    magicmirror is blocked after 30 sec
    19 Posts 2 Posters 5.9k Views 2 Watching
      boyboy
      magicmirror freezes after 30 sec.
      the clock freezes and there is no more updating
      log :
      0|mm | npm ERR! Failed at the magicmirror@2.12.0 start script.
      0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm |
      0|mm | npm ERR! A complete log of this run can be found in:
      0|mm | npm ERR! /home/pi/.npm/_logs/2020-09-14T06_46_21_988Z-debug.log
      0|mm | npm ERR! code ELIFECYCLE
      0|mm | npm ERR! errno 1
      0|mm | npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|mm | npm ERR! Exit status 1
      0|mm | npm ERR!
      0|mm |
      0|mm | npm ERR! /home/pi/.npm/_logs/2020-09-14T06_50_14_203Z-debug.log
        boyboy
        1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
        2 info using npm@6.14.6
        3 info using node@v10.22.0
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle magicmirror@2.12.0~prestart: magicmirror@2.12.0
        6 info lifecycle magicmirror@2.12.0~start: magicmirror@2.12.0
        7 verbose lifecycle magicmirror@2.12.0~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/magicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/ga$
        9 verbose lifecycle magicmirror@2.12.0~start: CWD: /home/pi/magicMirror
        10 silly lifecycle magicmirror@2.12.0~start: Args: [ ‘-c’,
        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’ ]
        11 silly lifecycle magicmirror@2.12.0~start: Returned: code: 1 signal: null
        12 info lifecycle magicmirror@2.12.0~start: Failed to exec start script
        13 verbose stack Error: magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        13 verbose stack Exit status 1
        13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
        13 verbose stack at EventEmitter.emit (events.js:198:13)
        13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
        13 verbose stack at ChildProcess.emit (events.js:198:13)
        13 verbose stack at maybeClose (internal/child_process.js:982:16)
        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        14 verbose pkgid magicmirror@2.12.0
        15 verbose cwd /home/pi/magicMirror
        16 verbose Linux 5.4.51-v7+
        17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
        18 verbose node v10.22.0
        19 verbose npm v6.14.6
        20 error code ELIFECYCLE
        21 error errno 1
        22 error magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        22 error Exit status 1
        23 error Failed at the magicmirror@2.12.0 start script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 1, true ]
          sdetweil @boyboy
          @boyboy what was the last thing you changed before this started to happen?
          can you
          pm2 stop all
          npm start dev
          and on the pi screen, select the console tab in the dev window.
            boyboy
            Thx,
            I restarted the whole installation cleanly. The same problem appears.
            here is the console log :
            main.js:478 Initializing MagicMirror.
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
            protocols.This exposes users of this app to unnecessary security risks.
            Consider loading the following resources over HTTPS or FTPS.
            • http://localhost:8080/css/main.css
            • http://localhost:8080/fonts/roboto.css
            • http://localhost:8080/socket.io/socket.io.js
            • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
            • http://localhost:8080/js/defaults.js
            • http://localhost:8080/config/config.js
            • http://localhost:8080/vendor/vendor.js
            • http://localhost:8080/modules/default/defaultmodules.js
            • http://localhost:8080/js/logger.js
            • http://localhost:8080/translations/translations.js
            • http://localhost:8080/js/translator.js
            • http://localhost:8080/js/class.js
            • http://localhost:8080/js/module.js
            • http://localhost:8080/js/loader.js
            • http://localhost:8080/js/socketclient.js
            • http://localhost:8080/js/main.js
            • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
            • http://localhost:8080/translations/fr.json
            • http://localhost:8080/translations/en.json
            • http://localhost:8080/modules/default/alert//alert.js
            • http://localhost:8080/modules/default/alert/notificationFx.js
            • http://localhost:8080/modules/default/alert/notificationFx.css
            • http://localhost:8080/vendor/css/font-awesome.css
            • http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
            • http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
            This warning will not show up
            once the app is packaged.
            warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
            Policy set or a policy with “unsafe-eval” enabled. This exposes users of
            (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
            (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
            main.js:496 All modules started!
