    MMM-Carousel w/ Slide Navigation
    15 Posts 2 Posters 4.7k Views 3 Watching
      banbutcher
      Did you see which version on carousel you have?
        raf @banbutcher
        @banbutcher
        carousel version 0.2.6
        keyBindings 1.3.1
          raf
          I have seen at startup it does give a message: (No helper found for module: MMM-Carousel.)
          but i don’t know if it is normal and what i can do about it
          [2020-11-03 11:17:14.590] [LOG]    Starting MagicMirror: v2.13.0
          [2020-11-03 11:17:14.606] [LOG]    Loading config ...
          [2020-11-03 11:17:14.621] [LOG]    Loading module helpers ...
          [2020-11-03 11:17:14.624] [LOG]    No helper found for module: MMM-Carousel.
          [2020-11-03 11:17:14.639] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:14.642] [LOG]    Module helper loaded: MMM-KeyBindings
          [2020-11-03 11:17:15.562] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:15.563] [LOG]    Module helper loaded: MMM-UpdateNotification
          [2020-11-03 11:17:21.615] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:21.617] [LOG]    Module helper loaded: MMM-GoogleAssistant
          [2020-11-03 11:17:24.351] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:24.353] [LOG]    Module helper loaded: MMM-Assistant2Display
          [2020-11-03 11:17:24.355] [LOG]    No helper found for module: alert.
          [2020-11-03 11:17:24.362] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:24.364] [LOG]    Module helper loaded: updatenotification
          [2020-11-03 11:17:24.366] [LOG]    No helper found for module: clock.
          [2020-11-03 11:17:25.219] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:25.221] [LOG]    Module helper loaded: calendar
          [2020-11-03 11:17:25.374] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:25.375] [LOG]    Module helper loaded: MMM-Tools
          [2020-11-03 11:17:25.511] [LOG]    Initializing new module helper ...
          [2020-11-03 11:17:25.512] [LOG]    Module helper loaded: MMM-TuyaSL
            banbutcher
            just checked about the node helper and that comes up on mine too! :)
            as for version - i mean whos git repo did you clone from, as you would have read if you read the link i gave you >:( that there are at least 2 versions of carousel. go to the module folder and check the readme file and it will be in there some where…
            use the link above and read it! solution should be there!
              raf @banbutcher
              @banbutcher
              barnabycolby & shbatm
              the carousel works over SSH, right?
                banbutcher @raf
                @raf
                if its not working after that, im afraid i dont know, sorry
                i dont know anything about ssh either :(
                  raf
                  @vondes
                  have been on it for days even now at the moment and still nothing
                    raf
                    in the end this is my solution (don’t add keybindings)
                                module: 'MMM-Carousel',
                                position: 'bottom_bar', // Required only for navigation controls
                                    transitionInterval: 0,
                                    ignoreModules: ['clock', 'alert', 'MMM-GoogleAssistant',],
                                    mode: 'slides',
                                    showPageIndicators: true,
                                    showPageControls: true,
                                    slides: {
                                        "Default": ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                                        "Slide 2": ['newsfeed',],
                                        "Slide 3": ['newsfeed',],
                                        "Slide 4": ['newsfeed',],
                                        "Slide 5": ['newsfeed',],
                                    keyBindings: {
                                        enabled: true,
                                        map: {
                                            NextSlide: "ArrowRight",
                                            PrevSlide: "ArrowLeft",
                                            Slide0: "ArrowUp",
                                            Slide5: "ArrowDown",
                                        mode: "DEFAULT"
                      banbutcher
                      glad to hear you figured it out, i know coming from a very limited knowledge base, trial and error was how i figured it out!
                      when you say dont add key bindings do you mean the module MMM-Keybindings or the keyBindings in the carousel config?
                        raf @banbutcher
                        @banbutcher
                        module installed (MMM-Keybindings) but not added in the config and it works (my knowledge is also very limited because I also have to figure everything out) I normally work in the concrete so that is something completely different huh
