    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 24.7k Views 7 Watching
      sdetweil @jthirasilpa
      @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
      sudo requires your password: [20:18:51.080]
      what is sending this message?
        jthirasilpa
        Thanks.
        Whenever it shows up, it is contiguous to the MMM-NetworkScanner received CONFIG reading in the log. When this module is added, npm install adds the “sudo” dependency - I assume that this is what is sending the message, but do not know how to confirm?
          @jthirasilpa cool, thx
          edit the node_helper.js
          add the following line
          const sudo = require("sudo");
          sudo.setPassword('your-password');      // add this line, edit to use your password
            jthirasilpa
            Thanks Sam - I made that modification in node_helper.js in the module’s directory with my password.
            I get the following errors from the logs:
            0|mm  | [21:06:46.210] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: sudo.setPassword is not a function
              0|mm  | [21:06:46.216] [ERROR]
            0|mm  | TypeError: sudo.setPassword is not a function
            0|mm  |     at Object.<anonymous> (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:13:6)
            0|mm  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
            0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            0|mm  |     at Module.load (internal/modules/cjs/loader.js:653:32)
            0|mm  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            0|mm  |     at Module.require (internal/modules/cjs/loader.js:692:17)
            0|mm  |     at require (internal/modules/cjs/helpers.js:25:18)
            0|mm  |     at loadModule (/home/jojo/MagicMirror/js/app.js:132:17)
            0|mm  |     at loadNextModule (/home/jojo/MagicMirror/js/app.js:166:5)
              jthirasilpa
              Maybe some progress?
              So I amended the insertion as follows:
              sudo.setPassword = ('your-password');      // add this line, edit to use your password
              Config loads, but NetworkScanner module still shows “loading…”
              Error logs as follows:
              0|mm       |     at Socket.emit (events.js:198:13)
              0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
              0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
              0|mm       | [21:26:17.270] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit
              0|mm       | [21:26:17.271] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 end listeners added. Use emitter.setMaxListeners() to increase limit
              0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListeners() to increase limit
              0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added. Use emitter.setMaxListeners() to increase limit
              0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 data listeners added. Use emitter.setMaxListeners() to increase limit
              0|mm       | [21:26:26.569] [ERROR]  TypeError: Cannot read property 'network' of undefined
              0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
              0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
              0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
              /home/jojo/.pm2/logs/mm-out.log last 15 lines:
              0|mm       | [21:26:18.772] [LOG]    Connecting socket for: MMM-UKNationalRail
              0|mm       | [21:26:18.772] [LOG]    MMM-UKNationalRail helper started ...
              0|mm       | [21:26:18.773] [LOG]    Connecting socket for: MMM-NetworkScanner
              0|mm       | [21:26:18.773] [LOG]    Starting module: MMM-NetworkScanner
              0|mm       | [21:26:18.773] [LOG]    Sockets connected & modules started ...
              0|mm       | [21:26:18.774] [LOG]
              0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
              0|mm       | [21:26:26.567] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
              0|mm       | [21:26:26.568] [LOG]    MMM-NetworkScanner is performing arp-scan
              0|mm       | [21:26:26.569] [LOG]    Whoops! There was an uncaught exception...
              0|mm       | [21:26:26.575] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mm       | [21:26:26.576] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mm       | [21:26:29.340] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              0|mm       | [21:26:29.375] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
              0|mm       | [21:26:29.441] [LOG]    MMM-NetworkScanner received CONFIG
                @jthirasilpa ok, had to read the sudo module code to find out where it was… cause when I searched I ended up in the wrong place…
                remove the one line I had you add
                do this
                // add these 4 lines
                var options = {
                    cachePassword: true,
                    prompt: 'Password, ???? ';     // put your password where ???? are (notice the quotes around)
                        var arpHosts = this.config.network || '-l';
                        var arp = sudo(['arp-scan', '-q', arpHosts], options);   // change this line, to add ,options at the end
                  jthirasilpa
                  @sdetweil said in MMM-NetworkScanner-loading...indefinitely:
                  var options = {
                  prompt: 'Password, ??? '; // put your password where ??? are (notice the quotes around)
                  Thanks - tried that. Got the following log:
                  0|mm  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:43
                  0|mm  |     prompt: 'Password, mypassword';     // put your password where ???? are (notice the quotes around)
                  0|mm  |                               ^
                  0|mm  | SyntaxError: Unexpected token ;
                  0|mm  |     at Module._compile (internal/modules/cjs/loader.js:723:23)
                  0|mm  |     at /home/jojo/MagicMirror/js/app.js:168:6
                    sorry, take off the ‘;’ after the actual password
                      jthirasilpa
                      Thanks - see error log below
                      [22:23:34.736] [ERROR] ReferenceError: options is not defined
                      at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                      at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                      at Socket. (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                      [22:24:03.590] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                      at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:45:36)
                      [22:24:05.534] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                        but you added the 4 lines, right?