            weatherforecast.js:274 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=3026534&cnt=40&units=metric&lang=fr&APPID=cfc2a0386deb21a6a6cf85ca2ba89bde 401 (Unauthorized)
            updateWeather @ weatherforecast.js:274
            (anonymous) @ weatherforecast.js:396
            setTimeout (async)
            scheduleUpdate @ weatherforecast.js:395
            start @ weatherforecast.js:94
            startModules @ loader.js:52
            (anonymous) @ loader.js:38
            stylesheet.onerror @ loader.js:207
            error (async)
            loadFile @ loader.js:204
            loadNextModule @ loader.js:36
            (anonymous) @ loader.js:29
            (anonymous) @ loader.js:122
            (anonymous) @ loader.js:158
            load @ translator.js:189
            loadTranslations @ module.js:330
            (anonymous) @ loader.js:155
            loadNextDependency @ module.js:296
            (anonymous) @ module.js:293
            loadFile @ loader.js:236
            loadNextDependency @ module.js:291
            loadDependencies @ module.js:300
            loadStyles @ module.js:266
            (anonymous) @ loader.js:153
            loadScripts @ module.js:275
            bootstrapModule @ loader.js:151
            afterLoad @ loader.js:121
            loadModule @ loader.js:130
            loadNextModule @ loader.js:27
            (anonymous) @ translator.js:186
            xhr.onreadystatechange @ translator.js:22
            XMLHttpRequest.send (async)
            loadJSON @ translator.js:25
            load @ translator.js:180
            stylesheet.onload @ loader.js:201
            load (async)
            loadFile @ loader.js:199
            loadFile @ loader.js:259
            (anonymous) @ loader.js:134
            script.onload @ loader.js:181
            load (async)
            loadFile @ loader.js:179
            loadModule @ loader.js:132
            loadTranslations @ module.js:333
            load (async)
            load (async)
            load (async)
            loadFile @ loader.js:244
              @boyboy said in magicmirror is blocked after 30 sec:
              weatherforecast 401 (Unauthorized)
              looks like your appid is invalid
              custom.css’ because its MIME type
              because the file is not created by default…
              what other modules do you have installed?
                boyboy
                i have remove forecast_weather module from config.js .The problem still appears
                  boyboy
                  two errors displayed on console :
                  • Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                  • Error on loadind stylesheet: css/custom.css
                  There is only one file in : css/main.css
                    sdetweil @boyboy
                    @boyboy custom.css
                    I said before
                    because the file is not created by default… < ------- YOU have to create it if u need it
                    if you had used my installer script, it would have created one for you
                    see https://github.com/sdetweil/MagicMirror_scripts
                      sdetweil @boyboy
                      @boyboy what other modules do you have installed , can u post your config.js, please use the code marker for that text here in the forum
                      paste text,
                      select text
                      then click the </> button above
                        boyboy
                        source from : http://localhost:8080/css/custom.css
                        @loader.js :205
                        stylesheet.onerror = function () {
                        Log.error(“error on loading styleshhet:”, fileName);
                          sdetweil @boyboy
                          @boyboy hello… did u read my prior post…
                          YOU have to create the file…
                          do this
                          ~/MagicMirror
                          touch css/custom.css
                          B 1 Reply Last reply
                            boyboy
                            		module: "alert",
                            		module: "updatenotification",
                            		position: "top_bar"
                            		module: "clock",
                            		position: "top_left"
                            			maximumNumberOfDays: 100,
                            			maximumEntries: 7,
                            			fade: "false",
                            			fadePoint: "0.80",
                            					url: 'http://localhost:8080/modules/calendars/*****.ics',
                            					symbol: 'calendar'
                            					symbol: 'birthday-cake'
                            		module: "compliments",
                            		position: "lower_third"
                            		module: "currentweather",
                            			locationID: "3026534", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            			appid: "****", //openweathermap.org API key
                            			showHumidity: "true",
                            			useKMPHwind: "true",
                            			roundTemp: "true",
                            			useBeaufort: "false"
                            		module: 'MMM-AirQuality',
                            		position: 'top_right', // you may choose any location
                            			location: 'france/bourgogne/macon-paul-bert/', // the location to check the index for
                            			lang: "fr"
                            	//	module: "weatherforecast",
                            	//	position: "top_right",
                            	//	header: "Weather Forecast",
                            	//	config: {
                            	//		location: "***",
                            	//		locationID: "3026534", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            	//		appid: "****", //openweathermap.org API key
                            	//		colored: "true",
                            	//		fade: "false",
                            	//		fadePoint: "0.75",
                            	//		showRainAmount: "true",
                            	//		roundTemp: "true"
                            		module: 'MMM-Todoist',
                            		position: 'top_left',	// This can be any of the regions. Best results in left or right regions.
                            		config: { // See 'Configuration options' for more information.
                            			hideWhenEmpty: false,
                            			accessToken: '****',
                            			maximumEntries: 60,
                            			updateInterval: 10*60*1000, // Update every 10 minutes
                            			fade: false,  // projects and/or labels is mandatory:
                            			projects: [ **** ],
                            			labels: [ "MagicMirror" ] // Tasks for any projects with these labels will be shown.
