Unsolved MMM-MirrorMirrorOnTheWall installation issue
All the info is in the thread for this to work
@parsons12 I’m at the same point you are. Trying to read through this thread to get a better idea of what I still have to do. I wish someone took the time to compile all the info into a nice doc. Have you figured this out yet? I get the Hello Queen response but then “unable to handle request” error whenever I try to show text, images, etc. I’m working through how to enable google search
@sbrundage85 Same Same. Started several months ago, went through this thread and still was not working. Just started to look at it again with a fresh install and go through the thread again. having the same issue. ill post more if i find something. Maybe the more attention we bring back to the thread the bigger the possibility of it getting fixed
So after going through the thread again, i am still stuck on the policy issue. i have tried @blackpanda code for the policy change while also changing the client ID to “MagicMirror” on both the pi/MirrorMirrorOnTheWallSkill/src/MirrorMirror.js and pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/MirrorMirror.js
With this i still get Attempt to connect to AWS. my cloudwatch logs show
2019-07-19T20:27:06.893Z 100e7185-039f-42ce-be95-07ea3a83c847 Task timed out after 3.00 seconds
which might mean its still a policy security issue or its just not connecting to Iot core.
When Prompted with intent, Alexa responds with the usual Hello my Queen, but when given a command i continue to get the classic “there was a problem with requested skill response”. Although the logs do show that the youtube video is requested then it times out.
Any ideas?
