovery as soon as possible.
                          A plugin would be great.
                          Since I am still in the initial phase, I will use a different view for now.
                          • LordyL Offline
                            Lordy @Guest
                            @Sean said in Calendar/familyplan:
                            I wish you a quick and good recovery Sean. I personally would be very happy about the plugin. Thanks in advance for that.