                            			accessToken: '***',
                            			maximumEntries: 60,
                            			projects: [ **** ],
                            			labels:  "Important"  // Tasks for any projects with these labels will be shown.
                              boyboy @sdetweil
                              @sdetweil i did it. There is no error in console now. But clock still block after 30 sec
                                sdetweil @boyboy
                                right, because that was just a useless warning…
                                  can u show the messages from the terminal window where you do npm start?
                                  npm start >somefile
                                  then post somefile
                                  as it seems the other modules are having trouble
                                    boyboy
                                    magicmirror@2.12.0 start /home/pi/MagicMirror
                                    [2020-09-14 16:12:50.092] [LOG] Starting MagicMirror: v2.12.0
                                    [2020-09-14 16:12:50.106] [LOG] Loading config …
                                    [2020-09-14 16:12:50.120] [LOG] Loading module helpers …
                                    [2020-09-14 16:12:50.124] [LOG] No helper found for module: alert.
                                    [2020-09-14 16:12:50.218] [LOG] Initializing new module helper …
                                    [2020-09-14 16:12:50.219] [LOG] Module helper loaded: updatenotification
                                    [2020-09-14 16:12:50.221] [LOG] No helper found for module: clock.
                                    [2020-09-14 16:12:50.977] [LOG] Initializing new module helper …
                                    [2020-09-14 16:12:50.978] [LOG] Module helper loaded: calendar
                                    [2020-09-14 16:12:50.979] [LOG] No helper found for module: compliments.
                                    [2020-09-14 16:12:50.981] [LOG] No helper found for module: currentweather.
                                    [2020-09-14 16:12:50.982] [LOG] No helper found for module: MMM-AirQuality.
                                    [2020-09-14 16:12:50.987] [LOG] Initializing new module helper …
                                    [2020-09-14 16:12:50.988] [LOG] Module helper loaded: MMM-Todoist
                                    [2020-09-14 16:12:50.989] [LOG] All module helpers loaded.
                                    [2020-09-14 16:12:51.200] [LOG] Starting server on port 8080 …
                                    [2020-09-14 16:12:51.227] [LOG] Server started …
                                    [2020-09-14 16:12:51.228] [LOG] Connecting socket for: updatenotification
                                    [2020-09-14 16:12:51.231] [LOG] Connecting socket for: calendar
                                    [2020-09-14 16:12:51.233] [LOG] Starting node helper for: calendar
                                    [2020-09-14 16:12:51.234] [LOG] Connecting socket for: MMM-Todoist
                                    [2020-09-14 16:12:51.235] [LOG] Starting node helper for: MMM-Todoist
                                    [2020-09-14 16:12:51.236] [LOG] Sockets connected & modules started …
                                    [2020-09-14 16:12:51.387] [LOG] Launching application.
                                    [2020-09-14 16:12:54.429] [LOG] Create new calendar fetcher for url: http://localhost:8080/modules/calendars/****.ics - Interval: 300000
                                    [2020-09-14 16:12:54.442] [LOG] Create new calendar fetcher for url: http://localhost:8080/modules/*****.ics - Interval: 300000
                                    [2020-09-14 16:12:54.514] [INFO] Checking git for module: MMM-AirQuality
                                    [2020-09-14 16:12:54.556] [INFO] Checking git for module: MMM-Todoist
                                    [2020-09-14 16:12:54.896] [INFO] Calendar-Fetcher: Broadcasting 7 events.
                                    [2020-09-14 16:12:54.920] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                                      boyboy
                                      I have disabled all modules in config.js and the clock is not blocking.
                                      I will reactivate the modules one by one to identify the failure
                                        sdetweil @boyboy
                                        @boyboy ok… I would start by disabling one added module at a time
                                        just add
                                           module: ?????,
                                          disabled: true,              // < ---- add this line to each module, then don't have to comment out
                                          boyboy
                                          yes i did it.
                                          i solved the problem
                                          I found the fault in the compliment module.
                                          On compliments.js file
                                          I wrote :
                                          compliments: {
                                          			anytime: [],
                                          			morning: [],
                                          			afternoon: [],
                                          			evening: [],
                                          "....-01-01": ["Happy new year!"],
                                          "....-09-14": ["Happy birthday !"]
                                          then adding “”
                                          compliments: {
                                          			anytime: [""],
                                          			morning: [""],
                                          			afternoon: [""],
                                          			evening: [""],
                                          the update interval is every 30 sec, that’s why it blocked.
                                          Thanks you for your help @sdetweil
