MM only server version working due to issues with config file
@legan if the server ver runs, then its not a config.js problem, but most likely a failure to run npm install in some module folder…
npm start messages should show you ‘unable to locate module’
@sdetweil thank you so much for your fast reply!
Attached you will find a screenshot of the whole responseDo you have an concrete idea what I should do to fix it?
@legan i don’t see the config error…
@legan you are connected via ssh, and using DISPLAY=:0, so should be displaying on pi monitor
exactly and I got the config error on the monitor which is connected to the pi
@legan eh? take a pic?
This post is deleted! -
@legan pic the icon with the sun over the mountain, folded upper right corner
