    remotecompliments disappeared - please help
    47 Posts 2 Posters 19.7k Views 2 Watching
    • F
      forjer @sdetweil
      @sdetweil And it’s a 3 B+
        sdetweil @forjer
        @forjer show me the config for those modules…
        do u have a position set for compliments
        F 1 Reply Last reply
        • F
          forjer @sdetweil
          @sdetweil I originally had a position of “upper_third” set but removed that yesterday when I started manually debugging. I just added it back in now as shown below with no change to the behavior…still no remote compliments showing.
          Here’s my clock…
          			module: "clock",
          			position: "top_center"
          This is how my remote compliments looked yesterday before I started manually debugging…
          			module: "MMM-RemoteCompliments",
          			header: "",
          			position: "upper_third",
          				header: "MMM-RemoteCompliments",
          				fetchInterval: 4000,
          This is what I had at the time I ran the above developers window and pm2 log…
          			    // See below for configurable options
          And I just threw the position back in with no change to the behavior…no remotecompliments showing whatsoever…
          module: “MMM-RemoteCompliments”,
          position: “upper_third”,
          header: “MMM-RemoteCompliments”,
            sdetweil @forjer
            @forjer u do have a url or something in the config section, yes? u have no content like that
            • F
              forjer @sdetweil
              @sdetweil The only url I have is for the default calendar module which I currently have commented out. The RemoteCompliments is the module that runs through Google Drive. As far as I know RemoteCompliments doesn’t require an url.
                sdetweil @forjer
                @forjer ok, I see the user setup in the drives folder
                let’s look in the console again, pm2 logs
                the Google authentication expires after a day.
                • F
                  forjer @sdetweil
                  @sdetweil For the pm2 logs, do I just do the default last 15 lines or should I do more. And if I do more I suppose there’s some"sensitive" stuff I should wipe out?
                  And as far a sGoogle authentication expiring, please expand on that. I set this up some weeks ago and hadn’t had a problem until sometime in the last few days…I’m thinking yesterday.
                    sdetweil @forjer
                    @forjer if the system isn’t run for a while a day I think… just helped another user with authentication failure
                    can’t think of any personal info in the log w those two modules…
                    if concerned, pm2 stop 0,
                    pm2 flush
                    pm2 start 0
                    pm2 logs
                    • F
                      forjer @sdetweil
                      pi@raspberrypi:~ $ pm2 logs
                      /home/pi/.pm2/pm2.log last 15 lines:
                      PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMir |
                      0|MagicMir | [2020-12-28 20:37:07.031] [LOG]    Starting MagicMirror: v2.13.0
                      0|MagicMir | [2020-12-28 20:37:07.045] [LOG]    Loading config ...
                      0|MagicMir | [2020-12-28 20:37:07.060] [LOG]    Loading module helpers ...
                      0|MagicMir | [2020-12-28 20:37:07.064] [LOG]    No helper found for module: clock.
                      0|MagicMir | [2020-12-28 20:37:10.491] [LOG]    Initializing new module helper ...
                      0|MagicMir | [2020-12-28 20:37:10.492] [LOG]    Module helper loaded: MMM-RemoteCompliments
                      0|MagicMir | [2020-12-28 20:37:10.493] [LOG]    All module helpers loaded.
                      0|MagicMir | [2020-12-28 20:37:10.714] [LOG]    Starting server on port 8080 ...
                      0|MagicMir | [2020-12-28 20:37:10.739] [LOG]    Server started ...
                      0|MagicMir | [2020-12-28 20:37:10.740] [LOG]    Connecting socket for: MMM-RemoteCompliments
                      0|MagicMir | [2020-12-28 20:37:10.744] [LOG]    Starting node helper for: MMM-RemoteCompliments
                      0|MagicMir | [2020-12-28 20:37:10.745] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [2020-12-28 20:37:10.891] [LOG]    Launching application.
                        sdetweil @forjer
                        @forjer no logging. sheesh
                        edit the module node_helper.js file,
                        take the //
                        off line 65 and 66
                          @forjer I think u will have to delete the Token.json file and rerun drives/setup.js
                          F 2 Replies Last reply
                          • F
                            forjer @sdetweil
                            @sdetweil Is this confirming what you thought?
                            PM2        | 2020-12-28T20:46:29: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2020-12-28T20:46:30: PM2 log: pid=17838 msg=failed to kill - retrying in 100ms
                            PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2020-12-28T20:46:30: PM2 log: pid=17838 msg=process killed
                            PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] online
                            0|MagicMir | [2020-12-28 20:46:45.545] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:48.247] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:48.251] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:50.493] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:50.501] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:52.743] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:52.744] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:54.986] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:54.988] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:57.215] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:57.216] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:46:59.763] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:46:59.765] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMir | [2020-12-28 20:47:02.299] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMir | [2020-12-28 20:47:02.301] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:04.513] [LOG]
                            0|MagicMirror  | MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                            0|MagicMirror  | [2020-12-28 20:47:04.518] [LOG]
                            0|MagicMirror  | MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:06.742] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:06.744] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:08.981] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:08.983] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:11.225] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:11.226] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:13.464] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:13.465] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:15.688] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:15.689] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:17.919] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:17.920] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:20.168] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:20.169] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:22.424] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:22.426] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:24.665] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:24.667] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:26.898] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:26.899] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:29.123] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:29.125] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:31.371] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:31.372] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:33.596] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:33.598] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:35.830] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:35.834] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                            0|MagicMirror  | [2020-12-28 20:47:38.074] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:38.080] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:40.326] [LOG]
                            0|MagicMirror  | [2020-12-28 20:47:40.327] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                              sdetweil @forjer
                              @forjer yeh. so the setup has probably expired
                              • F
                                forjer @sdetweil
                                @sdetweil So are you saying I should delete the Token.json file from /home/pi/MagicMirror/modules/MMM-RemoteCompliments/Drive and run node setup which will re-run the Setup.js script?