                        var options = {
                            prompt: 'Password, ???? '     // put your password where ???? are (notice the quotes around)
                        and then the updated line
                        • karsten13K
                          karsten13
                          what is the result of sudo arp-scan -l running on your machine?
                            @jthirasilpa just do this… get my version of the module
                            cd ~/MagicMirror/modules
                            mv MMM-NetworkScanner MMM-NetworkScanner.original
                            git clone https://github.com/sdetweil/MMM-NetworkScanner
                            cd MMM-NetworkScanner
                            npm install
                            cd ~/MagicMirror/config
                            nano config.js
                            add the following line to the config section of the network scanner module
                            Password: '??????',    // where '?????' is you password in quotes, for example 'raspberry', note the trailing comma
                            ctrl-o at save the config.js
                            ctrl-x to exit nano
                            Restart your MM
                              jthirasilpa @sdetweil
                              Thanks Sam - tried your version of the module and modified the config.js accordingly. Still not quite working. Error logs as follows:
                              0|mm       | [09:41:25.508] [ERROR]  ReferenceError: options is not defined
                              0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                              0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                              0|mm       | [09:41:55.508] [ERROR]  ReferenceError: options is not defined
                                @jthirasilpa hm… can u show me show me these lines from node_helper.js
                                scanNetworkMAC: function() {
                                        this.log(this.name + " is performing arp-scan");
                                        var self = this;
                                        // Target hosts/network supplied in config or entire localnet
                                				var options = {
                                						prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                                I tested here with three different addresses… some coming online later… worked, no errors…
                                  jthirasilpa @karsten13
                                  @karsten13
                                  Hi - it seems to function correctly - it returns the IP and MAC addresses of the various clients on the network.
                                    I tried it both ways - but should the ‘password’ field in the helper file be filled in?
                                      @jthirasilpa no… use the config.js
                                      the reference to the options variable should be from line 47, not 42…
                                      so, something is wrong with the code u have in node_helper.js
                                      did u follow my steps above exactly?
                                        jthirasilpa
                                        Sorry I’m not being clear. I know that I need to modify the config.js (and have done so), but in line 45 of node_helper.js (as shown below) there is:
                                        Should I leave this as is or fill in the password? That is where I have tried it both ways.
                                        Code you asked for from node_helper.js:
                                         38         this.log(this.name + " is performing arp-scan");
                                         39
                                         40         var self = this;
                                         41         // Target hosts/network supplied in config or entire localnet
                                         42         var arpHosts = this.config.network || '-l';
                                         43                                 var options = {
                                         44                                                 cachePassword: true,
                                         45                                                 prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                                         46                                 }
                                         47         var arp = sudo(['arp-scan', '-q', arpHosts], options);
                                          @jthirasilpa oh, i see I should have removed the comment… you do not need to change any code…
                                          but the error does not match the code u are running now…
                                          please do
                                          pm2 stop 0
                                          pm2 flush
                                          pm2 start 0
                                          pm2 logs
                                          that error must have been from yesterday
                                            jthirasilpa
                                            Hmm
                                            So with the password entered only in the config file, the error output still references line 42
                                            Error output:
                                            0|mm       | [19:37:36.956] [ERROR]  TypeError: Cannot read property 'network' of undefined
                                            0|mm  | [19:37:50.982] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                                            0|mm  | [19:37:50.983] [LOG]    MMM-NetworkScanner is performing arp-scan
                                            0|mm  | [19:37:50.984] [LOG]    Whoops! There was an uncaught exception...
                                            0|mm  | [19:37:50.984] [ERROR]
                                            0|mm  | TypeError: Cannot read property 'network' of undefined
                                            0|mm  | [19:37:50.985] [LOG]
                                            0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm  | [19:37:50.986] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|mm  | [19:38:21.046] [LOG]
                                            0|mm  | MMM-NetworkScanner received SCAN_NETWORK
                                            0|mm  | [19:38:21.047] [LOG]
                                            0|mm  | MMM-NetworkScanner is performing arp-scan
                                            0|mm  | [19:38:21.048] [LOG]    Whoops! There was an uncaught exception...
                                            0|mm  | [19:38:21.048] [ERROR]
