MMM-Carousel w/ Slide Navigation
15 Posts 2 Posters 3.7k Views 3 Watching
    raf
    why can’t I switch my pages manually
    no arrows are displayed on the screen
    the page indicators are displayed
    I can move the mouse anywhere on the screen but no arrows
    this is in my config.js
                module: 'MMM-Carousel',
                position: 'bottom_bar', // Required only for navigation controls
                    transitionInterval: 0,
                    ignoreModules: ['clock', 'alert'],
                    mode: 'slides',
                    showPageIndicators: true,
                    showPageControls: true,
                    slides: {
                        main: ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                        "Slide 2": ['newsfeed',],
                    keyBindings: {
                        enabled: true,
                        map: {
                            NextSlide: "ArrowRight",
                            PrevSlide: "ArrowLeft",
                            Slide0:    "Home"
                        mode: "DEFAULT"```
    code_text
    code_text
      banbutcher
      hey buddy,
      take a look at the way each slide is defined! think your missing quotes from main page
      • at bottom not sure but i think mode should be keyBindingsMode
      • missing a comma after slide0
      • not sure but check that all your open { have a closer }
      • do you have MMM-Keybindings installed? (eidt - i just checked and carousel wont change pages without MMM-Keybindings.)
                      ignoreModules: ['alert', 'MMM-GoogleAssistant'],
                      mode: 'slides',
                      slides: {
                          "Default":['clock', 'calendar_monthly', 'MMM-NetworkScanner', 'currentweather', 'weatherforecast', 'MMM-Weather'],
                          "Work":['MMM-google-route'],
                          "Office":['MMM-google-route2'],
      //		    "Traffic":['MMM-GoogleMapsTraffic'],
                          "Home":['clock', 'calendar_monthly', 'calendar', 'currentweather', 'weatherforecast', 'MMM-MyCommute', 'MMM-NetworkScanner',
      		    'MMM-COVID19-SPARKLINE', 'MMM-Spotify', 'MMM-GoogleFit', 'MMM-Todoist', 'newsfeed'],
                          "Info":['clock', 'calendar_monthly', 'currentweather', 'weatherforecast', 'MMM-Tools', 'MMM-NetworkScanner',
      		    'MMM-NetworkConnection', 'deluge', 'MMM-SystemStats'],
                      keyBindings: {
                          enabled: true,
                          map: {
                              Slide0: "ArrowUp",
      			Slide5: "ArrowDown",
                          keyBindingsMode: "DEFAULT"
      here is my config for MMM-Keybindings:
      /*-------------------- MMM-KeyBindings Start-----------------*/
          module: 'MMM-KeyBindings',
      	evdev: {enabled: false},
              enableKeyboard: true,
      	actions: [
      	  key: "ArrowRight",
      	  state: "KEY_PRESSED",
      	  instance: "SERVER",
      	  mode: "DEFAULT",
      	 key: "ArrowLeft",
      	 instance: "SERVER",
      	 mode: "DEFAULT",
      have a look at my working code and try again! :)
      R 1 Reply Last reply Nov 2, 2020, 5:40 AM Reply Quote 0
        raf @banbutcher
        @banbutcher
                        ignoreModules: ['clock', 'alert', 'MMM-GoogleAssistant',],
                        mode: 'slides',
                        slides: {
                            "Default": ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                            "Slide 3": ['newsfeed',],
                            "Slide 4": ['newsfeed',],
                            "Slide 5": ['newsfeed',],
                        keyBindings: {
                            enabled: true,
                            map: {
                                Slide0: "ArrowUp",
                            mode: "DEFAULT"
                	actions: [
                	  key: "ArrowRight",
                	  instance: "SERVER",
                	  mode: "DEFAULT",
                	 key: "ArrowLeft",
                	 instance: "SERVER",
                	 mode: "DEFAULT",
        it still doesn’t work and I don’t see what’s wrong (I have to tell you that I control the pi via my windows pc) with vnc
          banbutcher
          @raf the only thing i can think of is to rename the slides without numbers, you dont need them for the keybindings, it sets it automatically:
          "default" = slide0, "slide 2" = slide1 etc…
          try renaming the slides maybe "zero" "one" "two" etc…
          also check whos version of carousel you have as theres 2! :dizzy_face:
          look over this, its how i figured it out!! :thumbs_up_light_skin_tone:
          i use vnc from a mac so should be ok!?
          R 1 Reply Last reply Nov 2, 2020, 5:28 PM Reply Quote 0
            raf @banbutcher
            @banbutcher
            have given the pages a different name, but that is not the solution
              banbutcher
              Did you see which version on carousel you have?
              R 1 Reply Last reply Nov 3, 2020, 7:29 AM Reply Quote 0
                raf @banbutcher
                @banbutcher
                carousel version 0.2.6
                keyBindings 1.3.1
                  raf
                  I have seen at startup it does give a message: (No helper found for module: MMM-Carousel.)
                  but i don’t know if it is normal and what i can do about it
                  [2020-11-03 11:17:14.590] [LOG]    Starting MagicMirror: v2.13.0
                  [2020-11-03 11:17:14.606] [LOG]    Loading config ...
                  [2020-11-03 11:17:14.621] [LOG]    Loading module helpers ...
                  [2020-11-03 11:17:14.624] [LOG]    No helper found for module: MMM-Carousel.
                  [2020-11-03 11:17:14.639] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:14.642] [LOG]    Module helper loaded: MMM-KeyBindings
                  [2020-11-03 11:17:15.562] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:15.563] [LOG]    Module helper loaded: MMM-UpdateNotification
                  [2020-11-03 11:17:21.615] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:21.617] [LOG]    Module helper loaded: MMM-GoogleAssistant
                  [2020-11-03 11:17:24.351] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:24.353] [LOG]    Module helper loaded: MMM-Assistant2Display
                  [2020-11-03 11:17:24.355] [LOG]    No helper found for module: alert.
                  [2020-11-03 11:17:24.362] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:24.364] [LOG]    Module helper loaded: updatenotification
                  [2020-11-03 11:17:24.366] [LOG]    No helper found for module: clock.
                  [2020-11-03 11:17:25.219] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:25.221] [LOG]    Module helper loaded: calendar
                  [2020-11-03 11:17:25.374] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:25.375] [LOG]    Module helper loaded: MMM-Tools
                  [2020-11-03 11:17:25.511] [LOG]    Initializing new module helper ...
                  [2020-11-03 11:17:25.512] [LOG]    Module helper loaded: MMM-TuyaSL
                    banbutcher
                    just checked about the node helper and that comes up on mine too! :)
                    as for version - i mean whos git repo did you clone from, as you would have read if you read the link i gave you >:( that there are at least 2 versions of carousel. go to the module folder and check the readme file and it will be in there some where…
                    use the link above and read it! solution should be there!
                    R 1 Reply Last reply Nov 4, 2020, 5:37 AM Reply Quote 0
                      raf @banbutcher
                      @banbutcher
                      barnabycolby & shbatm
                      the carousel works over SSH, right?
                      B 1 Reply Last reply Nov 4, 2020, 6:30 AM Reply Quote 0
