    remotecompliments disappeared - please help
    47 Posts 2 Posters 16.3k Views 2 Watching
    • F Offline
      forjer @sdetweil
      @sdetweil In the developers window, it looks like I’ve got 3 errors, 1 warning and 1 issue. I’m not sure the right way to capture and post them.
        sdetweil @forjer
        @forjer copy paste.
        can’t open display :0
        are u doing this over ssh, vnc,??
        • F Offline
          forjer @sdetweil
          @sdetweil said in remotecompliments disappeared - please help:
          oing this over ssh,
          I’m logged in directly. And thanks for giving it a look.
          Developers window
          cdn.carbonads.com/carbon.js?serve=CK7IC23N&placement=magicmirrorbuilders:1 Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
          translator.js:7 Missing key in translation token "global:"
          n @ translator.js:7
          3favicon.ico:1 Failed to load resource: the server responded with a status of 404 ()
          DevTools failed to load SourceMap: Could not load content for https://forum.magicmirror.builders/assets/src/modules/pulling-drawer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
            sdetweil @forjer
            @forjer i think u are looking at the magicmirror.builders web site window not the mm window
            what pi is this?
            F 2 Replies Last reply Reply Quote 0
            • F Offline
              forjer @sdetweil
              @sdetweil As I said…I’m pretty new at this. Lol.
              I’ve commented out all modules except the clock and MMM-RemoteCompliments.
              main.js:487 Initializing MagicMirror.
              translator.js:129 Loading core translation file: translations/en.json
              translator.js:154 Loading core translation fallback file: translations/en.json
              loader.js:176 Load script: modules/default/clock//clock.js
              module.js:513 Module registered: clock
              loader.js:148 Bootstrapping module: clock
              loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
              loader.js:153 Scripts loaded for: clock
              loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
              loader.js:155 Styles loaded for: clock
              loader.js:157 Translations loaded for: clock
              loader.js:176 Load script: modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
              module.js:513 Module registered: MMM-RemoteCompliments
              loader.js:148 Bootstrapping module: MMM-RemoteCompliments
              loader.js:176 Load script: modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
              loader.js:153 Scripts loaded for: MMM-RemoteCompliments
              loader.js:155 Styles loaded for: MMM-RemoteCompliments
              loader.js:157 Translations loaded for: MMM-RemoteCompliments
              loader.js:195 Load stylesheet: css/custom.css
              :8080/modules/default/clock//clock.js:46 Starting module: clock
              main.js:508 All modules started!
              /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                protocols.This exposes users of this app to unnecessary security risks.
                Consider loading the following resources over HTTPS or FTPS.
               - http://localhost:8080/css/main.css
              - http://localhost:8080/fonts/roboto.css
              - http://localhost:8080/socket.io/socket.io.js
              - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
              - http://localhost:8080/js/defaults.js
              - http://localhost:8080/config/config.js
              - http://localhost:8080/vendor/vendor.js
              - http://localhost:8080/modules/default/defaultmodules.js
              - http://localhost:8080/js/logger.js
              - http://localhost:8080/translations/translations.js
              - http://localhost:8080/js/translator.js
              - http://localhost:8080/js/class.js
              - http://localhost:8080/js/module.js
              - http://localhost:8080/js/loader.js
              - http://localhost:8080/js/socketclient.js
              - http://localhost:8080/js/main.js
              - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
              - http://localhost:8080/translations/en.json
              - http://localhost:8080/modules/default/clock//clock.js
              - http://localhost:8080/vendor/node_modules/moment/min/moment-with-locales.js
              - http://localhost:8080/vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              - http://localhost:8080/vendor/node_modules/suncalc/suncalc.js
              - http://localhost:8080/modules/default/clock/clock_styles.css
              - http://localhost:8080/modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
              - http://localhost:8080/modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
              - http://localhost:8080/css/custom.css
              For more information and help, consult
              https://electronjs.org/docs/tutorial/security.
               This warning will not show up
              once the app is packaged.
              warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
              /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                  Policy set or a policy with "unsafe-eval" enabled. This exposes users of
              • F Offline
                forjer @sdetweil
                @sdetweil And it’s a 3 B+
                  sdetweil @forjer
                  @forjer show me the config for those modules…
                  do u have a position set for compliments
                  • F Offline
                    forjer @sdetweil
                    @sdetweil I originally had a position of “upper_third” set but removed that yesterday when I started manually debugging. I just added it back in now as shown below with no change to the behavior…still no remote compliments showing.
                    Here’s my clock…
                    			module: "clock",
                    			position: "top_center"
                    This is how my remote compliments looked yesterday before I started manually debugging…
                    			module: "MMM-RemoteCompliments",
                    			header: "",
                    			position: "upper_third",
                    				header: "MMM-RemoteCompliments",
                    				fetchInterval: 4000,
                    This is what I had at the time I ran the above developers window and pm2 log…
                    			    // See below for configurable options
                    And I just threw the position back in with no change to the behavior…no remotecompliments showing whatsoever…
                    module: “MMM-RemoteCompliments”,
                    position: “upper_third”,
                    header: “MMM-RemoteCompliments”,
                      sdetweil @forjer
                      @forjer u do have a url or something in the config section, yes? u have no content like that
                      • F Offline
                        forjer @sdetweil
                        @sdetweil The only url I have is for the default calendar module which I currently have commented out. The RemoteCompliments is the module that runs through Google Drive. As far as I know RemoteCompliments doesn’t require an url.
