    how can I display MM on my 2nd screen (just one pi 4)
    8 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @Axel51
      @Axel51 add to config.js
      electonOptions:{x:1920},
      X = size of display width
        Axel51 @sdetweil
        @sdetweil Thx for your help.
        In fact, x is the abscissa of the letf corner of your MM. So, you have to take in account if there 's a second screen on the left. In this case, x would be the width of the left screen. If not, x would be 0.
          sdetweil @Axel51
          @Axel51 said in how can I display MM on my 2nd screen (just one pi 4):
          eh?
          if u have two screens left and right, in port 0 and 1
          then to get MM to display on the right monitor, in port 1, u need to set x to the width of the left monitor (port 0),
          and If you are doing above and below
          y (instead of x), the height of the monitor 0 in pixels.
          on my desktop in use x:1920
          on my pi i use x:3840 (running in 4k mode)
            Axel51 @sdetweil
            @sdetweil yes absolutely
            you can do the same with y
              Axel51 @Axel51
              @Axel51 for rpi, there is only one display port number 0
                sdetweil @Axel51
                @Axel51 i was talking about the the physical ports on the PI4. not the logical DISPLAY number
                  Axel51 @sdetweil
                  @sdetweil ;-)
                  Thx for all!
