    read csv-data and put it in an array
    313 Posts 3 Posters 490.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      to include in my modul i have to do the following ?
      1. go in my module-folder
      2. npm i --save csvtojson
      than i have to include in my module.js:
      // required scripts
      getScripts: function() {
      return [“moment.js”, “csvtojson.js”];
      is this right?
      if so, how to use it in my script ?
      many thanks in advance.
      stay healthy !
        sdetweil @Perlchamp
        @Perlchamp you have to use the node_helper.js … the module.js file runs in the browser and doesn’t have access to local files
        var xxx= require(‘’)…
        then module has to send request to node_helper and node_helper has to send results back
        see my MyCovid19 module
        https://github.com/sdetweil/MyCovid19
          Perlchamp
          hello sam,
          i’m a noob. sorry for that. i will have a look to your module.
          this all is new for me. it will take some time …
          if you would help me, that would be great. but first i have to read some things …
          so long
            sdetweil @Perlchamp
            @Perlchamp my sample module might be helpful too…
            https://github.com/sdetweil/SampleModule
            implements what is in the developing module documentation
            https://docs.magicmirror.builders/development/introduction.html
              Perlchamp
              hello sam,
              thanks a lot. i will have a look on it, too. sure, i will learn a lot.
              so long
                Perlchamp
                covid chart do not load :-(
                  sdetweil @Perlchamp
                  @Perlchamp show me the config for the module?
                    Perlchamp
                    in config.js i didn’t use the config section. i thought the defaults should be enough. ok, i will put the config section into the config.js. just a moment, please …
                      sdetweil @Perlchamp
                      @Perlchamp no… I don’t pick any countries or states, or describe how big the charts should be…
                      try this
                      			module:"MyCovid19",
                      			disabled:false,
                      			position:"top_left",
                      			classes: 'sam',
                      			config:{
                      				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                      				// line colors can be any definition of color either a name ,or a hex string
                      				// one per country above, used in order,
                      				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                      				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                      				chart_title:"cumulative deaths by country", // however u want to label
                      				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                      				ranges:{min:0,max:30000,stepSize:5000},
                      				// size of the chart in pixels
                      			    width: 400,
                      			    height: 400,
                      			    // only used if we need to debug something
                      			    debug:false,
                      			    startDate:'02/01/2020',
                      			    //backgroundColor: 'white',
                        Perlchamp
                        still loading …
                        			module: "MyCovid19",
                        			config:{
                        				countries: "Italy",
                        			    //countries:["Italy","USA","China","Spain","France"],
                                        //OR
                        			    //states:['New York','Illinois','Texas'],
                        			    // one of countries or states MUST be specified
                        			    //line_colors:['red','white','green','yellow','blue'],
                        			    line_colors: "white",
                        			    chart_type:"cumulative_cases",  // or "cumulative deaths"
                        			    chart_title:"Cumulative Cases", // however u want to label
                        			    ranges:{min:0,max:8000,stepSize:10000},
                        		        width: 400,
                        		        height: 500,
                        		        debug:false,
                        		        startDate: "02/01/2020"
                        • 31
                        • 32
                        • 1 / 32
