Rotate the display 2560X1080 Raspberry Pi4
 I have a 2560x1080 display on the Raspberry Pi4. I cannot rotate the display. My settings are:@lxpanel --profile LXDE-pi @pcmanfm --desktop --profile LXDE-pi @lxterminal @leafpad @xrandr --output HDMI-1 --rotate right @xscreensaver -no-splash@and /boot/config.txt: hdmi_safe=1 hdmi_drive=2 hdmi_ignore_edid=0xa5000080 hdmi_aspect_21_9=7 hdmi_pixel_freq_limit=400000000 hdmi_cvt=2560 1080 50 7 0 0 1 config_hdmi_boost=4 max_framebuffer_width=2560 max_framebuffer_height=1080 framebuffer_width=2560 framebuffer_height=1080 display_rotate = 2 avoid_warnings=1 hdmi_group=2 hdmi_mode=87 hdmi_force_hotplug=1 dtoverlay=vc4-fkms-v3d max_framebuffers=2Can somebody help me?
 i rotated my screen through the pi itself
 preferences and screen rotation
 @wuermchen there should be an option in the raspi-config program (run from a terminal window) for rotation sudo raspi-config
 that does not work
 @raf yes, thanks. That is where it was
 sometimes i can also solve a problem except for myself
 @wuermchen I think your original problem was in /boot/config.txt where you had spaces around the equal sign for display_rotate.
 I found the mistake. The HDMI cable was defective. I installed a new cable and now it automatically detects the resolution. The display is now correctly rotated.
