magicmirror is blocked after 30 sec
19 Posts 2 Posters 3.2k Views 2 Watching
    boyboy
    magicmirror freezes after 30 sec.
    the clock freezes and there is no more updating
    log :
    0|mm | npm ERR! Failed at the magicmirror@2.12.0 start script.
    0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    0|mm |
    0|mm | npm ERR! A complete log of this run can be found in:
    0|mm | npm ERR! /home/pi/.npm/_logs/2020-09-14T06_46_21_988Z-debug.log
    0|mm | npm ERR! code ELIFECYCLE
    0|mm | npm ERR! errno 1
    0|mm | npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
    0|mm | npm ERR! Exit status 1
    0|mm | npm ERR!
    0|mm |
    0|mm | npm ERR! /home/pi/.npm/_logs/2020-09-14T06_50_14_203Z-debug.log
      boyboy
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@6.14.6
      3 info using node@v10.22.0
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.12.0~prestart: magicmirror@2.12.0
      6 info lifecycle magicmirror@2.12.0~start: magicmirror@2.12.0
      7 verbose lifecycle magicmirror@2.12.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/magicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/ga$
      9 verbose lifecycle magicmirror@2.12.0~start: CWD: /home/pi/magicMirror
      10 silly lifecycle magicmirror@2.12.0~start: Args: [ ‘-c’,
      10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’ ]
      11 silly lifecycle magicmirror@2.12.0~start: Returned: code: 1 signal: null
      12 info lifecycle magicmirror@2.12.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack at EventEmitter.emit (events.js:198:13)
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack at ChildProcess.emit (events.js:198:13)
      13 verbose stack at maybeClose (internal/child_process.js:982:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.12.0
      15 verbose cwd /home/pi/magicMirror
      16 verbose Linux 5.4.51-v7+
      17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
      18 verbose node v10.22.0
      19 verbose npm v6.14.6
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      22 error Exit status 1
      23 error Failed at the magicmirror@2.12.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      S 1 Reply Last reply Sep 14, 2020, 12:43 PM Reply Quote 0
        sdetweil @boyboy
        @boyboy what was the last thing you changed before this started to happen?
        can you
        pm2 stop all
        npm start dev
        and on the pi screen, select the console tab in the dev window.
          boyboy
          Thx,
          I restarted the whole installation cleanly. The same problem appears.
          here is the console log :
          main.js:478 Initializing MagicMirror.
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
          protocols.This exposes users of this app to unnecessary security risks.
          Consider loading the following resources over HTTPS or FTPS.
          • http://localhost:8080/css/main.css
          • http://localhost:8080/fonts/roboto.css
          • http://localhost:8080/socket.io/socket.io.js
          • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          • http://localhost:8080/js/defaults.js
          • http://localhost:8080/config/config.js
          • http://localhost:8080/vendor/vendor.js
          • http://localhost:8080/modules/default/defaultmodules.js
          • http://localhost:8080/js/logger.js
          • http://localhost:8080/translations/translations.js
          • http://localhost:8080/js/translator.js
          • http://localhost:8080/js/class.js
          • http://localhost:8080/js/module.js
          • http://localhost:8080/js/loader.js
          • http://localhost:8080/js/socketclient.js
          • http://localhost:8080/js/main.js
          • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          • http://localhost:8080/translations/fr.json
          • http://localhost:8080/translations/en.json
          • http://localhost:8080/modules/default/alert//alert.js
          • http://localhost:8080/modules/default/alert/notificationFx.js
          • http://localhost:8080/modules/default/alert/notificationFx.css
          • http://localhost:8080/vendor/css/font-awesome.css
          • http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
          • http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
          This warning will not show up
          once the app is packaged.
          warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with “unsafe-eval” enabled. This exposes users of
          (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
          (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
          main.js:496 All modules started!
          weatherforecast.js:274 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=3026534&cnt=40&units=metric&lang=fr&APPID=cfc2a0386deb21a6a6cf85ca2ba89bde 401 (Unauthorized)
          updateWeather @ weatherforecast.js:274
          (anonymous) @ weatherforecast.js:396
          setTimeout (async)
          scheduleUpdate @ weatherforecast.js:395
          start @ weatherforecast.js:94
          startModules @ loader.js:52
          (anonymous) @ loader.js:38
          stylesheet.onerror @ loader.js:207
          error (async)
          loadFile @ loader.js:204
          loadNextModule @ loader.js:36
          (anonymous) @ loader.js:29
          (anonymous) @ loader.js:122
          (anonymous) @ loader.js:158
          load @ translator.js:189
          loadTranslations @ module.js:330
          (anonymous) @ loader.js:155
          loadNextDependency @ module.js:296
          (anonymous) @ module.js:293
          loadFile @ loader.js:236
          loadNextDependency @ module.js:291
          loadDependencies @ module.js:300
          loadStyles @ module.js:266
          (anonymous) @ loader.js:153
          loadScripts @ module.js:275
          bootstrapModule @ loader.js:151
          afterLoad @ loader.js:121
          loadModule @ loader.js:130
          loadNextModule @ loader.js:27
          (anonymous) @ translator.js:186
          xhr.onreadystatechange @ translator.js:22
          XMLHttpRequest.send (async)
          loadJSON @ translator.js:25
          load @ translator.js:180
          stylesheet.onload @ loader.js:201
          load (async)
          loadFile @ loader.js:199
          loadFile @ loader.js:259
          (anonymous) @ loader.js:134
          script.onload @ loader.js:181
          load (async)
          loadFile @ loader.js:179
          loadModule @ loader.js:132
          loadTranslations @ module.js:333
          load (async)
          load (async)
          load (async)
          loadFile @ loader.js:244
            @boyboy said in magicmirror is blocked after 30 sec:
            weatherforecast 401 (Unauthorized)
            looks like your appid is invalid
            custom.css’ because its MIME type
            because the file is not created by default…
            what other modules do you have installed?
              boyboy
              i have remove forecast_weather module from config.js .The problem still appears
              S 1 Reply Last reply Sep 14, 2020, 2:04 PM Reply Quote 0
                boyboy
                two errors displayed on console :
                • Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                • Error on loadind stylesheet: css/custom.css
                There is only one file in : css/main.css
                S 1 Reply Last reply Sep 14, 2020, 2:02 PM Reply Quote 0
                  sdetweil @boyboy
                  @boyboy custom.css
                  I said before
                  because the file is not created by default… < ------- YOU have to create it if u need it
                  if you had used my installer script, it would have created one for you
                  see https://github.com/sdetweil/MagicMirror_scripts
                    sdetweil @boyboy
                    @boyboy what other modules do you have installed , can u post your config.js, please use the code marker for that text here in the forum
                    paste text,
                    select text
                    then click the </> button above
                      boyboy
                      source from : http://localhost:8080/css/custom.css
                      @loader.js :205
                      stylesheet.onerror = function () {
                      Log.error(“error on loading styleshhet:”, fileName);
                      S 1 Reply Last reply Sep 14, 2020, 2:06 PM Reply Quote 0
