    Display temperature over network
    14 Posts 7 Posters 4.7k Views 7 Watching
    • L Offline
      linuxdxs
      Hello, at first please excuse my bad english. I build a thermometer with an Rasperry zero. The Raspi shout transmit the value over the Network. All Magic Mirror should display the temperature.
      Can someone help me?
      thank you in advance
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @linuxdxs
        @linuxdxs how transmit over network?
        • L Offline
          linuxdxs
          So far I have no idea how to transfer the data. Maybe over udp and phyton?
            sdetweil @linuxdxs
            @linuxdxs what is running on the pi 0?.. raspian and python?
            you could set up a little web server (using node js and express, or python) and then a module on the Magic Mirror could call that server to get the data
            • L Offline
              linuxdxs
              Ok, which webserver would you prefere
                sdetweil @linuxdxs
                @linuxdxs you can write code to start the web server… node web server using express library is very short…
                I don’t know python that well… I’m sure a google search will give u results…
                so, whatever u feel more comfortable with
                once u set that up you can use your browser to invoke the function on the pi0 to return the temp…
                once that is working, then u can build a module to do the same…
                using my sample module might help on the last step
                https://github.com/sdetweil/SampleModule
                • E Offline
                  ember1205
                  Why not write the module that goes into MM and then use a script on the thermometer to update the module when the temp changes? If your thermometer is measuring the internal temp of a home, and that changes infrequently because the heat or AC is on, there’s no point in polling the thermometer every five minutes to see what the temp is. :)
                    sdetweil @ember1205
                    @ember1205 thats another way, but takes more skill to trigger into MM…
                    • E Offline
                      ember1205 @sdetweil
                      @sdetweil Agreed. And, it would still require a method for the module to “register” with the remote thermometer of its existence when it loads so that initial temp and updates will be transmitted.
                        sdetweil @ember1205
                        @ember1205 based on @linuxdxs comments and questions, I think starting slow is a better choice…
