    Google Calendar not updating
    22 Posts 2 Posters 6.1k Views 3 Watching
      sdetweil @vanced54
      @vanced54 said in Google Calendar not updating:
      calendar error 404: Not Found
      that means the URL you provided is not working (not found)
      put the url in the browser on the pi, it must download an ics file… if not fix til it does
      then add THAT url to MM calendar config
      V 2 Replies Last reply Reply Quote 0
      • V Offline
        vanced54 @sdetweil
        @sdetweil Thanks. I will give it a go!
        • V Offline
          vanced54 @sdetweil
          @sdetweil said in Google Calendar not updating:
          So I have gotten the 404 error to clear but there are no events coming in.
          module: “calendar”,
          header: “Dustin’s Calendar”,
          position: “top_left”,
          symbol: “calendar-check-o”,
          url: “https://calendar.google.com/calendar/ical/USERNAME%40gmail.com/private-CODE/basic.ics” }
          Here is the code. I did change my user name to USERNAME and the private code to CODE
            sdetweil @vanced54
            @vanced54 if u edit the downloaded ics file. Do you see the events u are looking for?
            • V Offline
              vanced54 @sdetweil
              @sdetweil I sure do
                sdetweil @vanced54
                @vanced54 do you see in the terminal window, or pm2 logs
                 Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                but with your url?
                do you see any errors?
                • V Offline
                  vanced54 @sdetweil
                  Not that I see but there may be something I am overlooking
                    sdetweil @vanced54
                    @vanced54 ok, there is a debug tool in the /modules/default/calendar folder
                    edit the debug.js and put your url in the place of the one there
                    and then do
                    node debug.js
                    it should display events read from the calendar
                    • V Offline
                      vanced54 @sdetweil
                      @sdetweil where do I do the node debug.js?
                      I tried it but doesn’t seem to worka22cc263-c285-48e6-bf1c-420fccb1e735-image.png
                      I did edit the debug.js file with the same link.
                        sdetweil @vanced54
                        @vanced54 you have to be in the MagicMirror/modules/default/calendar folder
