    Default currentweather and weatherforecast not displaying
    8 Posts 2 Posters 2.0k Views 2 Watching
      brendan_c23
      I registered for api key yesterday and have entered in the locationIDs and appids in the config.js file under weatherforecast and currentweather modules. I do not receive any errors after saving but nothing comes up in the magicmirror interface once I run the magic mirror. Any help would be appreciated
        brendan_c23 @brendan_c23
        @brendan_c23 Turns out my api key was off by a letter. Got the current weather to display, but the temperatures are definitely off. It says it is 0.1 degrees and feels like -3 degrees where I am, but the app on my Iphone says it is 36 degrees outside. I have verified that I have entered the correct locationID for the city/state that Im in. My weather forecast still isnt displaying either.
          @brendan_c23
          Here is my config.js file
          module: “weatherforecast”,
          position: “top_right”,
          header: “Weather Forecast”,
          conifg: {
          locationID: “4487042”,
          appid: “b3da6c6f773acb0ed39cdbXXXXXXXXXX”,
          module: “currentweather”,
          B JerryPJ 3 Replies Last reply Reply Quote 0
            @brendan_c23 Would really appreciate any help. The time is off also for the current weather. Still can not get weather forecast to display
            • JerryPJ Offline
              JerryP @brendan_c23
              • JerryPJ Offline
                JerryP @brendan_c23
                @brendan_c23
                	module: "currentweather",
                		locationID: "4487042",
                		appid: "TOP SECRTE"
                	module: "weatherforecast",
                	header: "",
                		appid: "Top Secret",
                		fade: false,
                		colored: true,
                This loc ID i test on my own mirror and it’s working. So Or your APPID is false or you make een wrong " at the start or end.
                  brendan_c23 @JerryP
                  @jerryp I have exact same code as you got. 4487042 as my ID, still giving me wrong temperature and weather forecast is not showing up. Made sure I have correct quotations everywhere
                  JerryPJ 1 Reply Last reply Reply Quote 0
                  • JerryPJ Offline
                    JerryP @brendan_c23
                    @brendan_c23 The only thin I can think off is that the API is not working or correct config.
                    If you run the Develop en see the log.
                    shift + Control + I
                    And than look for the faults
