    MMM-CalendarExt2 fullday events showing as 2 days
    10 Posts 6 Posters 2.3k Views 5 Watching
      A Former User
      try forceLocalTZ: true to the suspicious calendar.
        pillbug22
        I’ve seen similar issues even in Outlook before. Depending on how the “all day” event is created, the client showing you the event is interpreting it as spilling over into the 2nd day.
        For example, if you have an all-day event that is being seen as
        Monday, Jan 1, 2020 @ 0000 and goes through Tuesday, Jan 2, 2020 @ 0000
        the client app reading that appointment is looking at the ending date, and realizing it’s touching Tuesday, so it displays as Tuesday as well.
        This usually can be tested by manually creating 2 appointments that both start at midnight. One of them to match the above scenario that “touches” midnight on the next day, and then do another manual appointment that stops at 23:59, and see if the appointment that “touches” the next day shows up on both days of the calendar.
          mr_minning @Guest
          @Sean I tried this first, then I tried forceLocalTZ: false, that is why it’s still there. Neither works.
            mr_minning
            My calendars are created in Google Calendar.
            Here is one of my “offending” calendar entries. It gets rendered on every second tuesday (as expected), but also on the following wednesday, which is wrong.
            BEGIN:VEVENT
            DTSTART;VALUE=DATE:20200602
            DTEND;VALUE=DATE:20200603
            RRULE:FREQ=WEEKLY;WKST=MO;INTERVAL=2;BYDAY=TU
            DTSTAMP:20200603T175106Z
            UID:secret@google.com
            CREATED:20200603T174826Z
            DESCRIPTION:Städning
            LAST-MODIFIED:20200603T174826Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:Städning
            TRANSP:TRANSPARENT
            BEGIN:VALARM
            ACTION:DISPLAY
            DESCRIPTION:This is an event reminder
            TRIGGER:-P0DT0H30M0S
            END:VALARM
            END:VEVENT
              mr_minning
              I found the solution. The docker container was not aware of the correct timezone. I found this https://github.com/bastilimbach/docker-MagicMirror/issues/15 and added this to my docker-compose.yml
                  environment:
                    - TZ=Europe/Berlin
                    - SET_CONTAINER_TIMEZONE=true
                    - CONTAINER_TIMEZONE=Europe/Berlin
