    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 23.7k Views 7 Watching
      jthirasilpa
      Thanks.
      Whenever it shows up, it is contiguous to the MMM-NetworkScanner received CONFIG reading in the log. When this module is added, npm install adds the “sudo” dependency - I assume that this is what is sending the message, but do not know how to confirm?
        sdetweil @jthirasilpa
        @jthirasilpa cool, thx
        edit the node_helper.js
        add the following line
        const sudo = require("sudo");
        sudo.setPassword('your-password');      // add this line, edit to use your password
          jthirasilpa
          Thanks Sam - I made that modification in node_helper.js in the module’s directory with my password.
          I get the following errors from the logs:
          0|mm  | [21:06:46.210] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: sudo.setPassword is not a function
            0|mm  | [21:06:46.216] [ERROR]
          0|mm  | TypeError: sudo.setPassword is not a function
          0|mm  |     at Object.<anonymous> (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:13:6)
          0|mm  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
          0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          0|mm  |     at Module.load (internal/modules/cjs/loader.js:653:32)
          0|mm  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          0|mm  |     at Module.require (internal/modules/cjs/loader.js:692:17)
          0|mm  |     at require (internal/modules/cjs/helpers.js:25:18)
          0|mm  |     at loadModule (/home/jojo/MagicMirror/js/app.js:132:17)
          0|mm  |     at loadNextModule (/home/jojo/MagicMirror/js/app.js:166:5)
            jthirasilpa
            Maybe some progress?
            So I amended the insertion as follows:
            sudo.setPassword = ('your-password');      // add this line, edit to use your password
            Config loads, but NetworkScanner module still shows “loading…”
            Error logs as follows:
            0|mm       |     at Socket.emit (events.js:198:13)
            0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
            0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
            0|mm       | [21:26:17.270] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit
            0|mm       | [21:26:17.271] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 end listeners added. Use emitter.setMaxListeners() to increase limit
            0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListeners() to increase limit
            0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added. Use emitter.setMaxListeners() to increase limit
            0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 data listeners added. Use emitter.setMaxListeners() to increase limit
            0|mm       | [21:26:26.569] [ERROR]  TypeError: Cannot read property 'network' of undefined
            0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
            0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
            0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
            /home/jojo/.pm2/logs/mm-out.log last 15 lines:
            0|mm       | [21:26:18.772] [LOG]    Connecting socket for: MMM-UKNationalRail
            0|mm       | [21:26:18.772] [LOG]    MMM-UKNationalRail helper started ...
            0|mm       | [21:26:18.773] [LOG]    Connecting socket for: MMM-NetworkScanner
            0|mm       | [21:26:18.773] [LOG]    Starting module: MMM-NetworkScanner
            0|mm       | [21:26:18.773] [LOG]    Sockets connected & modules started ...
            0|mm       | [21:26:18.774] [LOG]
            0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
            0|mm       | [21:26:26.567] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
            0|mm       | [21:26:26.568] [LOG]    MMM-NetworkScanner is performing arp-scan
            0|mm       | [21:26:26.569] [LOG]    Whoops! There was an uncaught exception...
            0|mm       | [21:26:26.575] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mm       | [21:26:26.576] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|mm       | [21:26:29.340] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            0|mm       | [21:26:29.375] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
            0|mm       | [21:26:29.441] [LOG]    MMM-NetworkScanner received CONFIG
              @jthirasilpa ok, had to read the sudo module code to find out where it was… cause when I searched I ended up in the wrong place…
              remove the one line I had you add
              do this
              // add these 4 lines
              var options = {
                  cachePassword: true,
                  prompt: 'Password, ???? ';     // put your password where ???? are (notice the quotes around)
                      var arpHosts = this.config.network || '-l';
                      var arp = sudo(['arp-scan', '-q', arpHosts], options);   // change this line, to add ,options at the end
                jthirasilpa
                @sdetweil said in MMM-NetworkScanner-loading...indefinitely:
                var options = {
                prompt: 'Password, ??? '; // put your password where ??? are (notice the quotes around)
                Thanks - tried that. Got the following log:
                0|mm  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:43
                0|mm  |     prompt: 'Password, mypassword';     // put your password where ???? are (notice the quotes around)
                0|mm  |                               ^
                0|mm  | SyntaxError: Unexpected token ;
                0|mm  |     at Module._compile (internal/modules/cjs/loader.js:723:23)
                0|mm  |     at /home/jojo/MagicMirror/js/app.js:168:6
                  @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
                  sorry, take off the ‘;’ after the actual password
                    jthirasilpa
                    Thanks - see error log below
                    [22:23:34.736] [ERROR] ReferenceError: options is not defined
                    at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                    at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                    at Socket. (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                    [22:24:03.590] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                    at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:45:36)
                    [22:24:05.534] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                      but you added the 4 lines, right?
                      var options = {
                          prompt: 'Password, ???? '     // put your password where ???? are (notice the quotes around)
                      and then the updated line
                      • karsten13K Offline
                        karsten13
                        what is the result of sudo arp-scan -l running on your machine?
