    MMM-NetworkScanner-loading...indefinitely
    54 Posts 6 Posters 25.1k Views 7 Watching
      jthirasilpa
      Re: MMM-NetWorkScanner
      I have run config:check and indicates no issue with the config.js syntax, but cannot get the networkscanner module to load.
      Here is the code from config.js: (note there is a missing { that dropped off code below)
                              module:                 "MMM-NetworkScanner",
                              position:               "bottom_center",
                              header:                 "Devices Online",
                                      devices: [
                                      { ipAddress: "192.168.1.11", name: "ABC", icon: "server"},
                                      { ipAddress:  "192.168.1.17", name:  "DEF", icon:  "server"},
                                      { ipAddress:  "192.168.1.133", name: "GHI,", icon: "mobile" },
                                      showUnknown: false,
                                      showOffline:  true,
                                      keepAlive:  600,
                                      showLastSeen:  true,
                                      updateInterval:  30
      pm2 logs mm gives the following output:
      ```0|mm       |     at process._tickCallback (internal/process/next_tick.js:61:11)
      0|mm       | [20:12:56.567] [ERROR]  TypeError: Cannot read property 'network' of undefined
      0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:36)
      0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:30:18)
      0|mm       |     at Socket.<anonymous> (/home/jojo/MagicMirror/js/node_helper.js:113:11)
      0|mm       |     at Socket.emit (events.js:198:13)
      0|mm       |     at /home/jojo/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      0|mm       | [20:13:26.570] [ERROR]  TypeError: Cannot read property 'network' of undefined
      /home/jojo/.pm2/logs/mm-out.log last 15 lines:
      0|mm       | [20:15:28.523] [LOG]    Connecting socket for: updatenotification
      0|mm       | [20:15:28.524] [LOG]    Connecting socket for: newsfeed
      0|mm       | [20:15:28.525] [LOG]    Starting module: newsfeed
      0|mm       | [20:15:28.525] [LOG]    Connecting socket for: MMM-UKNationalRail
      0|mm       | [20:15:28.525] [LOG]    MMM-UKNationalRail helper started ...
      0|mm       | [20:15:28.526] [LOG]    Connecting socket for: MMM-NetworkScanner
      0|mm       | [20:15:28.526] [LOG]    Starting module: MMM-NetworkScanner
      0|mm       | [20:15:28.527] [LOG]    Sockets connected & modules started ...
      0|mm       | Ready to go! Please point your browser to: http://0.0.0.0:8080
      0|mm       | [20:15:37.883] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      0|mm       | [20:15:37.917] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
      0|mm       | [20:15:37.985] [LOG]    MMM-NetworkScanner received CONFIG
      0|mm       | sudo requires your password: [20:18:51.080] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
      0|mm       | [20:18:51.087] [LOG]    Use existing news fetcher for url: http://rss.cnn.com/rss/edition.rss
      Suggestions appreciated.
        sdetweil @jthirasilpa
        @jthirasilpa said in MMM-NetworkScanner-loading...indefinitely:
        what is sending this message?
          jthirasilpa
          Thanks.
          Whenever it shows up, it is contiguous to the MMM-NetworkScanner received CONFIG reading in the log. When this module is added, npm install adds the “sudo” dependency - I assume that this is what is sending the message, but do not know how to confirm?
          S 2 Replies Last reply
            @jthirasilpa cool, thx
            edit the node_helper.js
            add the following line
            const sudo = require("sudo");
            sudo.setPassword('your-password');      // add this line, edit to use your password
              jthirasilpa
              Thanks Sam - I made that modification in node_helper.js in the module’s directory with my password.
              I get the following errors from the logs:
              0|mm  | [21:06:46.210] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: sudo.setPassword is not a function
                0|mm  | [21:06:46.216] [ERROR]
              0|mm  | TypeError: sudo.setPassword is not a function
              0|mm  |     at Object.<anonymous> (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:13:6)
              0|mm  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
              0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              0|mm  |     at Module.load (internal/modules/cjs/loader.js:653:32)
              0|mm  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              0|mm  |     at Module.require (internal/modules/cjs/loader.js:692:17)
              0|mm  |     at require (internal/modules/cjs/helpers.js:25:18)
              0|mm  |     at loadModule (/home/jojo/MagicMirror/js/app.js:132:17)
              0|mm  |     at loadNextModule (/home/jojo/MagicMirror/js/app.js:166:5)
                jthirasilpa
                Maybe some progress?
                So I amended the insertion as follows:
                sudo.setPassword = ('your-password');      // add this line, edit to use your password
                Config loads, but NetworkScanner module still shows “loading…”
                Error logs as follows:
                0|mm       | [21:26:17.270] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit
                0|mm       | [21:26:17.271] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 end listeners added. Use emitter.setMaxListeners() to increase limit
                0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 drain listeners added. Use emitter.setMaxListeners() to increase limit
                0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added. Use emitter.setMaxListeners() to increase limit
                0|mm       | [21:26:17.272] [ERROR]  (node:1940) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 data listeners added. Use emitter.setMaxListeners() to increase limit
                0|mm       | [21:26:26.569] [ERROR]  TypeError: Cannot read property 'network' of undefined
                0|mm       | [21:26:18.772] [LOG]    Connecting socket for: MMM-UKNationalRail
                0|mm       | [21:26:18.772] [LOG]    MMM-UKNationalRail helper started ...
                0|mm       | [21:26:18.773] [LOG]    Connecting socket for: MMM-NetworkScanner
                0|mm       | [21:26:18.773] [LOG]    Starting module: MMM-NetworkScanner
                0|mm       | [21:26:18.773] [LOG]    Sockets connected & modules started ...
