Issues installing on rpi2
Hi folks,
tried to setup a new MM version on a rpi2. Followed every step in the (current) manual installation procedure, but it fails every time. Tried to reinstall and add features several times, now I do not know what to do next… any idea?Here are the logs from ‘npm install’
pi@raspberrypi:~/MagicMirror $ npm install > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver > node ./download-chromedriver.js internal/modules/cjs/loader.js:638 throw err; ^ Error: Cannot find module 'debug' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron-download/lib/index.js:4:15) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! electron-chromedriver@6.0.0 install: `node ./download-chromedriver.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the electron-chromedriver@6.0.0 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-04-15T07_19_42_745Z-debug.log pi@raspberrypi:~/MagicMirror $ node ./download-chromedriver.js internal/modules/cjs/loader.js:638 throw err; ^ Error: Cannot find module '/home/pi/MagicMirror/download-chromedriver.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Function.Module.runMain (internal/modules/cjs/loader.js:831:12) at startup (internal/bootstrap/node.js:283:19) at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)and as this seems to be related to electron the log for: ‘npm install electron@6.0.12’
pi@raspberrypi:~/MagicMirror $ npm install electron@6.0.12 > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver > node ./download-chromedriver.js internal/modules/cjs/loader.js:638 throw err; ^ Error: Cannot find module 'debug' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) at Function.Module._load (internal/modules/cjs/loader.js:562:25) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron-download/lib/index.js:4:15) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) npm WARN grunt-eslint@22.0.0 requires a peer of grunt@>=1 but none is installed. You must install peer dependencies yourself. npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself. npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@>=1.0.1 but none is installed. You must install peer dependencies yourself. npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself. npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself. npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! electron-chromedriver@6.0.0 install: `node ./download-chromedriver.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the electron-chromedriver@6.0.0 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-04-15T07_22_40_386Z-debug.log -
What version of NPM are you using?
npm -v -
Running on 6.14.4’
pi@raspberrypi:~ $ npm version { npm: '6.14.4', ares: '1.15.0', brotli: '1.0.7', cldr: '35.1', http_parser: '2.9.3', icu: '64.2', modules: '64', napi: '6', nghttp2: '1.39.2', node: '10.20.1', openssl: '1.1.1e', tz: '2019c', unicode: '12.1', uv: '1.34.2', v8: '6.8.275.32-node.56', zlib: '1.2.11' } -
Tha’s weird. You could try installing ‘debug’:
npm install debug -
@MichMich @K-w-b its because he is on a pi2, armv6l…
he needs to do
npm install --only=prod
to NOT try to load the chromedriver, which doesn’t exist… (same as our optional dependency for electron on armv6l) (I think its spectron which is dragging in the chromedriver)@K-w-b please use the automated install script… it fixes a bunch of problems om armv6l systems.
see here , https://github.com/sdetweil/MagicMirror_scripts
read the readme online for the command to issue…
u will need to erase the MagicMirror folder to run install again -
thank you @MichMich and @sdetweil for the responsed.
before I saw Sam’s notice, I wiped the SD card again and started with a new raspbian version from scratch. Everything from the manual installation worked fine now - MM launches. The only thing I might have done different is rebooting raspbi after upgrading
sudo apt full-upgrade- Needless to say that this is a major facepalm on my side.
So to whoever reads this in the future - follow the instructions shown on the screen (!) -
@K-w-b great news!!,
which raspian version were u trying and which worked?