                                • F
                                  forjer @sdetweil
                                  @sdetweil I deleted the Token.json file and ran node Setup in the RemoveCompliments/Drive folder and was successful in re-completing the setup (following link, pasting code), but there was no change in function…RemoteCompliments is MIA…no header or anything.
                                  • F
                                    forjer
                                    FWIW, I’m also running the default Compliments in the lower_third position. I’ve swapped positions between Compliements and RemoteCompliments and the result of that is Compliments works in both positions, RemoteCompliments doesn’t work in either position.
                                      sdetweil @forjer
                                      @forjer and the pm2 log?
                                      • F
                                        forjer @sdetweil
                                        PM2        | 2020-12-28T21:29:05: PM2 log: pid=22698 msg=process killed
                                        PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                        PM2        | 2020-12-28T21:29:05: PM2 log: App [MagicMirror:0] online
                                        PM2        | 2020-12-28T21:29:50: PM2 log: Stopping app:MagicMirror id:0
                                        PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=failed to kill - retrying in 100ms
                                        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                        PM2        | 2020-12-28T21:29:51: PM2 log: pid=23236 msg=process killed
                                        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                        PM2        | 2020-12-28T21:29:51: PM2 log: App [MagicMirror:0] online
                                        PM2        | 2020-12-28T21:46:00: PM2 log: Stopping app:MagicMirror id:0
                                        PM2        | 2020-12-28T21:46:00: PM2 log: pid=23422 msg=failed to kill - retrying in 100ms
                                        PM2        | 2020-12-28T21:46:00: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                        PM2        | 2020-12-28T21:46:01: PM2 log: pid=23422 msg=process killed
                                        PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                        PM2        | 2020-12-28T21:46:01: PM2 log: App [MagicMirror:0] online
                                        0|MagicMir |
                                        0|MagicMir | [2020-12-28 21:46:04.542] [LOG]    Starting MagicMirror: v2.13.0
                                        0|MagicMir | [2020-12-28 21:46:04.557] [LOG]    Loading config ...
                                        0|MagicMir | [2020-12-28 21:46:04.568] [LOG]    Loading module helpers ...
                                        0|MagicMir | [2020-12-28 21:46:04.571] [LOG]    No helper found for module: clock.
                                        0|MagicMir | [2020-12-28 21:46:07.600] [LOG]    Initializing new module helper ...
                                        0|MagicMir | [2020-12-28 21:46:07.601] [LOG]    Module helper loaded: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 21:46:07.602] [LOG]    All module helpers loaded.
                                        0|MagicMir | [2020-12-28 21:46:07.798] [LOG]    Starting server on port 8080 ...
                                        0|MagicMir | [2020-12-28 21:46:07.819] [LOG]    Server started ...
                                        0|MagicMir | [2020-12-28 21:46:07.821] [LOG]    Connecting socket for: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 21:46:07.825] [LOG]    Starting node helper for: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 21:46:07.826] [LOG]    Sockets connected & modules started ...
                                        0|MagicMir | [2020-12-28 21:46:07.960] [LOG]    Launching application.
                                          sdetweil @forjer
                                          @forjer sorry, I’ve run out of everything to look for. the error is gone now…
                                          • F
                                            forjer @sdetweil
                                            @sdetweil In my developer log it mentions “RemoteCompliments: ‘MODULE_DOM_CREATED’ received: null” and “module.js:199 MMM-RemoteCompliments is suspended.” Is that a clue? It just doesn’t make sense. I tested it yesterday morning by putting in a really long compliment just to see how it looked on the screen. I then reverted it back to a short compliment. Later in the morning I did a sudo apt-get update and a sudo apt-get upgradejust before setting up remote desktop, VNC and pitunnel. Those are the only other things that I can think of where I changed some stuff.
                                            developers window
                                            Load script: modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
                                            module.js:513 Module registered: MMM-RemoteCompliments
                                            loader.js:148 Bootstrapping module: MMM-RemoteCompliments
                                            loader.js:176 Load script: modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
                                            loader.js:153 Scripts loaded for: MMM-RemoteCompliments
                                            loader.js:155 Styles loaded for: MMM-RemoteCompliments
                                            loader.js:157 Translations loaded for: MMM-RemoteCompliments
                                            loader.js:195 Load stylesheet: css/custom.css
                                            :8080/modules/default/clock//clock.js:46 Starting module: clock
                                            main.js:508 All modules started!
                                            :8080/modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js:222 MMM-RemoteCompliments: 'MODULE_DOM_CREATED' received:  null
                                            Are there any other (perhaps more stable) modules where I can display a custom message (compliment) depending on the time of day? I had about 10 compliments programmed to display at their specified time slots throughout the day. And I liked the ability to control / override them easily with my phone via Google Drive.
