    Google Calendar not updating
    22 Posts 2 Posters 6.3k Views 3 Watching
    • V Offline
      vanced54
      Complete Noob here. I am not getting my calendar to work in MM. I have tried many different ways but still no success. The holiday calendar works fine. Is there something not working with Google Calendar?
      calendar error 404: Not Found is what I’m getting when I control +Q out of MM
        sdetweil @vanced54
        @vanced54 said in Google Calendar not updating:
        that means the URL you provided is not working (not found)
        put the url in the browser on the pi, it must download an ics file… if not fix til it does
        then add THAT url to MM calendar config
        V 2 Replies Last reply Reply Quote 0
        • V Offline
          vanced54 @sdetweil
          @sdetweil Thanks. I will give it a go!
          • V Offline
            vanced54 @sdetweil
            @sdetweil said in Google Calendar not updating:
            So I have gotten the 404 error to clear but there are no events coming in.
            module: “calendar”,
            header: “Dustin’s Calendar”,
            position: “top_left”,
            symbol: “calendar-check-o”,
            url: “https://calendar.google.com/calendar/ical/USERNAME%40gmail.com/private-CODE/basic.ics” }
            Here is the code. I did change my user name to USERNAME and the private code to CODE
              sdetweil @vanced54
              @vanced54 if u edit the downloaded ics file. Do you see the events u are looking for?
              • V Offline
                vanced54 @sdetweil
                @sdetweil I sure do
                  sdetweil @vanced54
                  @vanced54 do you see in the terminal window, or pm2 logs
                   Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                  but with your url?
                  do you see any errors?
                  • V Offline
                    vanced54 @sdetweil
                    Not that I see but there may be something I am overlooking
                      sdetweil @vanced54
                      @vanced54 ok, there is a debug tool in the /modules/default/calendar folder
                      edit the debug.js and put your url in the place of the one there
                      and then do
                      node debug.js
                      it should display events read from the calendar
                      • V Offline
                        vanced54 @sdetweil
                        @sdetweil where do I do the node debug.js?
                        I tried it but doesn’t seem to worka22cc263-c285-48e6-bf1c-420fccb1e735-image.png
                        I did edit the debug.js file with the same link.
