Solved MMM-Screencast erro
I opened issue in the module github repo
https://github.com/aserramonner/MMM-HASS/issues/14 -
You are great!
In the meantime, I tried another module, MMM-homeassistant-sensors.
It carries the MM. However I get this error msg. and no other module loads … gets msg from “loading”
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh [19:50:41.053] [LOG] Starting MagicMirror: v2.10.0 [19:50:41.091] [LOG] Loading config ... [19:50:41.111] [LOG] Loading module helpers ... [19:50:41.119] [LOG] No helper found for module: alert. [19:50:41.315] [LOG] Initializing new module helper ... [19:50:41.319] [LOG] Module helper loaded: updatenotification [19:50:41.321] [LOG] No helper found for module: clock. [19:50:42.483] [LOG] Initializing new module helper ... [19:50:42.485] [LOG] Module helper loaded: MMM-Screencast [19:50:43.894] [LOG] Initializing new module helper ... [19:50:43.896] [LOG] Module helper loaded: calendar [19:50:43.898] [LOG] No helper found for module: compliments. [19:50:45.187] [LOG] Initializing new module helper ... [19:50:45.190] [LOG] Module helper loaded: MMM-DarkSkyForecast [19:50:45.320] [LOG] Initializing new module helper ... [19:50:45.322] [LOG] Module helper loaded: newsfeed [19:50:45.330] [LOG] Initializing new module helper ... [19:50:45.332] [LOG] Module helper loaded: MMM-homeassistant-sensors [19:50:45.333] [LOG] All module helpers loaded. [19:50:45.342] [LOG] Starting server on port 8080 ... [19:50:45.441] [LOG] Server started ... [19:50:45.444] [LOG] Connecting socket for: updatenotification [19:50:45.448] [LOG] Connecting socket for: MMM-Screencast [19:50:45.452] [LOG] Connecting socket for: calendar [19:50:45.454] [LOG] Starting node helper for: calendar [19:50:45.457] [LOG] Connecting socket for: MMM-DarkSkyForecast [19:50:45.459] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast] [19:50:45.462] [LOG] Connecting socket for: newsfeed [19:50:45.465] [LOG] Starting module: newsfeed [19:50:45.528] [LOG] Connecting socket for: MMM-homeassistant-sensors [19:50:45.533] [LOG] Sockets connected & modules started ... [19:50:45.538] [LOG] Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minute --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version= events.js:174 throw er; // Unhandled 'error' event ^ Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed at doWrite (_stream_writable.js:411:19) at writeOrBuffer (_stream_writable.js:399:5) at Socket.Writable.write (_stream_writable.js:299:11) at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46) at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10) at process.emit (events.js:198:13) at process._fatalException (internal/bootstrap/node.js:497:27) ^C pi@raspberrypi:~/MagicMirror $
@sdetweil said in MMM-Screencast erro:
I’m getting the same “Unhandled ‘error’”-error. However, I’m not using this module at all.
@jorgnyg well then it’s a problem in another module
@iorifly said in MMM-Screencast erro:
I installed this module and am running split mode… I don’t see any errors, but I don’t have an HA system talk to…
I get the header on the page, that says the module started
This command worked. now stop underscore error.
However I have the following error.
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh [21:04:03.127] [LOG] Starting MagicMirror: v2.10.0 [21:04:03.163] [LOG] Loading config ... [21:04:03.185] [LOG] Loading module helpers ... [21:04:03.191] [LOG] No helper found for module: alert. [21:04:03.401] [LOG] Initializing new module helper ... [21:04:03.405] [LOG] Module helper loaded: updatenotification [21:04:03.408] [LOG] No helper found for module: clock. [21:04:04.630] [LOG] Initializing new module helper ... [21:04:04.633] [LOG] Module helper loaded: MMM-Screencast [21:04:06.010] [LOG] Initializing new module helper ... [21:04:06.013] [LOG] Module helper loaded: calendar [21:04:06.016] [LOG] No helper found for module: compliments. [21:04:07.345] [LOG] Initializing new module helper ... [21:04:07.347] [LOG] Module helper loaded: MMM-DarkSkyForecast [21:04:07.457] [LOG] Initializing new module helper ... [21:04:07.460] [LOG] Module helper loaded: newsfeed [21:04:07.548] [LOG] Initializing new module helper ... [21:04:07.553] [LOG] Module helper loaded: MMM-HASS [21:04:07.557] [LOG] All module helpers loaded. [21:04:07.563] [LOG] Starting server on port 8080 ... [21:04:07.688] [LOG] Server started ... [21:04:07.695] [LOG] Connecting socket for: updatenotification [21:04:07.703] [LOG] Connecting socket for: MMM-Screencast [21:04:07.710] [LOG] Connecting socket for: calendar [21:04:07.716] [LOG] Starting node helper for: calendar [21:04:07.721] [LOG] Connecting socket for: MMM-DarkSkyForecast [21:04:07.724] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast] [21:04:07.729] [LOG] Connecting socket for: newsfeed [21:04:07.734] [LOG] Starting module: newsfeed [21:04:07.740] [LOG] Connecting socket for: MMM-HASS [21:04:07.745] [LOG] Sockets connected & modules started ... [21:04:07.748] [LOG] Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minute --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version= events.js:174 throw er; // Unhandled 'error' event ^ Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed at doWrite (_stream_writable.js:411:19) at writeOrBuffer (_stream_writable.js:399:5) at Socket.Writable.write (_stream_writable.js:299:11) at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46) at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10) at process.emit (events.js:198:13) at process._fatalException (internal/bootstrap/node.js:497:27) ^C
PS: Sorry for the delay I was without network for 5 days.
./run-start.sh[21:04:03.127] [LOG] Starting MagicMirror: v2.10.0
[21:04:03.163] [LOG] Loading config …
[21:04:03.185] [LOG] Loading module helpers …
[21:04:03.401] [LOG] Initializing new module helper …
[21:04:04.630] [LOG] Initializing new module helper …
[21:04:06.010] [LOG] Initializing new module helper …
[21:04:07.345] [LOG] Initializing new module helper …
[21:04:07.457] [LOG] Initializing new module helper …
[21:04:07.548] [LOG] Initializing new module helper …
[21:04:07.563] [LOG] Starting server on port 8080 …
[21:04:07.688] [LOG] Server started …
[21:04:07.745] [LOG] Sockets connected & modules started …
–disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
events.js:174
throw er; // Unhandled ‘error’ event
^Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
at process. (/home/pi/MagicMirror/js/app.js:40:10)
at process._fatalException (internal/bootstrap/node.js:497:27)And all the modules are loading …
When I try to run npm install after installing this module I get
npm ERR! zlib: invalid distance too far back
What the heck?
