    magicmirror is blocked after 30 sec
    19 Posts 2 Posters 5.9k Views 2 Watching
      @boyboy said in magicmirror is blocked after 30 sec:
      weatherforecast 401 (Unauthorized)
      looks like your appid is invalid
      custom.css’ because its MIME type
      because the file is not created by default…
      what other modules do you have installed?
        boyboy
        i have remove forecast_weather module from config.js .The problem still appears
          boyboy
          two errors displayed on console :
          • Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
          • Error on loadind stylesheet: css/custom.css
          There is only one file in : css/main.css
            sdetweil @boyboy
            @boyboy custom.css
            I said before
            because the file is not created by default… < ------- YOU have to create it if u need it
            if you had used my installer script, it would have created one for you
            see https://github.com/sdetweil/MagicMirror_scripts
              sdetweil @boyboy
              @boyboy what other modules do you have installed , can u post your config.js, please use the code marker for that text here in the forum
              paste text,
              select text
              then click the </> button above
                boyboy
                source from : http://localhost:8080/css/custom.css
                @loader.js :205
                stylesheet.onerror = function () {
                Log.error(“error on loading styleshhet:”, fileName);
                  sdetweil @boyboy
                  @boyboy hello… did u read my prior post…
                  YOU have to create the file…
                  do this
                  ~/MagicMirror
                  touch css/custom.css
                  B 1 Reply Last reply
                    boyboy
                    		module: "alert",
                    		module: "updatenotification",
                    		position: "top_bar"
                    		module: "clock",
                    		position: "top_left"
                    			maximumNumberOfDays: 100,
                    			maximumEntries: 7,
                    			fade: "false",
                    			fadePoint: "0.80",
                    					url: 'http://localhost:8080/modules/calendars/*****.ics',
                    					symbol: 'calendar'
                    					symbol: 'birthday-cake'
                    		module: "compliments",
                    		position: "lower_third"
                    		module: "currentweather",
                    			locationID: "3026534", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    			appid: "****", //openweathermap.org API key
                    			showHumidity: "true",
                    			useKMPHwind: "true",
                    			roundTemp: "true",
                    			useBeaufort: "false"
                    		module: 'MMM-AirQuality',
                    		position: 'top_right', // you may choose any location
                    			location: 'france/bourgogne/macon-paul-bert/', // the location to check the index for
                    			lang: "fr"
                    	//	module: "weatherforecast",
                    	//	position: "top_right",
                    	//	header: "Weather Forecast",
                    	//	config: {
                    	//		location: "***",
                    	//		locationID: "3026534", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    	//		appid: "****", //openweathermap.org API key
                    	//		colored: "true",
                    	//		fade: "false",
                    	//		fadePoint: "0.75",
                    	//		showRainAmount: "true",
                    	//		roundTemp: "true"
                    		module: 'MMM-Todoist',
                    		position: 'top_left',	// This can be any of the regions. Best results in left or right regions.
                    		config: { // See 'Configuration options' for more information.
                    			hideWhenEmpty: false,
                    			accessToken: '****',
                    			maximumEntries: 60,
                    			updateInterval: 10*60*1000, // Update every 10 minutes
                    			fade: false,  // projects and/or labels is mandatory:
                    			projects: [ **** ],
                    			labels: [ "MagicMirror" ] // Tasks for any projects with these labels will be shown.
                    			accessToken: '***',
                    			maximumEntries: 60,
                    			projects: [ **** ],
                    			labels:  "Important"  // Tasks for any projects with these labels will be shown.
                      boyboy @sdetweil
                      @sdetweil i did it. There is no error in console now. But clock still block after 30 sec
                        sdetweil @boyboy
                        right, because that was just a useless warning…
                          can u show the messages from the terminal window where you do npm start?
                          npm start >somefile
                          then post somefile
                          as it seems the other modules are having trouble
                            boyboy
                            magicmirror@2.12.0 start /home/pi/MagicMirror
                            [2020-09-14 16:12:50.092] [LOG] Starting MagicMirror: v2.12.0
                            [2020-09-14 16:12:50.106] [LOG] Loading config …
                            [2020-09-14 16:12:50.120] [LOG] Loading module helpers …
                            [2020-09-14 16:12:50.124] [LOG] No helper found for module: alert.
                            [2020-09-14 16:12:50.218] [LOG] Initializing new module helper …
                            [2020-09-14 16:12:50.219] [LOG] Module helper loaded: updatenotification
                            [2020-09-14 16:12:50.221] [LOG] No helper found for module: clock.
                            [2020-09-14 16:12:50.977] [LOG] Initializing new module helper …
                            [2020-09-14 16:12:50.978] [LOG] Module helper loaded: calendar
                            [2020-09-14 16:12:50.979] [LOG] No helper found for module: compliments.
                            [2020-09-14 16:12:50.981] [LOG] No helper found for module: currentweather.
                            [2020-09-14 16:12:50.982] [LOG] No helper found for module: MMM-AirQuality.
                            [2020-09-14 16:12:50.987] [LOG] Initializing new module helper …
                            [2020-09-14 16:12:50.988] [LOG] Module helper loaded: MMM-Todoist
                            [2020-09-14 16:12:50.989] [LOG] All module helpers loaded.
                            [2020-09-14 16:12:51.200] [LOG] Starting server on port 8080 …
                            [2020-09-14 16:12:51.227] [LOG] Server started …
                            [2020-09-14 16:12:51.228] [LOG] Connecting socket for: updatenotification
                            [2020-09-14 16:12:51.231] [LOG] Connecting socket for: calendar
                            [2020-09-14 16:12:51.233] [LOG] Starting node helper for: calendar
                            [2020-09-14 16:12:51.234] [LOG] Connecting socket for: MMM-Todoist
                            [2020-09-14 16:12:51.235] [LOG] Starting node helper for: MMM-Todoist
                            [2020-09-14 16:12:51.236] [LOG] Sockets connected & modules started …
                            [2020-09-14 16:12:51.387] [LOG] Launching application.
                            [2020-09-14 16:12:54.429] [LOG] Create new calendar fetcher for url: http://localhost:8080/modules/calendars/****.ics - Interval: 300000
                            [2020-09-14 16:12:54.442] [LOG] Create new calendar fetcher for url: http://localhost:8080/modules/*****.ics - Interval: 300000
                            [2020-09-14 16:12:54.514] [INFO] Checking git for module: MMM-AirQuality
                            [2020-09-14 16:12:54.556] [INFO] Checking git for module: MMM-Todoist
                            [2020-09-14 16:12:54.896] [INFO] Calendar-Fetcher: Broadcasting 7 events.
                            [2020-09-14 16:12:54.920] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                              boyboy
                              I have disabled all modules in config.js and the clock is not blocking.
                              I will reactivate the modules one by one to identify the failure
                                sdetweil @boyboy
                                @boyboy ok… I would start by disabling one added module at a time
                                just add
                                   module: ?????,
                                  disabled: true,              // < ---- add this line to each module, then don't have to comment out
                                  boyboy
                                  yes i did it.
                                  i solved the problem
                                  I found the fault in the compliment module.
                                  On compliments.js file
                                  I wrote :
                                  compliments: {
                                  			anytime: [],
                                  			morning: [],
                                  			afternoon: [],
                                  			evening: [],
                                  "....-01-01": ["Happy new year!"],
                                  "....-09-14": ["Happy birthday !"]
                                  then adding “”
                                  compliments: {
                                  			anytime: [""],
                                  			morning: [""],
                                  			afternoon: [""],
                                  			evening: [""],
                                  the update interval is every 30 sec, that’s why it blocked.
                                  Thanks you for your help @sdetweil
