    Google Calendar not updating
    22 Posts 2 Posters 7.7k Views 3 Watching
      sdetweil @vanced54
      @vanced54 if u edit the downloaded ics file. Do you see the events u are looking for?
      • V Offline
        vanced54 @sdetweil
        @sdetweil I sure do
          sdetweil @vanced54
          @vanced54 do you see in the terminal window, or pm2 logs
           Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          but with your url?
          do you see any errors?
          • V Offline
            vanced54 @sdetweil
            Not that I see but there may be something I am overlooking
              sdetweil @vanced54
              @vanced54 ok, there is a debug tool in the /modules/default/calendar folder
              edit the debug.js and put your url in the place of the one there
              and then do
              node debug.js
              it should display events read from the calendar
              • V Offline
                vanced54 @sdetweil
                @sdetweil where do I do the node debug.js?
                I tried it but doesn’t seem to worka22cc263-c285-48e6-bf1c-420fccb1e735-image.png
                I did edit the debug.js file with the same link.
                  sdetweil @vanced54
                  @vanced54 you have to be in the MagicMirror/modules/default/calendar folder
                  • V Offline
                    vanced54 @sdetweil
                    It does find events. So that means the link is good I belive.
                      sdetweil @vanced54
                      @vanced54 are the events in the future?
                      open the developers window on the mirror
                      using the ctrl-shift-i on the keyboard or npm start dev
                      then select the console tab, and scroll up… u can also filter to just the module
                      by putting part of the module name in the filter field ‘cal’ (no quotes) for example
                      • V Offline
                        vanced54 @sdetweil
                        The events were in the past. Only 10 were there but it seems like that is what the max events were set to.
                          sdetweil @vanced54
                          @vanced54 yeh, the calendar will not show events in the past… it will (with settings change) broadcast those as part of the calendar data to OTHER modules, which might use it… I have a module that uses the calendar broadcast, but not events in the past
                          • V Offline
                            vanced54 @sdetweil
                            @sdetweil So what does that mean? Does that provide a clue as to why I’m not getting calendar events to show up?
                              sdetweil @vanced54
                              @vanced54 no… cause the calendar shows them and THEN sends a message for others to use…
                              if the calendar doesn’t find any usable events, then there is nothing to send
                              • V Offline
                                vanced54 @sdetweil
                                So any other suggestions as to figure out what is going on?
                                  sdetweil @vanced54
                                  @vanced54 if u send me your cal url, I will test it here.
                                  Send email to my same user ID at gmail
                                  • V Offline
                                    vanced54 @sdetweil
                                    I did Thank you
                                      sdetweil @vanced54
                                      @vanced54 sent reply
                                        @vanced54 replied email again
