    MM2 will not start after update
    9 Posts 2 Posters 2.3k Views 2 Watching
    • K Offline
      killing joke
      Hi @sdetweil,
      this is my “second” pi and it´s an free-external-module pi.
      Anyhow. I used your code but it didn´t worked for me/my pi - same error occurs.
      Unfortunately there is no log file “install.log” in the MagicMirror folder.
      Files in my MM folder:
      • CHANGELOG.m d
      • core (without file ending)
      • dangerfile.js
      • Gruntfile.js
      • index.html
      • jsconfig.json
      • LICENSE.m d
      • module-types.ts
      • package.json
      • package-lock.json
      • README.m d
      confused any suggestions?
        sdetweil @killing joke
        @killing-joke said in MM2 will not start after update:
        correct, if I am installing, I cannot out the loh IN the MM folder as it doesn’t exist yet,
        so its in the user root ~/install.log
        but there IS an upgrade.log in the installers folder as it said when it started
        and its two pass, right?? 1st time to test, second time with more arguments to actually DO the upgrade
        AND if you did it manually once, you will have to FORCE it
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
        install is NEW (if u ran install again there should be a log at ~/install.log)
        upgrade is update MM versions
        • K Offline
          killing joke
          Hi @sdetweil,
          I found the log file. I translated it into english
          install starting  - Fr Mai 22 17:59:08 CEST 2020
          installing on armv7l processor system
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
          Updating packages ...
          OK:1 http://archive.raspberrypi.org/debian stretch InRelease OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease Holen:3 https://deb.nodesource.com/node_9.x stretch InRelease [4.623 B] Es wurden 4.623 B in 1 s geholt (3.548 B/s). packages reading...
          apt-get update  completed ok
          apt-get upgrade  started
          apt upgrade result =rc=0 packages reading...
          building dependecie tree....
          status informationen reading....
          calculating packages updated (Upgrade) ...
          hold back the following packages:
            libavfilter6 libavformat57 omxplayer piwiz python-gpiozero python3-gpiozero
            python3-thonny sense-emu-tools wolfram-engine
          0 updated, 0 new installed, 0 deleted and 9 not updated.
          Installing helper tools ...
          packages reading...
          build-essential is the newest version (12.3).
          curl is already the newest version (7.52.1-5+deb9u10).
          git is already the newest version (1:2.11.0-3+deb9u6).
          unzip is already the newest version (6.0-21+deb9u2).
          wget is already the newest version (1.18-5+deb9u3).
          Minimum Node version: v10.1.0
          Installed Node version: v9.11.2
          Node should be upgraded.
          A Node process is currently running. Can't upgrade.
          Please quit all Node processes and restart the installer.
          afterwards the same error as described in the first post…
            @killing-joke that is install, and something is already running.
            Upgrade is different script.
            • K Offline
              killing joke
              Hi @sdetweil
              yep, copied the wrong lines to my pi. Now i used the upgrade-code.
              Upgrade started - Fr Mai 22 18:39:20 CEST 2020
              system is Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
              remote name = origin
              upgrading from version 2.11.0 to 2.11.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up-to-date with 'origin/master'.
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	core
              nothing added to commit but untracked files present (use "git add" to track)
              no files different from github version
              test merge result rc='' , if empty, no conflicts
              skipping merge, only test run
              downloading dumpactivemodules script
              no modules found needing npm refresh
              removing git alias
              Afterwards I performed npm update and npm restart but didn´t helped.
              Now it´s working.
              Thank you very much for your patience!!!
              (how can I mark the thread as solved? - under "Topic Tool its only possible the “Delete Topic” or “Ask as question” )
              S K 2 Replies Last reply Reply Quote 0
                this is a two pass process… I tell you what MIGHT need to be done
                then you run it again with ‘apply’ at the end of the command and i DO the update
                this is for people that have lots of things that break on each update…
                • K Offline
                  killing joke @killing joke
                  was a typo. It should be "Afterwards I performed npm update and npm restart and it helped.
                  Thank you very much.
