    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 25.1k Views 7 Watching
      jthirasilpa
      @sdetweil said in MMM-NetworkScanner-loading...indefinitely:
      var options = {
      cachePassword: true,
      prompt: 'Password, ??? '; // put your password where ??? are (notice the quotes around)
      Thanks - tried that. Got the following log:
      0|mm  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:43
      0|mm  |     prompt: 'Password, mypassword';     // put your password where ???? are (notice the quotes around)
      0|mm  |                               ^
      0|mm  | SyntaxError: Unexpected token ;
      0|mm  |     at Module._compile (internal/modules/cjs/loader.js:723:23)
      0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      0|mm  |     at Module.load (internal/modules/cjs/loader.js:653:32)
      0|mm  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      0|mm  |     at Module.require (internal/modules/cjs/loader.js:692:17)
      0|mm  |     at require (internal/modules/cjs/helpers.js:25:18)
      0|mm  |     at loadModule (/home/jojo/MagicMirror/js/app.js:132:17)
      0|mm  |     at loadNextModule (/home/jojo/MagicMirror/js/app.js:166:5)
      0|mm  |     at /home/jojo/MagicMirror/js/app.js:168:6
        sdetweil @jthirasilpa
        @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
        sorry, take off the ‘;’ after the actual password
          jthirasilpa
          Thanks - see error log below
          [22:23:34.736] [ERROR] ReferenceError: options is not defined
          at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
          at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
          at Socket. (/home/jojo/MagicMirror/js/node_helper.js:113:11)
          at Socket.emit (events.js:198:13)
          at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at process._tickCallback (internal/process/next_tick.js:61:11)
          [22:24:03.590] [ERROR] TypeError: Cannot read property ‘network’ of undefined
          at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:45:36)
          [22:24:05.534] [ERROR] TypeError: Cannot read property ‘network’ of undefined
            but you added the 4 lines, right?
            var options = {
                prompt: 'Password, ???? '     // put your password where ???? are (notice the quotes around)
            and then the updated line
             var arp = sudo(['arp-scan', '-q', arpHosts], options);
            • karsten13K
              karsten13
              what is the result of sudo arp-scan -l running on your machine?
              J 1 Reply Last reply
                @jthirasilpa just do this… get my version of the module
                cd ~/MagicMirror/modules
                mv MMM-NetworkScanner MMM-NetworkScanner.original
                git clone https://github.com/sdetweil/MMM-NetworkScanner
                cd MMM-NetworkScanner
                npm install
                cd ~/MagicMirror/config
                nano config.js
                add the following line to the config section of the network scanner module
                Password: '??????',    // where '?????' is you password in quotes, for example 'raspberry', note the trailing comma
                ctrl-o at save the config.js
                ctrl-x to exit nano
                Restart your MM
                  jthirasilpa @sdetweil
                  Thanks Sam - tried your version of the module and modified the config.js accordingly. Still not quite working. Error logs as follows:
                  0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
                  0|mm       | [09:41:25.508] [ERROR]  ReferenceError: options is not defined
                  0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                  0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                  0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                  0|mm       |     at Socket.emit (events.js:198:13)
                  0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                  0|mm       | [09:41:55.508] [ERROR]  ReferenceError: options is not defined
                    @jthirasilpa hm… can u show me show me these lines from node_helper.js
                    scanNetworkMAC: function() {
                            this.log(this.name + " is performing arp-scan");
                            var self = this;
                            // Target hosts/network supplied in config or entire localnet
                            var arpHosts = this.config.network || '-l';
                    				var options = {
                    						prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                    I tested here with three different addresses… some coming online later… worked, no errors…
                      jthirasilpa @karsten13
                      @karsten13
                      Hi - it seems to function correctly - it returns the IP and MAC addresses of the various clients on the network.
                        I tried it both ways - but should the ‘password’ field in the helper file be filled in?
                          @jthirasilpa no… use the config.js
                          the reference to the options variable should be from line 47, not 42…
                          so, something is wrong with the code u have in node_helper.js
                          did u follow my steps above exactly?
                            jthirasilpa
                            Sorry I’m not being clear. I know that I need to modify the config.js (and have done so), but in line 45 of node_helper.js (as shown below) there is:
                            Should I leave this as is or fill in the password? That is where I have tried it both ways.
                            Code you asked for from node_helper.js:
                             38         this.log(this.name + " is performing arp-scan");
                             39
                             40         var self = this;
                             41         // Target hosts/network supplied in config or entire localnet
                             42         var arpHosts = this.config.network || '-l';
                             43                                 var options = {
                             44                                                 cachePassword: true,
                             45                                                 prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                             46                                 }
                             47         var arp = sudo(['arp-scan', '-q', arpHosts], options);
                              @jthirasilpa oh, i see I should have removed the comment… you do not need to change any code…
                              but the error does not match the code u are running now…
                              please do
                              pm2 stop 0
                              pm2 flush
                              pm2 start 0
                              pm2 logs
                              that error must have been from yesterday
                                jthirasilpa
                                Hmm
                                So with the password entered only in the config file, the error output still references line 42
                                Error output:
                                0|mm       | [19:37:36.956] [ERROR]  TypeError: Cannot read property 'network' of undefined
                                0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
                                0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
                                0|mm  | [19:37:50.982] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                0|mm  | [19:37:50.983] [LOG]    MMM-NetworkScanner is performing arp-scan
                                0|mm  | [19:37:50.984] [LOG]    Whoops! There was an uncaught exception...
                                0|mm  | [19:37:50.984] [ERROR]
                                0|mm  | TypeError: Cannot read property 'network' of undefined
                                0|mm  | [19:37:50.985] [LOG]
                                0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|mm  | [19:37:50.986] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                0|mm  | [19:38:21.046] [LOG]
                                0|mm  | MMM-NetworkScanner received SCAN_NETWORK
                                0|mm  | [19:38:21.047] [LOG]
                                0|mm  | MMM-NetworkScanner is performing arp-scan
                                0|mm  | [19:38:21.048] [LOG]    Whoops! There was an uncaught exception...
                                0|mm  | [19:38:21.048] [ERROR]
                                  0|mm | [19:37:36.956] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                                  Ok, but not ‘options’…
                                  now, to check, this system is case sensitive… so in config.js it MUST look like this, right?
                                              keepAlive: 300,
                                              updateInterval: 5,
                                  	    Password: 'pi'                        // added password (note capital P)
                                  using your password of course
                                    jthirasilpa
                                    That is how the config looks.
                                    Still getting the node_helper line 42 error. Will park this for now. Thank you for spending so much time on this Sam - much appreciated. Will come back to this later in the week.
                                      @jthirasilpa update the current code
                                      cd ~MagicMirror/modules/MMM-NetworkScanner
                                      git pull
                                      then you can shutdown and restart the MM app
                                      there was a tiny timing gap where the config info is not yet set, when the helper is asked to scan the network…
                                      let me know
                                      • O
                                        OldSunGuy
                                        Is it bad to have this?
                                        pi@raspberrypi ~ % sudo -l|grep NOPASS
                                            (ALL) NOPASSWD: ALL
                                        pi@raspberrypi ~ %
                                        Edit: To expand further, I have MMM-NetworkScanner running. I do not need to supply a password when I run sudo and I don’t have a password stored in a config file.
                                          Hi Sam - thanks I tried the update. Still getting the same error - from the log:
                                          [19:00:49.868] [ERROR]  TypeError: Cannot read property 'network' of undefined
                                            @jthirasilpa do another git pull from my repo… and try again
