    2.9 to 2.10 update error using lubuntu 18.04
    4 Posts 2 Posters 1.1k Views 2 Watching
    • F
      fatrgr
      Tried using update script, didn’t work.
      Tried using manual update using git pull, didn’t work.
      Error:
      minime@mini:~$ cd MagicMirror
      minime@mini:~/MagicMirror$ npm start
      magicmirror@2.10.0 start /home/minime/MagicMirror
      ./run-start.sh
      App threw an error during load
      Error: Cannot find module ‘module-alias/register’
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/minime/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/minime/MagicMirror/js/app.js:15:1)
      at Object. (/home/minime/MagicMirror/js/app.js:283:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Tried posting log, too long.
        sdetweil @fatrgr
        @fatrgr how did you do the update?
        git pull??
        you also need to do
        npm install
        from the announcement
        https://forum.magicmirror.builders/topic/11899/v2-10-0
        ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install
        • F
          fatrgr @sdetweil
          @sdetweil Thanks, I missed the announcement, and didn’t show in my searches. npm install worked. Will check for announcements next time. Thanks for the hard work!!
            sdetweil @fatrgr
            @fatrgr in general there is a planned new release every 90 days
