    Changing the icon for only one calendar
    7 Posts 3 Posters 1.7k Views 3 Watching
    • VengeanceV Offline
      Vengeance
      Thanks @sdetweil
      I actually managed to just store the icons in the root dir for the module and change the .js for the module to look for the new file name.
      Now the issue I have is that .mov doesnt seem to work for icons. ( I tested with other file types to confirm the “change” worked, do now I know its just a file type issue)
        Vengeance
        New post here: https://forum.magicmirror.builders/topic/12876/getting-mov-to-work-as-icons
        • G Offline
          gubastide
          I’m new on the forum and new on MM dev.
          I have a little question : could we have different colors in the calendar (I use default module, with a google calendar) like in the web version ?
          Because I made a custom CSS
           body {
           * CALENDAR SPECIFIC
          .fa.fa-calendar-check {
            color: #2B60DE; /* Dodger Blue */
          div.CALEXT .tableStyle .eventTime {
              display:block;
          And all my pictures are blue but I would like to have this picture at the same color like my web version like this example example.PNG
          Is it possible ?
          Thank you and congrats for your work
            sdetweil @gubastide
            @gubastide sure… did u read the config for the calendar in the link from the readme?
            • G Offline
              gubastide
              @sdetweil Yes but I don’t understand how to make this …
              And English is difficult to me (I’m French) …
              Is there any solution for my problem ?
              Thank you
