Solved Help getting remote compliments working
@robertybob correct
@sdetweil Sorry about that, I didn’t realise I wasn’t supposed to edit the .js files within the modules folders, I’ve restored the original compliments.js file.
My code within config.js now reads:
{ module: 'compliments', position: 'middle_center', config: { remoteFile: '/home/pi/MagicMirror/modules/default/compliments/remote_compliments.js' } },
however now only the default compliments are shown on the screen
@robertybob the doc says
remoteFile
Path or URL (starting with http:// or https://) to a JSON file containing compliments,
so. the file needs either the file prefix
file://
or the http prefix, assuming the server root
the server root is /home/pi/MagicMirror
so
http://localhost:8080/modules/default/compliments/compliments.jsonjson(json) and JavaScript(js) are like each other, but not the same.
I would put your json file thru one of the online parsers to make sure it’s right, and then use the correct file extension -
@robertybob actually, looking at it again, your GitHub url should work. if u put that in a browser it downloads a file
but u need to use the raw link
remoteFile:‘https://raw.githubusercontent.com/robertybob/MagicMirrorConfigs/master/compliments.json’and i put it thru an online validator and the contents look good
@sdetweil Thank you so much! I spotted a missing comma a few minutes ago, which I’ve now corrected. The raw link works perfectly. Thank you so so much!!!
@robertybob awesome!!
I use this validator, just FYI.
https://codebeautify.org/jsonvalidator -
@sdetweil I’ve submitted a pull request on the documentation repository so that hopefully no one will require assistance on this in the future ;)