                          @jthirasilpa just do this… get my version of the module
                          cd ~/MagicMirror/modules
                          mv MMM-NetworkScanner MMM-NetworkScanner.original
                          git clone https://github.com/sdetweil/MMM-NetworkScanner
                          cd MMM-NetworkScanner
                          npm install
                          cd ~/MagicMirror/config
                          nano config.js
                          add the following line to the config section of the network scanner module
                          Password: '??????',    // where '?????' is you password in quotes, for example 'raspberry', note the trailing comma
                          ctrl-o at save the config.js
                          ctrl-x to exit nano
                          Restart your MM
                            jthirasilpa @sdetweil
                            Thanks Sam - tried your version of the module and modified the config.js accordingly. Still not quite working. Error logs as follows:
                            0|mm       | [09:41:25.508] [ERROR]  ReferenceError: options is not defined
                            0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                            0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                            0|mm       | [09:41:55.508] [ERROR]  ReferenceError: options is not defined
                              @jthirasilpa hm… can u show me show me these lines from node_helper.js
                              scanNetworkMAC: function() {
                                      this.log(this.name + " is performing arp-scan");
                                      var self = this;
                                      // Target hosts/network supplied in config or entire localnet
                              				var options = {
                              						prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                              I tested here with three different addresses… some coming online later… worked, no errors…
                                jthirasilpa @karsten13
                                @karsten13
                                Hi - it seems to function correctly - it returns the IP and MAC addresses of the various clients on the network.
                                  I tried it both ways - but should the ‘password’ field in the helper file be filled in?
                                    @jthirasilpa no… use the config.js
                                    the reference to the options variable should be from line 47, not 42…
                                    so, something is wrong with the code u have in node_helper.js
                                    did u follow my steps above exactly?
                                      jthirasilpa
                                      Sorry I’m not being clear. I know that I need to modify the config.js (and have done so), but in line 45 of node_helper.js (as shown below) there is:
                                      Should I leave this as is or fill in the password? That is where I have tried it both ways.
                                      Code you asked for from node_helper.js:
                                       38         this.log(this.name + " is performing arp-scan");
                                       39
                                       40         var self = this;
                                       41         // Target hosts/network supplied in config or entire localnet
                                       42         var arpHosts = this.config.network || '-l';
                                       43                                 var options = {
                                       44                                                 cachePassword: true,
                                       45                                                 prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                                       46                                 }
                                       47         var arp = sudo(['arp-scan', '-q', arpHosts], options);
                                        @jthirasilpa oh, i see I should have removed the comment… you do not need to change any code…
                                        but the error does not match the code u are running now…
                                        please do
                                        pm2 stop 0
                                        pm2 flush
                                        pm2 start 0
                                        pm2 logs
                                        that error must have been from yesterday
                                          jthirasilpa
                                          Hmm
                                          So with the password entered only in the config file, the error output still references line 42
                                          Error output:
                                          0|mm       | [19:37:36.956] [ERROR]  TypeError: Cannot read property 'network' of undefined
                                          0|mm  | [19:37:50.982] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                          0|mm  | [19:37:50.983] [LOG]    MMM-NetworkScanner is performing arp-scan
                                          0|mm  | [19:37:50.984] [LOG]    Whoops! There was an uncaught exception...
                                          0|mm  | [19:37:50.984] [ERROR]
                                          0|mm  | TypeError: Cannot read property 'network' of undefined
                                          0|mm  | [19:37:50.985] [LOG]
                                          0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|mm  | [19:37:50.986] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|mm  | [19:38:21.046] [LOG]
                                          0|mm  | MMM-NetworkScanner received SCAN_NETWORK
                                          0|mm  | [19:38:21.047] [LOG]
                                          0|mm  | MMM-NetworkScanner is performing arp-scan
                                          0|mm  | [19:38:21.048] [LOG]    Whoops! There was an uncaught exception...
                                          0|mm  | [19:38:21.048] [ERROR]
                                            0|mm | [19:37:36.956] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                                            Ok, but not ‘options’…
                                            now, to check, this system is case sensitive… so in config.js it MUST look like this, right?
                                                        keepAlive: 300,
                                                        updateInterval: 5,
                                            	    Password: 'pi'                        // added password (note capital P)
                                            using your password of course
