This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
Solved Add JS Code to the Mirror
I added your code snippet in 1st line after
var mpd = require('mpd'),
and output
[2020-10-24 01:56:54.490] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/mpd_client/node_helper.js:1 var mpd = require('mpd'),const NodeHelper = require("node_helper"); ^^^^^ SyntaxError: Unexpected token const at Module._compile (internal/modules/cjs/loader.js:722:23) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at loadModule (/home/pi/MagicMirror/js/app.js:134:17) at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5) at /home/pi/MagicMirror/js/app.js:171:6 at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
@dnj0104 no, I want it to be a line BEFORE the stuff in the file already
AH! Sorry!
Changed it now your snippet in 1st Line
And we have Success!!! Finally!!
Thanks Alot @sdetweil