                0|mm       | [21:26:18.774] [LOG]
                0|mm       | [21:26:26.567] [LOG]    MMM-NetworkScanner received SCAN_NETWORK
                0|mm       | [21:26:26.568] [LOG]    MMM-NetworkScanner is performing arp-scan
                0|mm       | [21:26:26.569] [LOG]    Whoops! There was an uncaught exception...
                0|mm       | [21:26:26.575] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [21:26:26.576] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm       | [21:26:29.340] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                0|mm       | [21:26:29.375] [LOG]    Create new news fetcher for url: http://rss.cnn.com/rss/edition.rss - Interval: 300000
                0|mm       | [21:26:29.441] [LOG]    MMM-NetworkScanner received CONFIG
                  @jthirasilpa ok, had to read the sudo module code to find out where it was… cause when I searched I ended up in the wrong place…
                  remove the one line I had you add
                  do this
                  // add these 4 lines
                  var options = {
                      cachePassword: true,
                      prompt: 'Password, ???? ';     // put your password where ???? are (notice the quotes around)
                          var arpHosts = this.config.network || '-l';
                          var arp = sudo(['arp-scan', '-q', arpHosts], options);   // change this line, to add ,options at the end
                    jthirasilpa
                    @sdetweil said in MMM-NetworkScanner-loading...indefinitely:
                    var options = {
                    prompt: 'Password, ??? '; // put your password where ??? are (notice the quotes around)
                    Thanks - tried that. Got the following log:
                    0|mm  | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:43
                    0|mm  |     prompt: 'Password, mypassword';     // put your password where ???? are (notice the quotes around)
                    0|mm  |                               ^
                    0|mm  | SyntaxError: Unexpected token ;
                    0|mm  |     at Module._compile (internal/modules/cjs/loader.js:723:23)
                    0|mm  |     at /home/jojo/MagicMirror/js/app.js:168:6
                      sorry, take off the ‘;’ after the actual password
                        jthirasilpa
                        Thanks - see error log below
                        [22:23:34.736] [ERROR] ReferenceError: options is not defined
                        at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                        at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                        at Socket. (/home/jojo/MagicMirror/js/node_helper.js:113:11)
                        [22:24:03.590] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                        at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:45:36)
                        [22:24:05.534] [ERROR] TypeError: Cannot read property ‘network’ of undefined
                          but you added the 4 lines, right?
                          var options = {
                              prompt: 'Password, ???? '     // put your password where ???? are (notice the quotes around)
                          and then the updated line
                          • karsten13K
                            karsten13
                            what is the result of sudo arp-scan -l running on your machine?
                            J 1 Reply Last reply
                              @jthirasilpa just do this… get my version of the module
                              cd ~/MagicMirror/modules
                              mv MMM-NetworkScanner MMM-NetworkScanner.original
                              git clone https://github.com/sdetweil/MMM-NetworkScanner
                              cd MMM-NetworkScanner
                              npm install
                              cd ~/MagicMirror/config
                              nano config.js
                              add the following line to the config section of the network scanner module
                              Password: '??????',    // where '?????' is you password in quotes, for example 'raspberry', note the trailing comma
                              ctrl-o at save the config.js
                              ctrl-x to exit nano
                              Restart your MM
                                jthirasilpa @sdetweil
                                Thanks Sam - tried your version of the module and modified the config.js accordingly. Still not quite working. Error logs as follows:
                                0|mm       | [09:41:25.508] [ERROR]  ReferenceError: options is not defined
                                0|mm       |     at Class.scanNetworkMAC (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:42:54)
                                0|mm       |     at Class.socketNotificationReceived (/home/jojo/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:29:18)
                                0|mm       | [09:41:55.508] [ERROR]  ReferenceError: options is not defined
                                  @jthirasilpa hm… can u show me show me these lines from node_helper.js
                                  scanNetworkMAC: function() {
                                          this.log(this.name + " is performing arp-scan");
                                          var self = this;
                                          // Target hosts/network supplied in config or entire localnet
                                  				var options = {
                                  						prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                                  I tested here with three different addresses… some coming online later… worked, no errors…
                                    jthirasilpa @karsten13
                                    @karsten13
                                    Hi - it seems to function correctly - it returns the IP and MAC addresses of the various clients on the network.
                                      I tried it both ways - but should the ‘password’ field in the helper file be filled in?
                                        @jthirasilpa no… use the config.js
                                        the reference to the options variable should be from line 47, not 42…
                                        so, something is wrong with the code u have in node_helper.js
                                        did u follow my steps above exactly?
                                          jthirasilpa
                                          Sorry I’m not being clear. I know that I need to modify the config.js (and have done so), but in line 45 of node_helper.js (as shown below) there is:
                                          Should I leave this as is or fill in the password? That is where I have tried it both ways.
                                          Code you asked for from node_helper.js:
                                           38         this.log(this.name + " is performing arp-scan");
                                           39
                                           40         var self = this;
                                           41         // Target hosts/network supplied in config or entire localnet
                                           42         var arpHosts = this.config.network || '-l';
                                           43                                 var options = {
                                           44                                                 cachePassword: true,
                                           45                                                 prompt: 'Password,' + this.config.Password     // put your password where ???? are (notice the quotes around)
                                           46                                 }
                                           47         var arp = sudo(['arp-scan', '-q', arpHosts], options);
                                            @jthirasilpa oh, i see I should have removed the comment… you do not need to change any code…
                                            but the error does not match the code u are running now…
                                            please do
                                            pm2 stop 0
                                            pm2 flush
                                            pm2 start 0
                                            pm2 logs
                                            that error must have been from yesterday
