Calendar issue - Private work calendar
10 Posts 2 Posters 453 Views 2 Watching
  • T Offline
    trev125
    I have seen some other posts here with a similar issue, but nothing quite like what I am facing. The odd thing is this seemed to have broken recently, as it was working just a few days ago…
    The company I work for makes our calendars private, and that’s fine with me, all I want to show on my MM is the “Busy” subject for when I have meetings (will make it easier for my wife to know when I am in a meeting or when I am not)
    These are the settings of the calendar:
    I am trying to use the basic.ics one at the bottom of that second image, but its not pulling in any of the data.
    Things I have tried:
    1. running curl -L https://calendar.google.com/calendar/ical/********************/public/basic.ics on my computer and my raspberry pi (both are pulling in the data correctly as far as I can tell)
      I am getting data like this back:
    BEGIN:VCALENDAR
    BEGIN:VEVENT
    DTSTART:20201105T200000Z
    DTEND:20201105T210000Z
    UID:*********@google.com
    ATTENDEE;X-NUM-GUESTS=0:mailto:**************
    SUMMARY:Busy
    END:VEVENT
    END:VCALENDAR
    1. I have manually typed in the /basic.ics url into Chromium on my Raspberry Pi and it downloads it properly too
    2. I have manually added this calendar yo my personal google account and it pulls it in properly
    Any other recommendations would be much appreciated!
    S 1 Reply Last reply Jan 4, 2021, 12:07 AM Reply Quote 0
      sdetweil @trev125
      @trev125 said in Calendar issue - Private work calendar:
      BEGIN:VCALENDAR
      BEGIN:VEVENT
      UID:@google.com
      SUMMARY:Busy
      END:VEVENT
      END:VCALENDAR
      well, THAT event is november 5th
      we don’t display events in the past
      I changed the date, but because it has no timezone associated (only UTC start/stop)
      my TZ is used, and its STILL in the past
      Sun Jan 03 2021 14:00:00 GMT-0600
      if I make it jan 4, at 20:00 UTC it shows and says in 20 hours, as its 6 pm (18:00) here and the appt says 2 pm (14:00)
      T 1 Reply Last reply Jan 4, 2021, 3:12 AM Reply Quote 0
        I made a lot of changes to calendar this last 3 months to get it right.
        u could email me the ics file, its text, sanitize anything u need to.
        my email in my same userid here at gmail
        • T Offline
          trev125 @sdetweil
          @sdetweil said in Calendar issue - Private work calendar:
          BEGIN:VCALENDAR
          BEGIN:VEVENT
          UID:@google.com
          SUMMARY:Busy
          END:VEVENT
          END:VCALENDAR
          Youre right, I put in the oldest one instead of the newest, I didnt realize the .ics was in that order. It looks like I have appointments ranging from 2020 to 2022. One that should be valid is this (I added the header and footer of the .ics to this to make it more clear):
          BEGIN:VCALENDAR
          PRODID:-//Google Inc//Google Calendar 70.9054//EN
          VERSION:2.0
          CALSCALE:GREGORIAN
          METHOD:PUBLISH
          X-WR-CALNAME:******
          X-WR-TIMEZONE:America/Denver
          BEGIN:VEVENT
          DTSTART:20210104T220000Z
          DTEND:20210104T225000Z
          DTSTAMP:20210103T224853Z
          UID:**********@google.com
          RECURRENCE-ID:20210104T220000Z
          SUMMARY:Busy
          END:VEVENT
          END:VCALENDAR
          And its still not showing up in my calendar
          S 1 Reply Last reply Jan 4, 2021, 3:18 AM Reply Quote 0
            sdetweil @trev125
            @trev125 ok, shows on mine… what mm version are u on?
            grep version ~/MagicMirror/package.json
            T 1 Reply Last reply Jan 4, 2021, 3:33 AM Reply Quote 0
            • T Offline
              trev125 @sdetweil
              @sdetweil “version”: “2.14.0”,
              S 1 Reply Last reply Jan 4, 2021, 3:35 AM Reply Quote 0
                sdetweil @trev125
                @trev125 ok, change config.js
                add
                	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                if its already there, add “DEBUG”
                then restart MM
                If you are using pm2, the
                pm2 flush
                pm2 restart 0
                this is what I see for the latest event u posted, i set my timezone to yours
                [03.01.2021 20:35.36.727] [DEBUG]  parsed data={"**********@google.com":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy","recurrences":{"2021-01-04":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy"}}}}
                [03.01.2021 20:35.36.727] [DEBUG] there are 1 calendar entries
                [03.01.2021 20:35.36.729] [DEBUG] have entries
                [03.01.2021 20:35.36.730] [DEBUG]
                event={"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy","recurrences":{"2021-01-04":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy"}}}
                [03.01.2021 20:35.36.730] [DEBUG]  start=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time) end=Mon Jan 04 2021 15:50:00 GMT-0700 (Mountain Standard Time)
                [03.01.2021 20:35.36.730] [DEBUG]  if no tz, guess based on now
                [03.01.2021 20:35.36.742] [DEBUG] initial tz=America/Denver
                [03.01.2021 20:35.36.743] [DEBUG] corrected tz=America/Denver
                [03.01.2021 20:35.36.743] [DEBUG] start date/time=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
                [03.01.2021 20:35.36.744] [DEBUG] start offset=-420
                [03.01.2021 20:35.36.745] [DEBUG] start date/time w tz =Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
                [03.01.2021 20:35.36.745] [DEBUG] event date=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
                [03.01.2021 20:35.36.745] [DEBUG] event offset=-420 hour=15 event date=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
                [03.01.2021 20:35.36.745] [DEBUG] adjustHours=0
                [03.01.2021 20:35.36.746] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                also, can u show the calendar config entry, not the url
                u would see this data in the pm2 logs
                using command
                pm2 logs --lines=100
                T 1 Reply Last reply Jan 4, 2021, 3:53 AM Reply Quote 0
                • T Offline
                  trev125 @sdetweil
                  @sdetweil Thanks for the quick responses. It looks like the calendar that I am pulling in has around 600 events, if that is anything.
                  Because of that, it makes it hard to read the debugger, but I did see this:
                  "2021-01-05":{"type":"VEVENT","params":[],"start":"2021-01-05T17:00:00.000Z","datetype":"date-time","end":"2021-01-05T17:25:00.000Z","dtstamp":"2021-01-04T03:46:12.000Z","uid":"*******@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:******"},"recurrenceid":"2021-01-05T17:00:00.000Z","summary":"Busy"},
                  Then I have some things like this, but I dont notice any of them for any dates coming up soon:
                  [03.01.2021 20:46.13.274] [DEBUG]  start=Tue Jan 03 2023 10:00:00 GMT-0700 (Mountain Standard Time) end=Tue Jan 03 2023 10:25:00 GMT-0700 (Mountain Standard Time)
                  [03.01.2021 20:46.13.274] [DEBUG] have entries
                  Also: here is my calendar config:
                  			header: "Calendar",
                  			position: "top_bar",
                  			maximumEntries: 80,
                  						symbol: "calendar-check",
                  						url: "https://calendar.google.com/calendar/ical/******/public/basic.ics"
                  I can edit and send you the .ics if that would be helpful, I can sanitize it
                  S 2 Replies Last reply Jan 4, 2021, 3:55 AM Reply Quote 0
                    sdetweil @trev125
                    @trev125 yes, please, the sanitized ics would be awesome…
                    I won’t get to it til tomorrow tho
                      sdetweil @trev125
                      @trev125 i got it and sent u an email back
