    Mirror Update Permissions Error
    18 Posts 3 Posters 5.4k Views 3 Watching
    • X Offline
      xxLulaBelle
      My mirror is saying it needs an update but I get the following when I follow instructions to do so. Also, will the update take away all my modifications?
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
      npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /usr/lib/node_modules/npm/node_modules/graceful-fs
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’
      npm ERR! { [Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’]
      npm ERR! stack:
      npm ERR! ‘Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs'’,
      npm ERR! errno: -13,
      npm ERR! code: ‘EACCES’,
      npm ERR! syscall: ‘access’,
      npm ERR! path: ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’ }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR! /home/pi/.npm/_logs/2020-07-09T16_54_50_536Z-debug.log
        sdetweil @xxLulaBelle
        @xxLulaBelle do this
        sudo chown -r pi node_modules
        then update again
        may have to do the same for the npm library catalog
        sudo chown -r pi ~/.npm
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          xxLulaBelle @sdetweil
          @sdetweil thank you will try this.
          • X Offline
            xxLulaBelle
            I tried the above as suggested but get this error now:
            chown: invalid option – ‘r’
            Try ‘chown --help’ for more information.
              @xxLulaBelle look at the help, does it need capital R, not near my computer
              • X Offline
                xxLulaBelle
                Apologies I don’t speak the language so I don’t understand it unfortunately but I did a capital R and got the following:
                  @xxLulaBelle
                  like this notice the dash - in front of the r
                  sudo chown -R pi ~/.npm
                  • X Offline
                    Now getting this when I try to update.
                    pi@raspberrypi:~/MagicMirror $ git pull && npm install
                    Updating 447c0bf…018cb91
                    error: Your local changes to the following files would be overwritten by merge:
                    package-lock.json
                    package.json
                    Please commit your changes or stash them before you merge.
                    Aborting
                      @xxLulaBelle we don’t care about the package-lock.json file
                      but the package.json maybe
                      do
                      git diff package.json
                      to see what was changed.
                      my update script, from here, https://github.com/sdetweil/MagicMirror_scripts, might have helped.
                      • X Offline
                        xxLulaBelle
                        @sdetweil said in Mirror Update Permissions Error:
                        pi@raspberrypi:~ $ git diff package.json
                        Not a git repository
                        To compare two paths outside a working tree:
                        usage: git diff [–no-index]
