    Make a remove header space or overlap two modules
    7 Posts 2 Posters 2.3k Views 2 Watching
    • halacabullasH Offline
      halacabullas
      @sdetweil i can identify that there is a script for every module, but seems to me,that i can not access to a single module to edit it, they are all clump together (could be mistaken im pretty noob)
      screenshots here
        sdetweil @halacabullas
        @halacabullas edit the main.css and comment our cursor:none; in body , like this
        html {
          /*cursor: none; */
          overflow: hidden;
          background: #000;
          user-select: none;
        then u can se the mouse over the mm page content
        then ctrl-shift-i, and select the elements tab
        expand the left nav to the region, top, right (in my case), expand, find modules,
        expand, select module, see element tree to right
        add background-color:blue;
        if header still displayed, add change display:block the display :none
        (top right, blue circle)
        (just click in the element ares to edit, add, delete styles)
        middle, red circle is the class tree of the element… rightmost is closest to custom.css
          halacabullas
          @sdetweil If i change the display from block to none. that works. And put everything just where i want it. (I know i have like 0 knowlege about it) but is there a way to save the modified html code? seems like if i close and reopen the mm it’s back to normal.
          Also the edit generates like this kind of code, that i tried to add to the custom css, i tried like this, changing to .module header, and other similar stuff but nothing works
            @halacabullas well, all good except u missed my one step , finding the info for custom.css
            u need the module name and the element class name
            see in the editor view, the stuff circled in green (take off the module_number_, and the ‘module’ prefixes )
            .weatherforecast .module-header {
            display: none !important;
            sometimes u need the force the priority of the style, with !important
            halacabullasH 1 Reply Last reply Reply Quote 0
              halacabullas @sdetweil
              @sdetweil THAT WAS IT. THANK YOU SO MUCH <3333
