    Calendar issue - Private work calendar
    10 Posts 2 Posters 570 Views 2 Watching
    • T Offline
      trev125 @sdetweil
      @sdetweil “version”: “2.14.0”,
        sdetweil @trev125
        @trev125 ok, change config.js
        add
        	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
        if its already there, add “DEBUG”
        then restart MM
        If you are using pm2, the
        pm2 flush
        pm2 restart 0
        this is what I see for the latest event u posted, i set my timezone to yours
        [03.01.2021 20:35.36.727] [DEBUG]  parsed data={"**********@google.com":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy","recurrences":{"2021-01-04":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy"}}}}
        [03.01.2021 20:35.36.727] [DEBUG] there are 1 calendar entries
        [03.01.2021 20:35.36.729] [DEBUG] have entries
        [03.01.2021 20:35.36.730] [DEBUG]
        event={"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy","recurrences":{"2021-01-04":{"type":"VEVENT","params":[],"start":"2021-01-04T22:00:00.000Z","datetype":"date-time","end":"2021-01-04T22:50:00.000Z","dtstamp":"2021-01-03T22:48:53.000Z","uid":"**********@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:*********"},"recurrenceid":"2021-01-04T22:00:00.000Z","summary":"Busy"}}}
        [03.01.2021 20:35.36.730] [DEBUG]  start=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time) end=Mon Jan 04 2021 15:50:00 GMT-0700 (Mountain Standard Time)
        [03.01.2021 20:35.36.730] [DEBUG]  if no tz, guess based on now
        [03.01.2021 20:35.36.742] [DEBUG] initial tz=America/Denver
        [03.01.2021 20:35.36.743] [DEBUG] corrected tz=America/Denver
        [03.01.2021 20:35.36.743] [DEBUG] start date/time=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
        [03.01.2021 20:35.36.744] [DEBUG] start offset=-420
        [03.01.2021 20:35.36.745] [DEBUG] start date/time w tz =Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
        [03.01.2021 20:35.36.745] [DEBUG] event date=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
        [03.01.2021 20:35.36.745] [DEBUG] event offset=-420 hour=15 event date=Mon Jan 04 2021 15:00:00 GMT-0700 (Mountain Standard Time)
        [03.01.2021 20:35.36.745] [DEBUG] adjustHours=0
        [03.01.2021 20:35.36.746] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
        also, can u show the calendar config entry, not the url
        u would see this data in the pm2 logs
        using command
        pm2 logs --lines=100
        • T Offline
          trev125 @sdetweil
          @sdetweil Thanks for the quick responses. It looks like the calendar that I am pulling in has around 600 events, if that is anything.
          Because of that, it makes it hard to read the debugger, but I did see this:
          "2021-01-05":{"type":"VEVENT","params":[],"start":"2021-01-05T17:00:00.000Z","datetype":"date-time","end":"2021-01-05T17:25:00.000Z","dtstamp":"2021-01-04T03:46:12.000Z","uid":"*******@google.com","attendee":{"params":{"X-NUM-GUESTS":0},"val":"mailto:******"},"recurrenceid":"2021-01-05T17:00:00.000Z","summary":"Busy"},
          Then I have some things like this, but I dont notice any of them for any dates coming up soon:
          [03.01.2021 20:46.13.274] [DEBUG]  start=Tue Jan 03 2023 10:00:00 GMT-0700 (Mountain Standard Time) end=Tue Jan 03 2023 10:25:00 GMT-0700 (Mountain Standard Time)
          [03.01.2021 20:46.13.274] [DEBUG] have entries
          Also: here is my calendar config:
          			header: "Calendar",
          			position: "top_bar",
          			maximumEntries: 80,
          						symbol: "calendar-check",
          						url: "https://calendar.google.com/calendar/ical/******/public/basic.ics"
          I can edit and send you the .ics if that would be helpful, I can sanitize it
            sdetweil @trev125
            @trev125 yes, please, the sanitized ics would be awesome…
            I won’t get to it til tomorrow tho
              sdetweil @trev125
              @trev125 i got it and sent u an email back
