Mirror Update Permissions Error
18 Posts 3 Posters 3.8k Views 3 Watching
  • X Offline
    xxLulaBelle
    My mirror is saying it needs an update but I get the following when I follow instructions to do so. Also, will the update take away all my modifications?
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/graceful-fs
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/mkdirp
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/nopt
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /usr/lib/node_modules/npm/node_modules/spdx-license-ids
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /usr/lib/node_modules/npm/node_modules/graceful-fs
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’
    npm ERR! { [Error: EACCES: permission denied, access ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’]
    npm ERR! stack:
    npm ERR! ‘Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/graceful-fs'’,
    npm ERR! errno: -13,
    npm ERR! code: ‘EACCES’,
    npm ERR! syscall: ‘access’,
    npm ERR! path: ‘/usr/lib/node_modules/npm/node_modules/graceful-fs’ }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR! /home/pi/.npm/_logs/2020-07-09T16_54_50_536Z-debug.log
    S 1 Reply Last reply Jul 9, 2020, 5:27 PM Reply Quote 0
      sdetweil @xxLulaBelle
      @xxLulaBelle do this
      sudo chown -r pi node_modules
      then update again
      may have to do the same for the npm library catalog
      sudo chown -r pi ~/.npm
      X 1 Reply Last reply Jul 9, 2020, 7:02 PM Reply Quote 0
      • X Offline
        xxLulaBelle @sdetweil
        @sdetweil thank you will try this.
        • X Offline
          xxLulaBelle
          I tried the above as suggested but get this error now:
          chown: invalid option – ‘r’
          Try ‘chown --help’ for more information.
          S 1 Reply Last reply Jul 11, 2020, 1:22 PM Reply Quote 0
            @xxLulaBelle look at the help, does it need capital R, not near my computer
            • X Offline
              xxLulaBelle
              Apologies I don’t speak the language so I don’t understand it unfortunately but I did a capital R and got the following:
              S 1 Reply Last reply Jul 11, 2020, 2:11 PM Reply Quote 0
                @xxLulaBelle
                like this notice the dash - in front of the r
                sudo chown -R pi ~/.npm
                X 1 Reply Last reply Aug 13, 2020, 8:18 AM Reply Quote 0
                • X Offline
                  Now getting this when I try to update.
                  pi@raspberrypi:~/MagicMirror $ git pull && npm install
                  Updating 447c0bf…018cb91
                  error: Your local changes to the following files would be overwritten by merge:
                  package-lock.json
                  package.json
                  Please commit your changes or stash them before you merge.
                  Aborting
                  S 1 Reply Last reply Aug 13, 2020, 12:08 PM Reply Quote 0
                    @xxLulaBelle we don’t care about the package-lock.json file
                    but the package.json maybe
                    do
                    git diff package.json
                    to see what was changed.
                    my update script, from here, https://github.com/sdetweil/MagicMirror_scripts, might have helped.
                    • X Offline
                      xxLulaBelle
                      @sdetweil said in Mirror Update Permissions Error:
                      pi@raspberrypi:~ $ git diff package.json
                      Not a git repository
                      To compare two paths outside a working tree:
                      usage: git diff [–no-index]