                          sdetweil @forjer
                          @forjer ok, I see the user setup in the drives folder
                          let’s look in the console again, pm2 logs
                          the Google authentication expires after a day.
                          • F Offline
                            forjer @sdetweil
                            @sdetweil For the pm2 logs, do I just do the default last 15 lines or should I do more. And if I do more I suppose there’s some"sensitive" stuff I should wipe out?
                            And as far a sGoogle authentication expiring, please expand on that. I set this up some weeks ago and hadn’t had a problem until sometime in the last few days…I’m thinking yesterday.
                              sdetweil @forjer
                              @forjer if the system isn’t run for a while a day I think… just helped another user with authentication failure
                              can’t think of any personal info in the log w those two modules…
                              if concerned, pm2 stop 0,
                              pm2 flush
                              pm2 start 0
                              pm2 logs
                              • F Offline
                                forjer @sdetweil
                                pi@raspberrypi:~ $ pm2 logs
                                /home/pi/.pm2/pm2.log last 15 lines:
                                PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] online
                                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                0|MagicMir |
                                0|MagicMir | [2020-12-28 20:37:07.031] [LOG]    Starting MagicMirror: v2.13.0
                                0|MagicMir | [2020-12-28 20:37:07.045] [LOG]    Loading config ...
                                0|MagicMir | [2020-12-28 20:37:07.060] [LOG]    Loading module helpers ...
                                0|MagicMir | [2020-12-28 20:37:07.064] [LOG]    No helper found for module: clock.
                                0|MagicMir | [2020-12-28 20:37:10.491] [LOG]    Initializing new module helper ...
                                0|MagicMir | [2020-12-28 20:37:10.492] [LOG]    Module helper loaded: MMM-RemoteCompliments
                                0|MagicMir | [2020-12-28 20:37:10.493] [LOG]    All module helpers loaded.
                                0|MagicMir | [2020-12-28 20:37:10.714] [LOG]    Starting server on port 8080 ...
                                0|MagicMir | [2020-12-28 20:37:10.739] [LOG]    Server started ...
                                0|MagicMir | [2020-12-28 20:37:10.740] [LOG]    Connecting socket for: MMM-RemoteCompliments
                                0|MagicMir | [2020-12-28 20:37:10.744] [LOG]    Starting node helper for: MMM-RemoteCompliments
                                0|MagicMir | [2020-12-28 20:37:10.745] [LOG]    Sockets connected & modules started ...
                                0|MagicMir | [2020-12-28 20:37:10.891] [LOG]    Launching application.
                                  sdetweil @forjer
                                  @forjer no logging. sheesh
                                  edit the module node_helper.js file,
                                  take the //
                                  off line 65 and 66
                                    @forjer I think u will have to delete the Token.json file and rerun drives/setup.js
                                    • F Offline
                                      forjer @sdetweil
                                      @sdetweil Is this confirming what you thought?
                                      PM2        | 2020-12-28T20:46:29: PM2 log: Stopping app:MagicMirror id:0
                                      PM2        | 2020-12-28T20:46:30: PM2 log: pid=17838 msg=failed to kill - retrying in 100ms
                                      PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2020-12-28T20:46:30: PM2 log: pid=17838 msg=process killed
                                      PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2        | 2020-12-28T20:46:30: PM2 log: App [MagicMirror:0] online
                                      0|MagicMir | [2020-12-28 20:46:45.545] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:48.247] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:48.251] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:50.493] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:50.501] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:52.743] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:52.744] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:54.986] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:54.988] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:57.215] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:57.216] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:46:59.763] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:46:59.765] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMir | [2020-12-28 20:47:02.299] [LOG]    MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMir | [2020-12-28 20:47:02.301] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:04.513] [LOG]
                                      0|MagicMirror  | MMM-RemoteCompliments: An error occurred when fetching from Google Drive that could not be recovered from:  Error with GET request for spreadsheet with ID '1dzINW3oWAYee6lbtFyaBO3hco4EErxI9ZL3Dvk_F-7s'.
                                      0|MagicMirror  | [2020-12-28 20:47:04.518] [LOG]
                                      0|MagicMirror  | MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:06.742] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:06.744] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:08.981] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:08.983] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:11.225] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:11.226] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:13.464] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:13.465] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:15.688] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:15.689] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:17.919] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:17.920] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:20.168] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:20.169] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:22.424] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:22.426] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:24.665] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:24.667] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:26.898] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:26.899] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:29.123] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:29.125] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:31.371] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:31.372] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:33.596] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:33.598] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:35.830] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:35.834] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                      0|MagicMirror  | [2020-12-28 20:47:38.074] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:38.080] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:40.326] [LOG]
                                      0|MagicMirror  | [2020-12-28 20:47:40.327] [LOG]    MMM-RemoteCompliments: Fetching again in two seconds.
                                        sdetweil @forjer
                                        @forjer yeh. so the setup has probably expired
                                        • F Offline
                                          forjer @sdetweil
                                          @sdetweil So are you saying I should delete the Token.json file from /home/pi/MagicMirror/modules/MMM-RemoteCompliments/Drive and run node setup which will re-run the Setup.js script?
                                          • F Offline
                                            forjer @sdetweil
                                            @sdetweil I deleted the Token.json file and ran node Setup in the RemoveCompliments/Drive folder and was successful in re-completing the setup (following link, pasting code), but there was no change in function…RemoteCompliments is MIA…no header or anything.
