    MM2 will not start after update
    9 Posts 2 Posters 2.5k Views 2 Watching
    • K Offline
      killing joke
      Hey @ all,
      I updated my RP3 B+ with the following commands sudo apt-get update and sudo apt-get upgrade
      and my MagicMirror 2 with the following command cd ~/MagicMirror && git pull
      The last one got some errors so I had git reset --hard and thengit pull $$ npm install it (as decribed here: update MagicMirror error - link to this forum) but now I can´t start the Mirror with npm start at the folder: ~/MagicMirror.
      This is the message which occurs:
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      App threw an error during load
      Error: Cannot find module 'module-alias/register'
          at Module._resolveFilename (module.js:543:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:473:25)
          at Module.require (module.js:586:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:14:1)
          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:282:3)
          at Module._compile (module.js:642:30)
          at Object.Module._extensions..js (module.js:653:10)
          at Module.load (module.js:561:32)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Uncaught Exception:
      Any suggestions how to solve it?
      Thanks in advance
        sdetweil @killing joke
        @killing-joke for every module that has a package.json file, you need to do an
        npm install
        in their folder too
        my upgrade script would have helped here, see
        • K Offline
          killing joke
          Hi @sdetweil,
          this is my “second” pi and it´s an free-external-module pi.
          Anyhow. I used your code but it didn´t worked for me/my pi - same error occurs.
          Unfortunately there is no log file “install.log” in the MagicMirror folder.
          Files in my MM folder:
          • CHANGELOG.m d
          • core (without file ending)
          • dangerfile.js
          • Gruntfile.js
          • index.html
          • jsconfig.json
          • LICENSE.m d
          • module-types.ts
          • package.json
          • package-lock.json
          • README.m d
          confused any suggestions?
            @killing-joke said in MM2 will not start after update:
            correct, if I am installing, I cannot out the loh IN the MM folder as it doesn’t exist yet,
            so its in the user root ~/install.log
            but there IS an upgrade.log in the installers folder as it said when it started
            and its two pass, right?? 1st time to test, second time with more arguments to actually DO the upgrade
            AND if you did it manually once, you will have to FORCE it
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
            install is NEW (if u ran install again there should be a log at ~/install.log)
            upgrade is update MM versions
            • K Offline
              killing joke
              Hi @sdetweil,
              I found the log file. I translated it into english
              install starting  - Fr Mai 22 17:59:08 CEST 2020
              installing on armv7l processor system
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
              Updating packages ...
              OK:1 http://archive.raspberrypi.org/debian stretch InRelease OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease Holen:3 https://deb.nodesource.com/node_9.x stretch InRelease [4.623 B] Es wurden 4.623 B in 1 s geholt (3.548 B/s). packages reading...
              apt-get update  completed ok
              apt-get upgrade  started
              apt upgrade result =rc=0 packages reading...
              building dependecie tree....
              status informationen reading....
              calculating packages updated (Upgrade) ...
              hold back the following packages:
                libavfilter6 libavformat57 omxplayer piwiz python-gpiozero python3-gpiozero
                python3-thonny sense-emu-tools wolfram-engine
              0 updated, 0 new installed, 0 deleted and 9 not updated.
              Installing helper tools ...
              packages reading...
              build-essential is the newest version (12.3).
              curl is already the newest version (7.52.1-5+deb9u10).
              git is already the newest version (1:2.11.0-3+deb9u6).
              unzip is already the newest version (6.0-21+deb9u2).
              wget is already the newest version (1.18-5+deb9u3).
              Minimum Node version: v10.1.0
              Installed Node version: v9.11.2
              Node should be upgraded.
              A Node process is currently running. Can't upgrade.
              Please quit all Node processes and restart the installer.
              afterwards the same error as described in the first post…
                @killing-joke that is install, and something is already running.
                Upgrade is different script.
                • K Offline
                  killing joke
                  Hi @sdetweil
                  yep, copied the wrong lines to my pi. Now i used the upgrade-code.
                  Upgrade started - Fr Mai 22 18:39:20 CEST 2020
                  system is Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
                  remote name = origin
                  upgrading from version 2.11.0 to 2.11.0
                  fetching latest revisions
                  git fetch rc=0
                  current branch = master
                  On branch master
                  Your branch is up-to-date with 'origin/master'.
                  Untracked files:
                    (use "git add <file>..." to include in what will be committed)
                  	core
                  nothing added to commit but untracked files present (use "git add" to track)
                  no files different from github version
                  test merge result rc='' , if empty, no conflicts
                  skipping merge, only test run
                  downloading dumpactivemodules script
                  no modules found needing npm refresh
                  removing git alias
                  Afterwards I performed npm update and npm restart but didn´t helped.
                  Now it´s working.
                  Thank you very much for your patience!!!
                  (how can I mark the thread as solved? - under "Topic Tool its only possible the “Delete Topic” or “Ask as question” )
                  S K 2 Replies Last reply Reply Quote 0
                    this is a two pass process… I tell you what MIGHT need to be done
                    then you run it again with ‘apply’ at the end of the command and i DO the update
                    this is for people that have lots of things that break on each update…
                    • K Offline
                      killing joke @killing joke
                      was a typo. It should be "Afterwards I performed npm update and npm restart and it helped.
                      Thank you very much.
