    [DEBUG] Default Weather Module with OpenWeatherMap One Call API
    openweathermaponecallapidefaultweathermodulehourlycurrentdaily
    7 Posts 5 Posters 3.4k Views 5 Watching
    • L Offline
      lost
      minor correction, the maxNumberOfEntries config parameter is wrong, it should be maxEntries instead:
      module: "weather",
      position: "bottom_center",
      header: "Hourly Forecast",
      	type: "wDataHourly", // wDataCurrent and wDataDaily theoretically work but currently don't have .njk files
      	apiKey: "OPENWEATHERMAPAPIKEY", // your OpenWeatherMap API key
      	lat: 40.7128, // your latitude
      	lon: -74.0060, // your longitude
      	weatherEndpoint: "/onecall",
      	maxEntries: 12
      • L Offline
        lost
        Got it working! I think I’ll just avoid dot notation from now on…
        Repo is linked below. If anyone’s looking to use this, OpenWeatherMap’s One Call API asks for latitude and longitude instead of a location or location ID. But in return, you can get not only current and daily (max 7 days) forecasts, but also hourly forecasts (max 48 hours).
        All original functionality of the module should remain intact.
        Sample Module Configurations:
        	module: "weather",
        	position: "bottom_left",
        	header: "Current Forecast",
        		type: "wDataCurrent",
        		initialLoadDelay: 0,
        	module: "weather",
        		initialLoadDelay: 2500,
        		maxEntries: 32, // max 48, set by OWM One Call API
        		showPrecipitationAmount: true
        	module: "weather",
        	position: "bottom_right",
        	header: "Daily Forecast",
        		type: "wDataDaily",
        		initialLoadDelay: 5000,
        		maxEntries: 7, // max 7, set by OWM One Call API
        		colored: true,
        Sample MagicMirror Output:
        Current, Hourly, and Daily Forecasts using the OpenWeatherMap One Call API
        Link to Branch
        Not making a pull request yet since I don’t know how the default Weather module is meant to be designed.
        • Feedy88F Offline
          Feedy88
          Hey @lost,
          thanks for creating this. I am currently building my first mirror and have issues with the weather module from the master (only showing “Loading”) and hence wanted to try yours, as I am looking for hourly data anyways.
          However, I am a total noob to git and stuff, so I don’t know how to install your branch. Could you help me out here? Much appreciated in advance.
            julien-vancouver
            Thanks for your work, ive tried using your config above and have run into two issues.
            module: “weather”,
            position: “bottom_left”,
            header: “Current Forecast”,
            weatherProvider: “openweathermap”,
            weatherEndpoint: “/onecall”,
            type: “wDataCurrent”,
            apiKey: “xxxxxxx”, // your OpenWeatherMap API key
            1. using the type: “wDataCurrent” results in “UNDEFINED”
              however if I change variable to Current, I then run into issue 2.
            2. loading. Similar to your original post, my screen remains forever loading and doesn’t load the retrieved values.
            any other thoughts or tips & tricks on how to resolve?
            • I Offline
              icemanmw
              i had the same problem and changed type: “wDataCurrent”, to type: “current”, because in the folder /home/pi/MagicMirror/modules/default/weather i found the files
              current.njk
              hourly.njk
              forecast.njk
              now is runs
                dangarlen @icemanmw
